Old 09-09-2023, 01:00 AM   #1226
SkinnyG
SkinnyG's Avatar
Re: SkinnyG's '61 Apache
'07 van pedal arrived for my '07 van PCM. Just need to put the van pedal guts in the truck pedal I have.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 09-10-2023, 01:52 AM   #1227
SkinnyG
SkinnyG's Avatar
Van pedal guts made no difference. It was just like the '08 van pedal I already have.
I had to repin the pedal so that it had two 0-5V sensors instead of one 0-5 and one 5-0 in order to get it to work.
Drove around the block, and it dropped carrier again.
Just now ordered a TAC module from Rock Auto. Their GM TAC for the van is ONLY for the van, whereas the part number the local GM dealership told me was the same for everything BUT vans. Frustrating that the "Pros" who have all the info at their fingertips and should know better can still steer me wrong.
I'll let you know when it gets here.
Old 09-11-2023, 01:23 PM   #1228
350TacoZilla
I'm asking this because I genuinely don't know but would a cable style throttle body fix your issues or just cause more ?
350TacoZilla is offline   Reply With Quote
Old 09-11-2023, 01:56 PM   #1229
SCOTI
SCOTI's Avatar
That would require an earlier GM computer/ECU & additional changes vs. sorting through what he has.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-11-2023, 06:53 PM   #1230
SkinnyG
SkinnyG's Avatar
The van PCM that I have has the ability to run either cable or DBW. If I go cable, I need to go back in and make changes. It would also make cruise control more difficult.
I am sure I can make it work, it's just figuring what's wrong.
I have two TAC modules #12590008, and GM quoted me the same part at $450, non-returnable.
The VAN uses #12590009. $135 from Rock Auto, GM part. Might be here Thursday.
Old 09-12-2023, 12:35 AM   #1231
SkinnyG
SkinnyG's Avatar
And, for motivation:
Old 09-12-2023, 09:09 AM   #1232
SCOTI
SCOTI's Avatar
Ahh..... I thought everything was DBW after '05.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-12-2023, 10:09 AM   #1233
SkinnyG
SkinnyG's Avatar
The P59 in the Express van has the chips to do either.
In fact, most of the wiring in the '07 van looks "pre-05."
Old 09-12-2023, 11:57 AM   #1234
SCOTI
SCOTI's Avatar
Good to know.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-13-2023, 11:12 AM   #1235
SkinnyG
SkinnyG's Avatar
Dad passed away this morning. I was by his side.
He never got to ride in the truck, the flagship of my abilities so far.
Old 09-13-2023, 11:48 AM   #1236
realvc
realvc's Avatar
Sorry to learn of your loss, praying for you and your family. God Bless you all.
Vince
Galatians 6:14
62 SWB stepside, 94 Wrangler, 99 Z71, 99 vette
My Project http://67-72chevytrucks.com/vboard/s...d.php?t=719086
"If it's too loud, you're too old"
realvc is offline   Reply With Quote
Old 09-13-2023, 12:04 PM   #1237
SCOTI
SCOTI's Avatar
Condolences on your loss.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-13-2023, 12:38 PM   #1238
Braunschweiger
My condolences on your loss.
Your father will have been proud of you.
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
Old 09-15-2023, 04:59 AM   #1239
350TacoZilla
Sorry for your loss man.
Old 09-16-2023, 11:42 PM   #1240
SkinnyG
SkinnyG's Avatar
The 2007 Express Van TAC module arrived. I had to re-pin the van like a truck to make it work, but it did not drop carrier. Well, there was an issue with some aggressive throttle, where it popped a P0068 code which turned out to be the computer was seeing a lot more air than it was expecting, and went "nope!" I added 15% to the Calculated Airmass and that went away.
Took it for a decent drive around town. I didn't see much boost, but did get some blow-off-valve flutter which is cool. The datalog shows the computer is pulling a lot of timing at higher throttle. I suspect this is part of the Torque Management and Traction Control. Since there is no Traction Control, I zero'd the TCS Method table. and we'll have a go tomorrow.
Lots of leaks I need to fix.
Old 09-17-2023, 08:50 PM   #1241
SkinnyG
SkinnyG's Avatar
Added one-way check valves to the PCV system so boost doesn't puke past all the seals.
And having still more quality control issues with the LS A/C Adapter I bought off Amazon.
Old 09-18-2023, 11:29 PM   #1242
SkinnyG
SkinnyG's Avatar
Took the truck to deal with some items in dad's condo. Dump run, mostly. LOTS of thumbs up; the truck really stands out.
Cool having 4psi boost at half throttle. And giggles with the "choo-choo-choo-choo" of the blow off valve.
I owe y'all some video....
Old 09-20-2023, 01:18 AM   #1243
350TacoZilla
Good to hear that something is going right for you man. If you don't mind next time you snap pics can you get one of it aired up? just pure curiosity on my part for what it's peak ride height would be.
Old 09-20-2023, 10:16 AM   #1244
SkinnyG
SkinnyG's Avatar
This pic is ride height. Crossmember 5" off the ground:
Old 09-20-2023, 01:12 PM   #1245
350TacoZilla
Looks great man. I'm sure you get a ton of smiles in that thing. Being a GMC guy I always liked the dual headlight front end on these.
Old 09-28-2023, 09:47 AM   #1246
88Stanger
88Stanger's Avatar
Damn Skinny, i am so sorry for your loss. I just read about it. This hits me extra hard in that I am in the same sorta situation. My dad raised me on hot rodding, how to build them and repair them. He is currently in Mobile Alabama, i am in Washington State (a bit of difference) and as you may have read i have a 1940 Chevy Coupe i actually got from Alabama, shipped it here and wanted to build a tribute to him with it. He is very sick with a lung issue that will eventually take him home to Heaven and he cannot travel. He is always asking about the car. He will never take a real ride in it, and i know this, BUT my hope is to get it running good and then Facetime him, take him for a ride that way in it. Anyways, i am sorry for rambling.... Love your ride. Prayers for you and your family...
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 09-28-2023, 10:36 AM   #1247
SkinnyG
SkinnyG's Avatar
Thanks, man.
Dad's passing wasn't really unexpected, but you're never really ready for it when it happens.
Old 10-01-2023, 02:38 AM   #1248
SkinnyG
SkinnyG's Avatar
This just in:
I think I have successfully scaled the tune for a better spark table at 14psi boost. I'm not at 14psi of boost yet. Yet.
Also,
The AAW headlight switch cannot feed four Hella H4's. That took some finding.
Also,
Somehow I or AAW themselves (probably me) wired the "Front Light Plug" wrong. I had to re-pin the front light wiring in order to get high and low beams to work correctly.
Also,
The cheap fuse/relay block I had bought had decided to disconnect with the fuel pump relay. In the dark. With headlight problems. Luckily I could walk home and jumper the relay and get it home to fix it.
Old 10-01-2023, 11:28 AM   #1249
SkinnyG
SkinnyG's Avatar
Old 10-01-2023, 03:02 PM   #1250
realvc
realvc's Avatar
Very cool video for sure.
Back years ago I worked at a restoration shop where we had done a complete resoration on a 1956 Chevy BelAir. The idiot light for the generator glowed dimly all the time. The generator was charging like it should.
After checking and rechecking everything I found two wires at the fuse block were in the wrong location, after switching those wires around everything was fine. I just knew it could not be a problem with new wiring harness, but it was.
Vince
Galatians 6:14
