Old 04-06-2012, 03:39 PM   #1226
76C10Stepside
76C10Stepside's Avatar
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
Originally Posted by Frizzle Fry View Post
Also picked up my color matched paint and other supplies. Got some POR-20 to try out on the header too. Anyone use it?
As usual, you've done a very inspiring job on the newest fabrication!
Why POR-20 on the header? Weren't you touting high-temp power coating the other day? ;-}
76C10Stepside is offline   Reply With Quote
Old 04-06-2012, 04:14 PM   #1227
Frizzle Fry
Frizzle Fry's Avatar
Nope. If anything I would ceramic coat it, which requires much higher temps and more capacity than my oven offers. Or pay $300 to have it done professionaly; which is why the POR-20 is worth a shot IMO.
Frizzle Fry is offline   Reply With Quote
Old 04-06-2012, 04:24 PM   #1228
smbrouss70
smbrouss70's Avatar
My dad used the POR-20 on his stock maifolds on his 67 GTO, and says he will never use anything else again. He did clean and media blast them real good before he put it on and applied 3 coats, and it hasn't started to change colors or burn off yet. After seeing how nice it still looks, I'll be using it on my Corvette manifolds. I woud assume it woud work on headers too, as long as you blast them so that they have a good "bite" for the paint.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 04-06-2012, 05:09 PM   #1229
Frizzle Fry
Glad to hear it. I understand the metal needs some "bite" (blasted). Also read it helps to preheat the part if possible, then bake at ~300 for an hour to partially cure (maybe between coats?). Apparently it will stay a bit tacky until it gets hot enough to fully cure.
Old 04-06-2012, 05:37 PM   #1230
smbrouss70
smbrouss70's Avatar
Yeah, my dad did tell me that, but he just bolted his on and used the exhaust heat to cure it.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 04-06-2012, 10:16 PM   #1231
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
How are you going to control the heat coming through the floorboard by the seat? Double the floor with an airgap between them?
low'n slow is offline   Reply With Quote
Old 04-06-2012, 10:30 PM   #1232
Frizzle Fry
The floor is being raised enough there to accommodate a decent gap. The muffler itself is a Flowmaster DBX, which is supposed to have very low external heat. Combine that with the wave terminator/resonator right behind the header and we should be good. May do some under-hood-type insulation there and the trans tunnel.
Old 04-06-2012, 10:40 PM   #1233
68 TT
Still plays with trucks
68 TT's Avatar
Sounds like a good product. 1400 degrees should hold up on headers if you don't go too lean.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 04-06-2012, 11:50 PM   #1234
76C10Stepside
The POR-20 sounds great. Hope your passenger has enough footroom down there.
Old 04-07-2012, 01:21 AM   #1235
Frizzle Fry
Yeh, Maybach is not worried...
Old 04-15-2012, 05:29 PM   #1236
Jvsapp
Jvsapp's Avatar
when you blast it, use aluminum oxide, and when you take the part out of the oven, use gloves(nitrile etc) so you don't contaminate it with oil before you coat it. just make sure you blow the dust off after you take it from the blast cabinet. i have a set of headers with that on it on a weld, but never tried it. i'm sure you could let it air dry then bolt it on and run it to make it cook on.
Jvsapp is offline   Reply With Quote
Old 04-15-2012, 11:28 PM   #1237
thor
thor's Avatar
Need to make some changes to accommodate the wave termination box:
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 04-17-2012, 12:13 PM   #1238
Frizzle Fry
Cool. I use garnet. Any reason to believe alox would be better?
Originally Posted by thor View Post
Been workin long hours at the "real job." Right now it's 12hr days x 6 days/wk.
Nonetheless, I have worked some shop time in here and there. Did some serious degreasing/cleaning of the undercarriage. It's amazing how well a nice coat of oily-dirt-grime preserves metal.
Working on hanging the muffler now. Then I'll connect the dots...
Old 04-17-2012, 04:27 PM   #1239
76C10Stepside
I doubt it. Softer and not as sharp as garnet. Maybe cheaper...
These days it's either a) work you to death for too little pay or b) out of work, and very little else. Whatever happened to honest wages for an honest days work?
Poor man's undercoating!
Let's see some more photos of the whole car in its current state!
Old 04-17-2012, 05:37 PM   #1240
ERASER5
ERASER5's Avatar
Muffler bearings or the "O" pipe muffler?
