Old 08-31-2017, 01:54 PM   #1351
knomadd
knomadd's Avatar
Re: How to: Ruin a perfectly good C10
Originally Posted by gringoloco View Post
...Or just break out the xacto blade and testors glue...
They are just really big models, right? Looks like some nice parts!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 08-31-2017, 03:13 PM   #1352
SCOTI
SCOTI's Avatar
They sure are. Much heavier & expensive though.....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-01-2017, 12:24 AM   #1353
gringoloco
A guy with a truck
gringoloco's Avatar
The parts laid out like that remind me of pieces on a PVC tree. Some kids never grow up, we just grow older. If mom and dad only knew what they were getting us into
Don't forget more durable, and useable, and um, yeah... I'm out of good reasons for spending all of this time and money on this old thing...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 09-01-2017, 12:36 AM   #1354
gringoloco
A guy with a truck
gringoloco's Avatar
More mild progress as I trimmed the width of the 'rails to fit the notches. Still some more trimming to go before they are ready to drill, but man do they look sweet! ~4 more inches of drop from my already pretty extreme 8" static drop ought to do nicely
-Chris
Old 09-01-2017, 01:11 AM   #1355
SCOTI
SCOTI's Avatar
Uhmm..... Fun.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-01-2017, 07:37 AM   #1356
mcbassin
Still Learning
mcbassin's Avatar
Looks great Chris!
mcbassin is offline   Reply With Quote
Old 09-01-2017, 09:29 AM   #1357
smbrouss70
smbrouss70's Avatar
I like it!
Since you have the tape measure out, what is the measurement from the top of the notch to the top of the original frame rail?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 09-01-2017, 07:40 PM   #1358
gringoloco
A guy with a truck
gringoloco's Avatar
Uhmm..... Fun.
Oh, yeah, that!
Originally Posted by mcbassin View Post
Looks great Chris!
Thanks buddy!
Originally Posted by smbrouss70 View Post
I like it!
Should be about 6", I'll verify
-Chris
Old 09-01-2017, 07:52 PM   #1359
gringoloco
A guy with a truck
gringoloco's Avatar
Yup, about 6 3/16" right now, which should be closer to 6" once it's all snugged down. This is the 'touring' notch; the 'extreme' is a few inches taller, but I'm not sure by how much.
-Chris
Old 09-01-2017, 11:15 PM   #1360
smbrouss70
smbrouss70's Avatar
That would be about perfect for my other truck since I've already raised the bed floor 6.5".
The frame under it turned out not like I wanted it to, so I really want to start over on that one once the Blazer is finished.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 09-02-2017, 10:33 AM   #1361
gringoloco
A guy with a truck
gringoloco's Avatar
Would even leave you a little room for air fittings How's that Blazer coming along?
-Chris
Old 09-02-2017, 12:53 PM   #1362
smbrouss70
smbrouss70's Avatar
There won't be air fittings on the truck when I am done with it. Hell, it may not even have a solid rear axle.
The Blazer is fighting me every step of the way. Of course, I'm trying to make sure everything is PERFECT, like you do, so some things I've had to do multiple times before I was happy with it. I have conceded to the fact that I will get the air ride and Accuair done before Cruisin' the Coast, but will have to hold off on getting the rear axle narrowed until this winter. That means no 20" gassers until then. It'll still look good with the 17" slots for now though.
On another note, I have a Kore3 brake setup F/R for a 2nd gen Camaro (GM TS 14" hybrid front and 10/12 bolt 13" Z51 rear) that is just laying around. You used a GM TS setup from Kore3 and bolted it up directly to a C10 LD spindle correct? If so, I may replace my drop spindles and the Blazer get bigger brakes when the 20's go on this winter.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 09-02-2017, 09:18 PM   #1363
gringoloco
A guy with a truck
gringoloco's Avatar
Intrigued! Where is the build thread?
...I'm trying to make sure everything is PERFECT, like you do, so some things I've had to do multiple times before I was happy with it...
No perfection here, just creative photography I used to strive for perfection, but it's too stressful of a pursuit. I also don't share many of my failures or how long some of these things actually take...
