Old 02-02-2010, 06:07 PM   #1351
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: Glock's new project: "Fred" w/ 5.3L LS swap info
I'm not a fan of running that much solid rubber line. You could, and I am at the moment, but I will be replacing it with SS braided line from the F/R to the engine real soon. That's just too much rubber line bouncing around that could get a hole rubbed in it. I have the line from the F/R to the engine covered in split loom, and wrapped in heat tape where it passes over the exhaust. It's one of the things I did that I don't like and will be redoing very soon.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 02-02-2010, 06:11 PM   #1352
soule64
soule64's Avatar
Originally Posted by Oilbrnr View Post
While we are talking fuel delivery, how does the EP-381 pump mate to the sending unit, both for fuel and power?
The base of the sending unit holds the inlet end of the pump in place. Fuel hose attaches the outlet of the pump to the outlet of the sending unit. The wiring is plug and play to the sending unit.
soule64 is offline   Reply With Quote
Old 02-02-2010, 06:13 PM   #1353
Butcherboy
Butcherboy's Avatar
Bob,( And everyone here) thanks for posting that fuel line info. I was going to ask you how it was done on Fred. Very helpful links, should be able to adapt it on my blazer fuel system.
Thanks again, You where right! I spend too much time on here now!
Justin
Butcherboy is offline   Reply With Quote
Old 02-02-2010, 07:05 PM   #1354
fpjr0
fpjr0's Avatar
thanks for answering some many questions Bob, I dont mine paying some $$$ for the stuff , but just trying to get away from that many fittings,,
fpjr0 is offline   Reply With Quote
Old 02-02-2010, 07:14 PM   #1355
Butcherboy
Butcherboy's Avatar
Question Re: Glock's new project: "Fred" w/ 5.3L LS swap info
Soule, What fuel pump is that? Very nice setup, looks factory!
Justin
Old 02-02-2010, 07:16 PM   #1356
Butcherboy
Butcherboy's Avatar
Whoops! I missed it! EP-381 pump. Is that GM part or aftermarket? Sorry for stupid questions!
Old 02-02-2010, 07:44 PM   #1357
Oilbrnr
Oilbrnr's Avatar
Go look at the pdf file on post #1259 in this thread.
-Don-
'66 C10 w/factory A/C
'77 Cheyenne K5 350/465/205
'80 Custom Deluxe K20 350/465/205
'04 Denali XL
'05 DMax CCLB 4x
Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf
Oilbrnr is offline   Reply With Quote
Old 02-02-2010, 07:49 PM   #1358
Oilbrnr
Oilbrnr's Avatar
Is that just the FI hose and FI clamps that attach the pump to the sender then?
-Don-
'04 Denali XL
'05 DMax CCLB 4x
Old 02-02-2010, 08:57 PM   #1359
fpjr0
fpjr0's Avatar
you are right on the bouncing around with the possibility to get a hole rubbed in it....ok I decided on the Russell 640850 fitting from the rail into a 6 an male adapter , to a 6an braided hose, then at the end of the braided hose I am going to put another Russell 640850 adapter and then the double bead line x 12 that you cut in half... I am going to not cut it and put one end into the russell adapter and the other into the filter/reg.. hope it works lol,, as said before hard to tell since I dont have all the parts in hand
Old 02-03-2010, 09:47 AM   #1360
soule64
soule64's Avatar
The bottom of the sending unit is like a 'cup' that is slightly larger than the pump itself. It has a hole in it for the inlet end of the pump to draw fuel through. The pump sits in the cup and the section of hose with clamps holds everything in place. If memory serves me correctly, I used a zip-tieacross the pumpt, too. The clamps I used are incorrect and will be replaced.
Old 02-03-2010, 12:36 PM   #1361
glock35ipsc
Great pic, thanks for posting that!
Bob
Old 02-04-2010, 10:18 AM   #1362
glock35ipsc
SONOFA
No dyno time today, it's snowing. Only about an inch on the ground, but wet tires and a dripping under carriage = "no dyno for you!!!!"
Bob
Old 02-04-2010, 10:30 AM   #1363
menace121978
menace121978's Avatar
Bob that sucks big time... maybe tomorrow?
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 02-04-2010, 10:32 AM   #1364
glock35ipsc
Probably not until next Tuesday at the earliest.
