07-05-2020, 05:06 PM | #1301 | |
BlahBlahBlah
Re: What did you do to your truck today.The 3rd chapter
07-05-2020, 10:06 PM | #1302 |
Pulled my truck out of the shop and gave her a quick wash. Cleaned up her spot good and then made the leap and took the first step in disc brake conversion. I have all the front steering and suspension removed. All that remains is the upper and lower A arms on both sides. Ran out of gas and called it a day.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2020 Toyota CH-R 2020 Acura MDX Last edited by 67C10Step; 07-06-2020 at 11:10 AM. Reason: Add photo |
07-06-2020, 10:38 AM | #1303 |
Finally finished rebuilding seat and recovering. Now the refurbished interior is nearing completion. Just need to finish trimming carpet, install seat belts, door panels, head unit, and steering wheel.
Reclaimed R12 refrigerant so I could disassemble a/c system enough to remove core support for rust repair (battery area) and repaint. Temporarily buttoned a/c system back up so I could evacuate to keep moisture out and re-use filter/drier. Going to change expansion valve while I have it opened up (evaporator flooding issues). No, I am not doing a BMW engine swap! Last edited by Davidf; 07-06-2020 at 10:51 AM. |
07-06-2020, 11:02 AM | #1304 | |
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
07-06-2020, 12:37 PM | #1305 | |
I polished the trim myself. Call me cheap and crafty but I used a variable electric speed drill with a locking trigger button. I put the drill upside down with the trigger in the up position in my bench vice and used the cheapo Harbor Freight cotton buffing wheels. I started by taking some 1000 grit wet finishing sanding paper for taking down any fine scratches/blemishes. The trim is all stainless steel and being careful when polishing is pretty forgiving. Being careful to not bend, keep your hands close together on the section you are polishing and keep moving to avoid heat build up when buffing. Hope this helps everyone out. |
07-06-2020, 12:43 PM | #1306 |
[QUOTE=Davidf;8769647]Finally finished rebuilding seat and recovering. Now the refurbished interior is nearing completion. Just need to finish trimming carpet, install seat belts, door panels, head unit, and steering wheel.
Thats looks great Davidf ! I'm on this same pathway Sam |
07-06-2020, 01:02 PM | #1307 | |
I've got my list of items to get, just ordered some Moog cross shaft kits and new from springs from Rockauto. Will get my conversion kit on order in a week or so. Got lots of cleaning to do before it goes back together.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2020 Toyota CH-R 2020 Acura MDX |
07-06-2020, 01:11 PM | #1308 |
laying low
Bill I may have missed it but are you lowering it at this time or going back with stock suspension?
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
07-06-2020, 01:27 PM | #1309 | |
07-06-2020, 02:36 PM | #1310 | |
Lowered it 4" in the rear and plan on 2-1/2" drop spindles in the front. I did the shock relocate in the rear and adjustable trac bar but wanted to keep front steering and suspension geometry which could use standard length shocks. I didn't want any radical lowering, just enough to make the stance lower and level.
07-06-2020, 02:49 PM | #1311 |
laying low
Ah ok. It should drive nice with that setup.
07-06-2020, 07:09 PM | #1312 |
[quote=samkost;8769701]Thanks Sam...let’s see some photos!
07-06-2020, 07:39 PM | #1313 |
Getting closer Davidf !
I still need to upholster the bench with the Black with Orange and Black Houndstooth cover, DynaMat , Carpet, door panels and install the 3 point belts. |
07-06-2020, 11:37 PM | #1314 |
Chillin with the shop dog.
DON'T BUILD IT IF YOUR NOT GONA DRIVE IT!! |
07-06-2020, 11:41 PM | #1315 |
Cute.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
07-07-2020, 04:33 AM | #1316 |
70+ ( Old Skool Club )
Writing this at 02:30. I drove mine to work tonight so when I see it waiting for me in the morning it'll make me smile after doing six 12 hour night shifts in a row and now can enjoy her the next few days.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
07-07-2020, 07:05 PM | #1317 |
Made some covers for the side of my seat. Think I'll do a bead roll around the outside of the holes.
07-08-2020, 05:10 PM | #1318 |
Started the cowl gutter. Was going to shave it but decided against it . More pics to follow on the gutter channel. I made a die from wood and made the hump area so far the rest is just bending and using the metal stretcher and shrinker.
07-08-2020, 07:58 PM | #1319 |
Proprietor of Dale's Corner
Looks great! Very nice truck
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
07-08-2020, 08:08 PM | #1320 |
Mine looked like that when I started. I found some very bad rust that was hidden under the cowl panel that I couldn't see until I removed it. I'm glad I went the extra mile and removed the cowl or I would have had water issues after all of that hard work.
07-09-2020, 09:42 AM | #1321 |
Got home late after a trip to power plant in east AR so all I did was unbox my new front springs and remove the upper passenger side A arm. Got the cross shaft ends loose on the bottom A arm so I can now take the U bolts off and drop the arm. It was hot, I was tired, and called it a day.
My new cross shafts should be here today. Ordered those and the new springs from RockAuto. New parts on the work bench motivates me. Even though these are weeks, possibly months from installation.
07-09-2020, 11:13 AM | #1322 | |
Mod Thread Dorman 13503 U Bolts
07-09-2020, 11:41 AM | #1323 | |
07-09-2020, 06:58 PM | #1324 |
Welded up the gutter. While I was cutting out the rot I used the borescope to look inside the cowl actually real clean . The prior owner had put screening on the cowl cover so there was nothing in there . But they never cleaned the gutter . Was packed with dirt and pine needles when I got it.
Spent the day cutting fitting and welding couple of spots look bad but they are solid just rusty. A little more grinding and sanding ,a little filler and some seam sealer and I'm calling it done
07-11-2020, 02:44 PM | #1325 |
Long story short I recently removed a ton of paint off the evaporator housing. 20-25 minutes oven cleaner, followed by 5 hours of patience and lacquer thinner. Ecstatic they're in great shape for just polish. I have a general cleaning to do yet, and they'll see a fiberglass polish I hope to see as the ticket.
More than that the painter took my cab, cowl & hood today, and dropped off this bed and tailgate.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 07-11-2020 at 08:37 PM. Reason: Clarification |