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 04-17-2012, 10:16 PM   #1241
mcbassin
Still Learning
mcbassin's Avatar
Pictures??
mcbassin is offline   Reply With Quote
Old 04-27-2012, 06:41 PM   #1242
Jvsapp
Jvsapp's Avatar
sorry for the late reply..... been a little busy... it cuts really fast and leaves a good "bite" for them coating. i use it mainly because it's faster but does eat my gun tips fast.
also the directions from columbia coatings say this for using with ceramic coatings
Degrease Part Before Sandblasting! DO NOT BLAST PART WITH GREASE OR OIL ON IT
Sandblast with Black Oxide or Aluminum Oxide. DO NOT USE GLASS BEAD (leaves silicate contaminates)
Blow off excess blasting dust with Clean Dry Air
Preheat part at 400 Degrees for 30 Minutes to eliminate any contaminates missed by sandblasting.
Remove Part from Oven and inspect for defects such as "oil bleed out." Handle only with clean gloves.
Apply ceramic coating with an airbrush or detail touch up gun or similar equipment, with fine spray pattern.
actually that's not true..... it's more expensive, sharper, and harder....
http://www.optaminerals.com/Abrasive...num-Oxide.html
"Aluminum oxide is the second-hardest mineral after diamond.
Opta Minerals makes brown aluminum oxide produced by fusing bauxite and anthracite in an electric arc furnace at high temperature.
The resulting oxide is over 95% Al203. Its high density and angular sharpness make it one of the fastest, most versatile and economical cutting abrasives available, usable in both dry and wet blasting applications from cleaning and deburring to etching and finishing."
http://www.optaminerals.com/Abrasive...-Cleaning.html
"Garnet, derived from mined Almandite and Andradite mineral deposits, is a semi-precious stone. Once extracted, it is processed and then screened to the desired grade.
The combination of the high density and physical properties make Garnet nature’s most highly efficient, effective and safe abrasive for both wet and dry blasting applications."
Old 05-01-2012, 01:09 AM   #1243
Frizzle Fry
I know man. The rich are getting richer and the middle class is disappearing. Don't get me started. These 6x12 weeks are killing this project. I can only look forward to coming out the other end with a few extra bucks.
Whatever works
Here you go:
I'll have to get me some!
Here's the latest. Spent a few few hours out there on Sat. working on the exhaust.
The floor boards were covered with the rubber sealer:
Cleaned up and more of the kick-up to clear the exhaust tuckage:
Underside:
Tubes:
Up and over:
More tweaking:
Muffler tucked up into it's spot:
Old 05-01-2012, 01:47 AM   #1244
65Pickup
65Pickup's Avatar
Looks good, nice to have you back at it. Building vicariously on 67-72 trucks is very affordable.
65Pickup is offline   Reply With Quote
Old 05-01-2012, 03:07 AM   #1245
76C10Stepside
Oh, yeah, I forgot it's the raw mineral, not the metal! Duh. Didn't know it was near-diamond hard though!
Old 05-01-2012, 07:46 AM   #1246
Jvsapp
Jvsapp's Avatar
looking good FF. did you have to hammer that piece of original floor to make the bend?
me either. i knew it was hard, and cuts fast, but i didn't realize it was that hard. i changed out my blaster gun and using glass bead now(yes i know my post above says to not use it, but that's for the ceramic coating. gonna try with regular powder to see what happens.) amazing what a "quality" gun compared to a standard cheap gun will do. the glass bead cuts almost as fast as the aluminum oxide now. i'm scared to put the aluminum oxide back into my cabinet now. but the glass bead doesn't tear up my tips as fast so i'll stick to it for now. i paid $60 for the new gun, but now i need a bigger feed tube and hose to match. once i get those i'm sure it'll be really nice. maybe i'll try the walnut shell i got that didnt' really work years ago.
Old 05-01-2012, 09:35 AM   #1247
Frizzle Fry
Ok, that's enough. Start a thread about it!
Old 05-01-2012, 09:43 AM   #1248
Jvsapp
Jvsapp's Avatar
LOL! good to see that you're back on the ball
Old 05-01-2012, 12:55 PM   #1249
thor
thor's Avatar
Love the tucked exhaust! Now you are ready for a flat belly pan, perhaps with longitudinal "fins" to direct air so the car doesn't get wiggly at speed.
Old 05-01-2012, 01:00 PM   #1250
watahyahknow
watahyahknow's Avatar
i agree that most of us blue collar workers work way too hard for the money we get compared to the asskissers that are sitting upstairs in the office doing the "important" work keeping their chairs warm and their phones occupied , but i wouldnt want to trade with their job as i dont like the smell of ****
i actually got some good news for myself today i have been offered a year long workcontract with an option for longer the pay isnt awesome but its steady income every month and its eazy work
i seen a funny cartoon a while back of people of all colour and rishes walking along a street with baloons over their heads showing their monthly income and debt , the guy sitting on the sidewalk begging for money had the most income left after his montly debts where payed off
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
