01-28-2010, 11:07 AM | #1251 |
Re: Glock's new project: "Fred" w/ 5.3L LS swap info
As we find more info I add it to the LS thread in my signature.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
01-28-2010, 11:13 AM | #1252 |
Next project: 1970 K10
Excellent. I'm in the middle of putting together a spreadsheet of part numbers that I used, and any others that are relevant that I come across, in hopes of coming up with a list of minimum parts needed to do a swap.
Your thread is killer BTW!!!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 01-28-2010 at 11:16 AM. |
01-28-2010, 11:21 AM | #1253 |
right on! that is a good article. i'm going through it now
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
01-28-2010, 11:38 AM | #1254 |
Future: 86 on GenIV power!
Gee another expensive part i need to buy........
01-28-2010, 11:43 AM | #1255 |
Working on another one now. Don't know if it should be added to that one or on its own.
I am trying to put together a GM parts list for connectors and pins for all the harness connectors in case anyone wants to build their own harness or repair broken connectors. Its turning out to be a daunting task. All I have info for is a 2005 5.3 and I only have 80% of the connector pictures? Accelerator pedal position sensor Connector Part Information • 15318071 • 10-Way F Metri-Pack 150 Series (GY) Pin Wire Color Circuit No. Function A GY 1273 Low Reference B PU 1272 Low Reference C L-BU 1162 APP Sensor 2 Signal D TN 1274 5-Volt Reference E BN 1271 Low Reference F D-BU 1161 APP Sensor 1 Signal G WH/BK 1164 5-Volt Reference H -- -- Not Used J YE/BK 1275 5-Volt Reference K D-GN 1163 APP Sensor 3 Signal
01-28-2010, 12:07 PM | #1256 |
Looks like you probably have what I have?
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
01-28-2010, 12:17 PM | #1257 |
Very similar but I saved yours anyway. Might be easier to just use your links in my thread also.
I didn't look but does yours have the transmission connectors, oil pressure, and the engine harness to coils connectors? Those weren't included in what I had and I had to find them. If you don't have those I can forward them to you in an email. Mine are in a less user friendly format.
01-28-2010, 12:29 PM | #1258 |
It has:
Transmission: AT Inline 20-way connector. If I remember right, this was on he P/S of the trans Park/Neutral Position Switch Range Position Switch VSS Oil Pressure: Engine Oil Pressure (EOP) Sensor Engine Harness to Coils: Ignition Coils (1,3,5,7 cylinders) Ignition Coils (2,4,6,8 cylinders) Ignition Coil 1 Ignition Coil 2 and so on, all 8 listed individually
01-28-2010, 12:52 PM | #1259 |
Just to give you all an idea of what I am doing for part numbers.
I might go through and note part you will need for sure, and what are optional. Instead of an overall list of what out there, I'm doing something more along the line of a minimum list of what you will want/need to do a swap into a square body, and might tweak it for a 67-72 also. It's not complete, this is just where I am at right now.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 01-28-2010 at 12:52 PM. |
01-28-2010, 12:56 PM | #1260 |
The info I have has a few more connectors including the flex fuel injector connectors, trans shift solonoids etc. It is about 2MB if you are interested in it PM me an email address
01-28-2010, 12:58 PM | #1261 |
My screenname, plus @aim.com
Thanks!
01-28-2010, 01:03 PM | #1262 |
Sent, let me know if you recieve it and can open it
01-28-2010, 01:14 PM | #1263 |
Got 'em, and I can open them. Thanks again!
01-28-2010, 01:25 PM | #1264 |
I have car A.D.D.
Wow, great info. That is even pretty clear to me and we all know that I am not the mechanical genius in the group. Good job!!
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. Last edited by Driveway Dreams; 01-28-2010 at 01:26 PM. |
01-28-2010, 02:52 PM | #1265 |
very cool! i dont think you can make it any easier Bob... short of traveling state to state and doing the installs yourself
01-28-2010, 02:55 PM | #1266 |
Excellent Idea!!!!!!
CHEVY ONLY |
01-28-2010, 04:13 PM | #1267 |
Formerly- 1972SuperCheyenne
Thats what I was thinking. Come to North Carolina first please.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
01-28-2010, 06:10 PM | #1268 | |
-Don- '66 C10 w/factory A/C '77 Cheyenne K5 350/465/205 '80 Custom Deluxe K20 350/465/205 '04 Denali XL '05 DMax CCLB 4x Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf |
01-28-2010, 06:54 PM | #1269 | |
Sweeeet post!! thanks!!! now what to buy first..... |
01-28-2010, 06:58 PM | #1270 |
yeah and stop by Ok for a week or two on the way
CHEVY ONLY |
01-28-2010, 07:07 PM | #1271 |
I have car A.D.D.
A week or two...isn't that a little excessive for Super Bob? 2 days max on the next one!
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
01-28-2010, 07:09 PM | #1272 |
true
CHEVY ONLY |
01-28-2010, 10:13 PM | #1273 |
yes bob,, that was one of the evap plug/sensor I was talking about, I am wanted to be sure I could take it off my harnesss,.. but the plug I have no idea if I need is this..hopefully this time the pics will show.. I tried re sizing them but cant
01-28-2010, 10:20 PM | #1274 |
also how the do you guys make them pics small... thats like the smallest I can make them?
01-28-2010, 10:52 PM | #1275 |
those pics are about the perfect size
CHEVY ONLY |
