05-06-2020, 10:06 PM | #1351 |
Re: "Project Orangepeel" 52 A.D
Update:
These next few shots are of the headliner and the trim pieces above the doors for the headliner. First 2 shots are the trim pieces made The 3rd is the headliner after it was prepped for the material. The last 2 are the final look. It was wrapped in suede. Mark
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
05-06-2020, 10:19 PM | #1352 |
Looking good!
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build |
05-06-2020, 11:34 PM | #1353 |
Looks good...Dad
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
05-07-2020, 08:34 AM | #1354 |
Awesome Mark!
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
05-07-2020, 09:03 AM | #1355 |
That interior is beautiful!
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
05-07-2020, 10:45 AM | #1356 |
Just came across this build, been away for awhile. Anyway truck is NICE!!! Love the radiator shroud as well. Also would be interested in the belt sander plans it came out great!! Keep up the good work.
05-07-2020, 10:51 AM | #1357 |
Mark, any pics of the battery install? Im still trying to figure out where to put mine. Planned to but it under the bed floor but space is premium under there.
05-07-2020, 07:16 PM | #1358 |
Thank you everyonefor the compliments!
05-07-2020, 07:22 PM | #1359 |
rollinrooster, speakingof the belt sander...
Pic 1. Primer Pic 2. Synergy green over silver. Pic 3. Sander back together with matte clear. The plans for the sander...are still coming sorry for the delay. Mark
05-07-2020, 07:25 PM | #1360 |
The battery will be housed inside the box in the bed.
This box was from a 29 model A sedan for luggage. And I built a steel box that goes inside and locks. Mark
05-07-2020, 08:54 PM | #1361 |
sueeeeeddde! looks great man!
its a nice update on the sander too, what will be the main usage?
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
05-08-2020, 07:59 AM | #1362 |
The usage of the belt sander is mainly for fabrication
Been wanting one for years,so I decided to just build one. The reason for the paint....because I can Mark
05-08-2020, 09:51 AM | #1363 |
hey reaper, what size of belt did you go with on the sander? looks good, and the width of the belt is wide enough to do some work for sure. nice.
05-08-2020, 10:30 AM | #1364 |
That headliner looks amazing....... thanks for the pics
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
05-08-2020, 07:43 PM | #1365 |
Thanks Guys!
The belt is 2" by 72" a fairly common size for belt sanders Mark.
05-11-2020, 11:15 AM | #1366 |
Ha, definitely won't go missing. Did you base it off plans or just started welding stuff together? What did you use for rollers?
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
05-12-2020, 08:04 AM | #1367 |
The main frame of the sander was based off the design from (Ameribrade) I used there wheels,platen and work table.
Then I modified the upper section as needed for the adjusting. I had No measurements,plans etc. when building this (I just winged it!) The stand was my design so it can be rolled around if needed. Mark
05-26-2020, 10:52 AM | #1368 |
This not an update on my truck, however its some things I wantedto share.
Pic 1. The 55 I worked on awhile back has been gone for several months now. Wanted to show what the metal work looked like. Pic 2. This is Brendans diesel motor that will be going in his 67 truck. The color is a Denali color from GM the truck will be painted the same. Pic 3. Me and my Friend John were working over the weekend on his 48 Ford truck and this is the new flake.
05-26-2020, 10:55 AM | #1369 |
Wow! That really pops.
05-26-2020, 11:57 AM | #1370 |
That flake is wild! My grandma had a '76 Beetle painted similar.
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
05-26-2020, 03:33 PM | #1371 |
wow that looks like a 70s glastron boat flake! really gorgeous!
05-26-2020, 04:39 PM | #1372 |
Russ, I had a '72 Glastron with a 455 Olds in "Root Beer Brown Metallic"...back in my younger wilder days.
05-26-2020, 07:38 PM | #1373 |
Glad you guys liked it.
The interior is going to end up being done in pearl white should really Pop!!
06-10-2020, 04:21 PM | #1374 |
First time back on the ground in quite awhile!
Forgot how low she was !!
06-10-2020, 04:38 PM | #1375 | |
Looks good. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
