Closed Thread
Old 09-18-2012, 12:41 AM   #1251
sickred72
Smile Re: What Did You Do With Your Truck Today ?
WOW! looks alot better than the chrome mods, just my opinion
sickred72 is offline
Old 09-18-2012, 02:08 AM   #1252
tttuba
That's what I thought too
tttuba is offline
Old 09-18-2012, 10:26 AM   #1253
mknittle
mknittle's Avatar
Originally Posted by tttuba View Post
put the original wheels back on my truck. not the final colors just wanted to see what original style wheels look like on the truck. Thinking i will keep them there.
Those would look good with the stock style hubcaps
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline
Old 09-18-2012, 11:06 AM   #1254
pvienneau
pvienneau's Avatar
Got 95% of the scale and rust off the frame. 49 4 speed is completely disasembled we are ready to begin painting the frame. Any suggestions and or how tos welcomed. This board has been awesome during my project.
pvienneau is offline
Old 09-18-2012, 05:33 PM   #1255
tttuba
I have a set of like new Chevy ones and know where to get new GMC ones. Just a matter of money just like anything else here. I am going to get the original caps though
tttuba is offline
Old 09-18-2012, 05:45 PM   #1256
crossfire84
crossfire84's Avatar
Made shock mounts and welded them on, and had the tool and die end of shop turn me up some stainless blinker and tilt arms.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline
Old 09-18-2012, 07:01 PM   #1257
la hi
Removed the windshield, wire brushed the channels, primered the windshield area, primered the dash and front top inside metal. Now I will not have to sand with a new windshield in place. Will have it installed tomorow.
la hi is offline
Old 09-18-2012, 07:22 PM   #1258
arturo7
arturo7's Avatar
Started cleaning the disassembled front end pieces in preparation for a de-rusting bath. Holy kerschnockers, this stuff is filthy! Comet and a scrub brush ain't gonna cut it.
Is there anything, like an engine degunker, that I can spray and on, let sit, then pressure wash off?
EDIT: Just did some googling. Looks like I need Wax & Grease Remover, right?
ever forward
build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542073
arturo7 is offline
Old 09-18-2012, 08:43 PM   #1259
mknittle
mknittle's Avatar
thats for paint prep go to walmart and get some ourple power it works as good as the chevron industral detergentwe use.
Mark
My GMC build.
mknittle is offline
Old 09-18-2012, 09:52 PM   #1260
mknittle
mknittle's Avatar
sorry, purple power. it's about $20 a gallon. a paint scrapper{ I get the ones with a point on one side and a radius on the other} works good to get the thick stuff off. get the thick stuff off first then degreaser.
Mark
My GMC build.
mknittle is offline
Old 09-18-2012, 11:26 PM   #1261
OrrieG
OrrieG's Avatar
Simple green cut 50 percent, wire brush, scrapers and elbow grease. Usually need to power wash a couple times. It's a lot nicer to the critters and environment too.
OrrieG is offline
Old 09-19-2012, 07:29 PM   #1262
crossfire84
started to fab up my exhaust to day.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 09-19-2012, 08:33 PM   #1263
mknittle
mknittle's Avatar
I started to work out my clutch linkage.
Mark
My GMC build.
mknittle is offline
Old 09-19-2012, 08:59 PM   #1264
lazerstrouts
Test fit my new 22 inch steelies on both trucks. Decided they make them look like crop sprayers and will need major lowering and fender widening.
lazerstrouts is offline
Old 09-19-2012, 09:20 PM   #1265
hotrod1
56 - autocross
hotrod1's Avatar
22" steelies? Where did u get those? Like to see pics.
hotrod1 is offline
Old 09-19-2012, 10:14 PM   #1266
lazerstrouts
contacted a guy on craigslist about a set of 22 inch tires for my wifes 02 suburban, when i went to look at them he had another set still mounted on black 6 lug steelies. i told him i would give him the asking price for the ones already mounted rather then the ones advertised. they are 22x9, looks likethey have 2009 or new gm tire pressure sensors. i painted them with ppg spectraflame/ hotwheels antifreeze green.
the black 48 gmc truck is on a 2000 4wd chevy tahoe chassis and drivetrain. the grey chop top 49 gmc is all original except the top. 48 wouldnt set all the way down due to fender, 49 is sitting on the ground but rust build up around the base of the hub( or 3 inch center bore is too smal) prevented the wheel mounting flush agianst the drum and studs are too short for a spacer small spacer that would make it roadworthy.
Old 09-19-2012, 10:18 PM   #1267
hotrod1
56 - autocross
hotrod1's Avatar
those are beautiful and I really like that color.
hotrod1 is offline
Old 09-20-2012, 07:24 PM   #1268
oldcouple
oldcouple's Avatar
Mocking up my door panels so everything fits.
Retired and too busy to work.
oldcouple is offline
Old 09-20-2012, 07:56 PM   #1269
mknittle
mknittle's Avatar
looking good
Mark
My GMC build.
mknittle is offline
Old 09-20-2012, 07:57 PM   #1270
mknittle
mknittle's Avatar
You wouldn't beleive me if I told you.
Mark
My GMC build.
mknittle is offline
Old 09-20-2012, 08:13 PM   #1271
mknittle
mknittle's Avatar
Ok i made fake bead rolls for my toeboard patch. I don't have a good way to roll the flat bottom beads so i made some out of 1/8" flat stock. they will be plug welded from the inside and i will use seam sealer to blend and seal them.
Mark
My GMC build.
mknittle is offline
Old 09-20-2012, 08:23 PM   #1272
oldcouple
oldcouple's Avatar
Thumbs up Re: What Did You Do With Your Truck Today ?
Details details.
Old 09-20-2012, 09:03 PM   #1273
mknittle
mknittle's Avatar
Details details.
Yeah, I know what you mean, i drive my wife crazy constantly messing with stuff she had to know what she was getting into when we met I had a house full of jeep parts
Mark
My GMC build.
mknittle is offline
Old 09-21-2012, 01:19 AM   #1274
arturo7
arturo7's Avatar
More homework.
The truck is about an hour away at my buddy's shop. It will be there until the heavy lifting in done. At present, I can only work on it on Saturdays. However, I can obsess over it whenever I choose.
The upside of this obsessing is that I'm spending quite a bit of time reading, pondering and planning. The scope of the project has expanded significantly. But oddly enough, the budget has not.
ever forward
arturo7 is offline
Old 09-22-2012, 09:09 AM   #1275
Johnny49
Final refinishing of the bed wood has begun! Left pic is where we started. Right pic is the underside. Bottom pic is the underside (which will now be the top side) after about an hour of pressure washing and a good belt sanding. The wood was then bleached, repairs made and now the final finishing has begun. Several coats and lots of sanding to be done, but we're getting there! I will post a before/during/after montage when it's all done. It won't be perfect, but it WILL look a hell of a lot better and have a little character. Not trying to have a show truck, just one that reflects a labor of love...
Johnny49 is offline
Closed Thread