Bob
Old 02-04-2010, 10:35 AM   #1365
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Man that sucks. I was watching the weather last night and was hoping it would hold off until late tonight. Hopefully next week will be nice for ya.
--Josh
Old 02-04-2010, 12:23 PM   #1366
glock35ipsc
Soooooo, Dave, my dyno guy just called. It wouldn't have mattered if it was 60° and sunny out, it still wouldn't have happened today.
Seems as though he had a slight mishap skiing over the weekend, and broke his face! He just got home yesterday from surgery to have his cheek and jaw put back where they belong! So we'll try again next week, according to him.
Bob
Old 02-04-2010, 12:26 PM   #1367
silvereagle07
silvereagle07's Avatar
That had to hurt.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 02-04-2010, 01:01 PM   #1368
STOCKISH
STOCKISH's Avatar
I laughed at "broke his face" Hopefully soon my friend.
--Josh
Old 02-04-2010, 03:10 PM   #1369
Butcherboy
Butcherboy's Avatar
Yikes! That's a tough break! Hope the guy recovers fine. Bob, I just printed your build/parts list PDF file! Thanks for putting that up for us guys!
Justin
Old 02-04-2010, 10:33 PM   #1370
rongstad
Future: 86 on GenIV power!
Originally Posted by fpjr0 View Post
thanks.... rongstand I see you are in san antonio also..,, any chance you let me see that truck..I like how Bob did his, I am just gonna order everything he ordered. lol and go from there
nice, good luck ordering pieces, some of the quick release fittings are on back order-two weeks or so....my truck is in several pieces I'm waiting for my re-worked harness and complete painless 87 harness before I dare to turn wrenches...
Rongstand - Thanks for posting those links! I didn't see that you had posted until I had posted.
your welcome......just tryin to spread the wealth as I learn.....
rongstad is offline   Reply With Quote
Old 02-05-2010, 09:05 PM   #1371
fpjr0
fpjr0's Avatar
[QUOTE=rongstad;3780638]nice, good luck ordering pieces, some of the quick release fittings are on back order-two weeks or so....my truck is in several pieces I'm waiting for my re-worked harness and complete painless 87 harness before I dare to turn wrenches...
thats cool ;man. I did get all the fittings.. the hard go get one from the vette filter to the 6 an line I found it locally,here in sa..,
bob you could always send your truck south to tx and me and rongstad could take it to the dyno and then maybe just maybe send it back to you....
Old 02-05-2010, 09:25 PM   #1372
lownfast
Gettinlow & Goinfast
Bob,
do you know where to get the threaded inserts that mount the throttle cable bracket to the intake??
my intake was originally dbw but i have gone with a cable tb and two of the the three inserts are missing, i can post a pic if needed, thanks.
eric
Protouring Texas built rides-
78' K5 bodied on 22's, 5.3/ 4L60E- sold-Bdydrptk5- http://67-72chevytrucks.com/vboard/s...d.php?t=358390
71' Chevelle #Bigbootyjudy 6.0 LSx, LS9 heads, Magnuson, T56 - http://ls1tech.com/forums/conversion...e-ly6-t56.html
70' Chevelle #EvilAnnie Lsx/4L80/S475 turbo-
85' C20 crew, 5.3/6L90/S475 turbo-
68' C10 5.3/4L60/Level 2 coil overs
Facebook- Protouringtexasdotcom
Instagram- @Protouringtexas
lownfast is offline   Reply With Quote
Old 02-07-2010, 01:24 PM   #1373
glock35ipsc
Eric - See if you have a Fastenal store near you, they do for sure. But any fastener supply store will have them, our ACE Hardware here has them. They are 1/4"-20 thread.
Bob
Old 02-07-2010, 02:10 PM   #1374
fpjr0
fpjr0's Avatar
when I bought my 5.3 it was missing the fans,,, the yard told me to come and choose what ever fan I want to from the fan room, the fans are all label, what do you guys recommend I take? the originals, or could I pick some from like a f body ?
Old 02-07-2010, 05:21 PM   #1375
glock35ipsc
If you are looking at electric fans, the original ones are too wide. I heard F-body fans will work thought. Can't confirm this however, I'm using the OEM clutch fan.
Bob
