Old 12-09-2020, 11:51 AM   #101
geunther
geunther's Avatar
Re: The build date project
Originally Posted by 402Bowtie View Post
Another curiosity... Has anyone seen a 2F2 VIN? Did they jump from F1 to F3 for some reason?
The lower number is after the higher number, so that alone does not explain. I'm sure the the folks on this forum, we will figure it out.
Canadian trucks?
geunther is offline   Reply With Quote
Old 12-09-2020, 11:58 AM   #102
402Bowtie
402Bowtie's Avatar
71 chevy; 1S622914; 1/71
71 GMC; S132048; 6/xx....based on our data, it should be 6/71
402Bowtie is offline   Reply With Quote
Old 12-09-2020, 12:39 PM   #103
geunther
geunther's Avatar
Originally Posted by geunther View Post
I certainly do not doubt the veracity of the "F3", I just have not been able to find the pattern. Considering Flint producing 300,000 for 72 equals 25,000 per month. So going to the end of March should equal about 200,000 trucks. So going with those numbers, the highest VIN for March of 72 Flint should be F300000. Of course, these numbers are based upon averages, not faster and slower production at different times.
Looking at March numbers for the other plants, Flints numbers would have to be about 71% higher. But if Flint produced half of the entire 72 run, this percentage would make sense.
However, we do have a Flint jamb sticker 4/72 with a sequence of F163780. I have added the F355033 and will continue to try and reconcile this.
Ok, I think I found the information but am looking at it more deeply and will share when I find more. It appears for 1972 Flint also used sequencing beginning with 300001 and 700001. For 71 Flint also used 800001.
Old 12-09-2020, 12:52 PM   #104
geunther
geunther's Avatar
From web
Z154606 = 4/9/70
Old 12-09-2020, 03:09 PM   #105
402Bowtie
402Bowtie's Avatar
72 chevy; 2F332776; 12/71
71 chevy suburban; 1F647787; 5/71
72 chevy suburban; 2F160080; 3/72
70 gmc St Louis; SZ55672; 10/69
Old 12-09-2020, 06:54 PM   #106
70c10-08
70c10-08's Avatar
My 69 C/20 parts truck 9S436384; 7/69 she was from St. Louis
70c10-08 is offline   Reply With Quote
Old 12-09-2020, 08:02 PM   #107
402Bowtie
402Bowtie's Avatar
72 chevy; 2Z154193; 3/24/72
Old 12-09-2020, 09:14 PM   #108
402Bowtie
402Bowtie's Avatar
Not sure this one is helpful. Can anyone read it?
72 Blazer; 2S105697; I think the date is 8/71, but maybe this is one for the discard pile since it is hard to read.
Old 12-09-2020, 10:12 PM   #109
geunther
geunther's Avatar
Ill add it and show ??/71
Old 12-09-2020, 10:13 PM   #110
57taskforce
All about them K’s
57taskforce's Avatar
That’s exactly what I was gonna say, hopefully other vins will fill in around it and solve the mystery.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is offline   Reply With Quote
Old 12-09-2020, 11:51 PM   #111
Pro299
Junior Member
My 72 C10:
2A150583
3/72
Pro299 is offline   Reply With Quote
Old 12-10-2020, 12:33 AM   #112
402Bowtie
402Bowtie's Avatar
72 chevy; 2F368889; most likely 5/72
70 chevy; 0Z167860; 6/70
Old 12-10-2020, 01:51 AM   #113
402Bowtie
402Bowtie's Avatar
The first Baltimore (and non-Fremont) build sheet I've seen...
72 chevy; 2B151900; 4/11/72
And a 70 chevy; 0J106770; 10/69
And a 67 chevy; 7Z155862; 5/18/67
And a 68 GMC; ZB18911; 3/25/68
Old 12-10-2020, 10:42 AM   #114
geunther
geunther's Avatar
Nice work! Now, where was the Baltimore build sheet found in the truck. No reason (other than there is a B in my VIN.
Old 12-10-2020, 01:50 PM   #115
402Bowtie
402Bowtie's Avatar
This one evidently had two build sheets.
72 chevy; 2Z128188; 12/10/71...or at least 12/1x/71
First build sheet shown attached in this post. See following post for 2nd build sheet.
Old 12-10-2020, 01:51 PM   #116
402Bowtie
402Bowtie's Avatar
2nd build sheet for same truck in post 115.
Old 12-10-2020, 06:11 PM   #117
geunther
geunther's Avatar
1972 2z118425 11-71
Old 12-10-2020, 06:21 PM   #118
geunther
geunther's Avatar
1970 0a116484 12/69
1970 0s120860 10/69
Old 12-10-2020, 07:19 PM   #119
402Bowtie
402Bowtie's Avatar
Originally Posted by 57taskforce View Post
I’m not sure how the blazer/jimmy and suburban/panels will factor into this yet. I fear that because they weren’t coming off the pickup assembly lines it may skew the pickup accuracy? Maybe I’m in left field? It might be best to have a similar list of them going in their individual sections? Anyone have thoughts on this?
