#1351 |
Re: What did you do to your truck today part III
What does £131.00 buy you from WASP Performance?
I am very happy tonight. These have put a silly grin my face just thinking of them fitted. ![]() ![]() Need to still get and build the 2.5" pipe work and get some 3" flanges to step down to the 2.5" from the 3" cutouts. Did I mention Anti Social Thuggery?
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
#1352 |
I finished up my intake manifold replacement and serpentine belt conversion.
BEFORE ![]() ![]() AFTER ![]() ![]() |
#1353 | |
Where did you get them from? I need a set to make the Hornet more friendly for my Pint Sized Passengers! Hooligan
The Green Hornet 1960 Apache 10 Long Fleet - Driver and Work In Progress The Death Star 2006 Vstar 1100 - Chopped, Bobbed, Riding the Dark Side |
#1354 |
Registered Truck Offender
Welp,,, does 'on the trucks motor' count.
Taking the truck back to street and building a nice little pump gas hydraulic roller 383 for it. Has been a year since I pulled the big bullet out (in frustration) and took me 3 months to set up the valve springs (from those for the big solid roller in the 434 to these for this little hydraulic). Was just hard to retire the truck from racing I guess so took MONTHS to do a 4 hour job. but progress,, finally. should have the motor buttoned up this weekend, then get the truck back over here and start pulling the electronics and build a street friendly TH400 ![]()
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
#1355 | |
![]() ![]() Join Date: Jul 2002
Where did you get the deep fan shroud from? Nice setup. Eventually my 64 will have it too.
#1356 |
#1357 | |
![]() Once satisfied the nut is centered, finish by welding the other 2 small holes. I'm planning to post a DIY thread on my website very soon. It will have all the measurements plus some tips. One of the tips is to drill matching holes in the washer and then plug weld the washer in place. The weld will be stronger. Either way will work if the weld is done properly.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. Last edited by Lugnutz65; 08-04-2015 at 09:56 PM. |
#1358 | |
This is great Egineering!! Thank you for sharing.
#1359 |
1961 crewcab
the wife got a new job, so the 63 went from driving only on sat and sun to 7 day a week duty!!
so since I have to drive it every day , I decided to fix that pesky fuel gauge... it has a no folding 73-87 seat in it , so I had to pull the whole seat- I pulled the sender out of a known working truck, and on the walk back to the garage I noticed that the float had gas in it... so I pull the sender out of the 63, gas in the float as well! I tried hooking both senders up, and moving them manually -both worked- so back out to the yard to look for a float... pulled the sender out of the crew cab tank and the float looked nice, I held it under water for a while and no air bubbles. so in it went attached to the og 63 good sender. worked for 4 hours and it was great! no longer the fear of running out!, and then on the ride home it started to sink ![]() so I went another week, but couldn't stand it any more , and pulled the seat again, this time pulling the float out of another "working" truck, this time it has lasted 3 days! so I think I am out of the woods. on a sad note both the "rust free" front fenders are starting to rust ![]()
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
#1360 | |
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST MY BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=611614 |
#1361 |
Installed door vents and glass.
http://67-72chevytrucks.com/vboard/s...d.php?t=605217 |
#1362 |
Got home tonight and my new gearbox mount had arrived from Langeys Rodshop.
The one that was on the truck had perished and fallen apart, so needed replacing. ![]() I was up at 05.00 to get out the house by 06.00 today, had an appointment over in the Barnet area for 08.00 and 09.00 followed by some more visits around that side of London and a pop in to head office to pick up some materials. Fortunately I was able to pop into Real Steel between appointments to pick up some parts for my engine, and some bits for mate Martin. The guys there are just amazingly helpful and patient. ![]() After work I fitted the gearbox mount and got some measurements for the flanges I need mate Darrwn to laser cut in Stainless Steel and mild steel for me that will be welded to thenY pieces and exhaust pipe when I build it. Cereal box engineering at its best. 10mm request was based on what is on the QTP Y pieces, but Darren suggested 5mm will do the job equally well. ![]() Once these are made up they get Tig welded to the stainless Y pieces and the mild steel units to the actual exhaust pipes that needs bending and fitting to the Flowmasters.
#1363 |
#1364 |
i put in my new window regulator on the driver side and and did both doors for the cat gut seals windows work great now accept for a tiny bit of movement in the Divider part lol but i made a post explaining this just a bit ago .. Happy Truckin
#1365 |
Rebuilt. I ordered the rubber seals and the rivet kit from LMC.
#1366 |
#1367 |
![]() Join Date: Feb 2014
Ordered an HEI distributor for the 66 250... Been waiting for several weeks for them to get back in stock.
Saving for intake/carb/headers... Pappyx4!
1962 Chevy C-10 Stepside 383 Stroker, Turbo 400 1966 Chevy C-10 Stepside 250 6Cyl, 3OTT- Daily Driver John 3:16 |
#1368 |
#1369 |
![]() Join Date: Sep 2006
http://www.summitracing.com/search/p...20Distributors You could go with one of these. The only reason I would buy is because Summit really stands behind their product and if they fail they send you another no questions. I bought an Optima battery from them and it failed a little over a year and they sent me a new one because they have a 3 year replacement. I didn't have to send the old battery back. I actually took it down to a place that recycles them and they gave me $8 for it. The last Mallory dist that I bought from failed me from the start. I replaced the Guts with summits kit but yet to reinstall it.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
#1370 | |
I don't disagree with ChevyFleetside I have had awesome service from Summit, definitely one of my favorite vendors. http://store.speedmaster79.com/p-376...stributor.aspx
1962 Chevy C-10 Stepside 383 Stroker, Turbo 400 1966 Chevy C-10 Stepside 250 6Cyl, 3OTT- Daily Driver John 3:16 Last edited by Pappyx3!; 08-06-2015 at 08:51 PM. Reason: Add info |
#1371 |
Moderator
![]() Join Date: Dec 2012
60 bucks? Wow, I'm never buying points again.
#1372 |
Ordered a ps bracket from captainfab454
#1373 |
Not enough pictures too much text. Here is some wiring about to happen.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
#1374 |
#1375 |
Must be wipers