I did use a tall spindle kit, but made for an impala to get the 5x5 pattern. I used LD Belltech 73-87 spindles. Yours sounds like it should work well, but I'd shoot Tobin a quick email to confirm. You'll likely need new brackets for the truck axle out back, but otherwise, I think, good to go.
-Chris
Old 09-02-2017, 09:29 PM   #1364
gringoloco
A guy with a truck
gringoloco's Avatar
Speaking of things that take longer than intended, I got the framerails trimmed for final notch fit, then primed/painted the bare metal and proceeded to drill a BOATLOAD of 7/16" holes to attach the radius notches and bridge. I used an old trick of dropping a 1/4" nut in the holes to center my pilot--worked out great!
Looks like not a lot of progress, but it's all final installed and torqued, and fits like butta. It's time now to remove the offending sections of framerail getting in the way of super-static lowness
-Chris
Old 09-02-2017, 09:32 PM   #1365
builtbyKane
builtbyKane's Avatar
Never thought of doing that while drilling. Excellent.
builtbyKane is offline   Reply With Quote
Old 09-02-2017, 09:46 PM   #1366
smbrouss70
smbrouss70's Avatar
Those notches look great in there, I love watching your builds come together. You seem way more organized than me.
No build thread, I haven't touched it since I got the Blazer, except to move it around the shop. I'm seriously contemplating using a C6 manual trans-axle with one of Dobbertin Performance's cradles when I get back on the truck.
It's amazing how long a simple task takes when you can only spend a couple of hours a night working on it... Oh yeah, my photography skills suck, that's why I haven't been posting on my thread, plus nobody wants to see pictures of me cussing at things that don't fit right or bolts/nuts that strip out!
I did use a tall spindle kit, but made for an impala to get the 5x5 pattern. I used LD Belltech 73-87 spindles. Yours sounds like it should work well, but I'd shoot Tobin a quick email to confirm. You'll likely need new brackets for the truck axle, but otherwise, I think, good to go.
I already have the 5 x 4.75 BC on the Blazer, and I might as well narrow the 8.5" 10-bolt that is in the other truck since it already has a brand new 3.73 Posi setup in it.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 09-03-2017, 10:06 AM   #1367
gringoloco
A guy with a truck
gringoloco's Avatar
Feel free to use it; pretty sure it's a trick I learned here somewhere. I think when I saw it, they were using it to center punch, but ain't nobody got time fo' dat
Thanks, they do look awesome! I just clean up before I snap pics
Solid plan, I think your brake kit will bolt up with no issues if you're using a car axle. I envy your blazer. Immensely.
-Chris
Old 09-03-2017, 10:38 AM   #1368
cooperhw
cooperhw's Avatar
sweet
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 09-03-2017, 09:17 PM   #1369
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by cooperhw View Post
sweet
Thanks! I'm really liking the quality and ease of installation of these porterbuilt pieces, plus they just look BA!
Took the plunge today and removed a big ol' chunk of framerail Time to figure out fuel tank mounting, fuel/brake line plumbing, and hang the axle.
-Chris
Old 09-04-2017, 10:22 PM   #1370
gringoloco
A guy with a truck
gringoloco's Avatar
Hung the TAXM, then slung the axle back underneath. She's square and centered at ride height and almost ready to re-meet mother earth.
-Chris
Old 09-04-2017, 10:26 PM   #1371
gringoloco
A guy with a truck
gringoloco's Avatar
I like these two pics at mock-up ride height. The axle now resides where the framerails used to--she's gonna be low
-Chris
Old 09-04-2017, 10:29 PM   #1372
smbrouss70
smbrouss70's Avatar
Looks good!
I like the fact that you still have the hitch bolted up!
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 09-04-2017, 10:39 PM   #1373
gringoloco
A guy with a truck
gringoloco's Avatar
Looks good!
Thanks, I needed a rear crossmember; the PB tubular is $100--this one is already paid for . Probably too low to actually tow anything--maybe it will help protect the tank
-Chris
Old 09-05-2017, 10:58 AM   #1374
knomadd
knomadd's Avatar
just turn the drop hitch upside down, then it would be a raised hitch... Looks good though!
-Duane
Old 09-05-2017, 11:38 AM   #1375
Bennett68C10
Bennett68C10's Avatar
Looks awesome Chris, can't wait to see the ride height when's it's back on the ground.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