I added your GMC short K10 ptjsk.
Very helpful. I added the Jimmy to post 2 but could not see the numbers well enough from the build sheet on the short step side. I am sure we will settle on one list (post 1 or post 2)but for now we are ironing out the bugs. Like 57taskforce said, adding Jimmys/Blazers might confuse things somewhat.
I'll add my 2 cents...
I think the blazers and suburbans should be mixed in with the other serial numbers (and maybe noted in parentheses as you have been doing). It appears to me that every model was mixed together as it came down the assembly line. Any proof otherwise?
You guys are doing a great job compiling and laying out the info, but I'm going to nitpick a little (it's the engineer in me):
-Fremont is spelled with only one "e."
-Under each year and make, I think we should keep the list sorted purely by serial number, not by date. ie. Don't intermix 2F1 with 2F3. Sorting by serial number I think will make it easier to look up our build dates in the future when our list is bigger.
Regardless, I'll be looking for more data points to add!
Old 12-10-2020, 08:26 PM   #120
57taskforce
All about them K’s
I can look into those things, no problem. Geunther and myself elected to continue to add the blazer/suburban’s for now to see how it all plays out. If the need arises in the future we will address it then. I will look into the 2F1vs2f3, I agree it might make things easier especially as more trucks come in. With as much leg work as you’re doing you deserve the right to nitpick
Tyler
Old 12-10-2020, 08:35 PM   #121
geunther
geunther's Avatar
Without a secondary sort feature we have to sort by date or by VIN but not both obviously. With it being a build date project, I would be more inclined to have the date sort have priority. Other wise you would have two sets of dates for Flint for 71 and 72. I am not saying that is a bad idea. I think we will continue to learn more about the pattern and hope to identify why they jumped to 2F3 then back to 2F1.
Of course we could just utilize 2 sorts for Flint? I am sure we are yet to identify all the anomalies.
Old 12-10-2020, 09:18 PM   #122
402Bowtie
402Bowtie's Avatar
70 chevy; 0S142568; 1/70
72 chevy; 2Z147088; 3/72
Old 12-11-2020, 12:37 AM   #123
402Bowtie
402Bowtie's Avatar
71 chevy; 1J623881; 2/71
Old 12-11-2020, 01:46 PM   #124
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Here's some information. Blue font is useful, black is gibberish:
If you haven't already you might add 1972 Z161544 with a build date 04/19/1972. He posted it in 2013, fairly well preserved build sheet too - gave me something to work with. I went through this to attempt to confirm my well ventilated 72 Super Z146839 was built in Mar. though perhaps Feb. using the most conservative dates & numbers available. I'm only assuming the factory didn't skip sequences.
Between March 24, 1972 and April 19, 1972 there were 7351 Z Chevy's built. That's the low end, divided by 27 days instead of 26, but a solid guide. That's 272 trucks per day and 8236 per month.
Between April 19, 1972 and sometime later in April (Mystery April Date, "MAD") there were 2502 Z Chevy's built.
If it's assumed MAD is the last day in April, then 9853 Z Chevys were built between March 24,1972 & April 30, 1972. That's on the low-end because I must be MAD, I mean the MAD is April 30th.
Using the number 9853, that's 259 trucks per day or 7908 trucks a month for the period. Strictly a guess, personally I think this is somewhat misleading, not sure why I went here EDIT: Irony, I now see that Z164046 has a 04/28/72 build date. That was a Friday and 259 pencils out after all.
Using the 03/24/1972 date (Z154193) for my 72 Super (Z146839) there's a difference of 7354 trucks. If March 1st is assumed through 03/24/72, then at 259 (minimum) trucks per day that's 6216 trucks. Bummer, still 1K short. If 272 trucks per day is used then still short 800.
That said my sticker is faded, just at that corner too, go figure. But a magnifying glass says "/72" and I'm mostly sure the month is "3". It's so faded it could be gone next month. In my edgeucated opinion (90/10+) Z146839 is March 1972, though if you add it asterisk at your discretion.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 12-11-2020, 02:33 PM   #125
geunther
geunther's Avatar
Fun with math no doubt.
I looked at two of the closest dates available with a decent spread: (3-24) Z154193 and (4-28) Z163961. That is either 34 or 36 days (34 if you consider Z154193 was built at the end of the day and Z163961 was built at the beginning of the day). Using those numbers, the average is 287 trucks a day. 287 x 24 (March 1 to Mach 24) = 6888 trucks. Backing up from 3-24, the earliest for March would be Z147305.
Certainly Z146839 was built in either February or March. I'll add an asterisk, ? for the month and a note. Ill bet we can make better estimates soon.
