Old 10-04-2021, 09:24 PM   #1351
Barnfind46
Barnfind46's Avatar
Re: What did you do to your truck today part IV
I have similar headers on my 68'. I have been very happy with them.
68' with no bells or whistles unless I add'em.
Barnfind46 is offline   Reply With Quote
Old 10-04-2021, 11:21 PM   #1352
Canadian63GMC
Canadian63GMC's Avatar
Sand blasted the cab today in driveway, will put in primer tomorrow, did the bottom of cab and roof a few days ago, messy job!
Canadian63GMC is offline   Reply With Quote
Old 10-05-2021, 03:14 PM   #1353
Barnfind46
Barnfind46's Avatar
Angry Re: What did you do to your truck today part IV
Broke the back glass replacing the rubber. Ordered a new one.
Old 10-05-2021, 09:15 PM   #1354
Chevy Fleetside
Chevy Fleetside's Avatar
I put the toys in the back that I'm going to take to the toy drive this weekend. It's a car show toy drive. Pier 50 San Francisco
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 10-05-2021, 10:20 PM   #1355
Canadian63GMC
Nicely done! Best of both worlds!
Old 10-09-2021, 07:13 PM   #1356
cwcarpenter98
cwcarpenter98's Avatar
Started painting my new wheels today. I've had these for almost 2 years, but was waiting on needing new tires
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 10-09-2021, 07:21 PM   #1357
roll_the_dice
roll_the_dice's Avatar
Looks good Christian...that is patience!
roll_the_dice is offline   Reply With Quote
Old 10-09-2021, 07:29 PM   #1358
cwcarpenter98
Thanks, Andy! I didn't feel like paying to have the tires swapped over to the new wheels when I first got them, so they sat in those boxes on the shelf since
Christian Carpenter
Old 10-12-2021, 12:47 PM   #1359
cwcarpenter98
New tires on. More pics in my build thread
Christian Carpenter
Old 10-12-2021, 01:06 PM   #1360
jmarkha1
Thumbs up Re: What did you do to your truck today part IV
new wheels / tyres and those hub caps look tough
1965 c10 project - how does all this stuff go back together...
jmarkha1 is offline   Reply With Quote
Old 10-12-2021, 09:56 PM   #1361
cwcarpenter98
Thank you! I'm very happy with them so far
Christian Carpenter
Old 10-12-2021, 09:58 PM   #1362
karlbenz
Originally Posted by TJ's Chevy View Post
Installed my wiper delay kit finally!
What wiper delay kit did you use?
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
karlbenz is offline   Reply With Quote
Old 10-13-2021, 11:16 PM   #1363
Canadian63GMC
Cab interior in primer!Name:  5B3858C3-873A-452A-ABD4-81E9A4BE2489.jpg
Old 10-14-2021, 09:27 PM   #1364
Barnfind46
Barnfind46's Avatar
Blasted my wheels and painted them. Got new tires.
Old 10-16-2021, 02:32 PM   #1365
goatless
goatless's Avatar
Installed KYB Gas-A-Justs to try to keep the top of my tires off the fender well. They help some over the standard Monroes, but still touch when in tight corners.
1964 C10 LWB->SWB, 283->454, SM420->200-4R
MECHANIC: "ME"
goatless is offline   Reply With Quote
Old 10-24-2021, 02:54 PM   #1366
blacknwhitedog
Gettin ready to pull the lowered rear leafs and switch over to a nolimit 4 bar.
blacknwhitedog is offline   Reply With Quote
Old 11-07-2021, 09:58 AM   #1367
Pitpig
Have a converted short bed with an LS and a th 400. Had terrible vibration at 70 mph. Shimmed rear 2 degrees down and trans 1 degree up per spicer calculator. Problem solved
Pitpig is offline   Reply With Quote
Old 11-07-2021, 11:58 AM   #1368
forestb
forestb's Avatar
It’s hard when your truck looks so good with that stance to change it at all
forestb is offline   Reply With Quote
Old 11-09-2021, 02:49 AM   #1369
goatless
goatless's Avatar
So true. I have 4" drop springs I can't use because my Monroes couldn't handle them. These KYBs raise the front slightly, unfortunately, and there's still the occasional rub. Might work if I had shorter front wheels.
MECHANIC: "ME"
Old 11-11-2021, 12:53 PM   #1370
pdxhall
pdxhall's Avatar
I put the doors, fenders, cowl, & cowl extensions back on the truck for the last time until final prep and paint. I still have to work on gap alignments on the cowl extensions, cowl, and hood, and I also need to block out the hood.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 11-11-2021, 12:58 PM   #1371
forestb
forestb's Avatar
Vary exciting looks good.
Old 11-11-2021, 06:12 PM   #1372
66x3
Pdx what is your plan for color?
66x3 is offline   Reply With Quote
Old 11-11-2021, 07:49 PM   #1373
roll_the_dice
Greased all of the front end zerk fittings...didn't realize there were so many! Hopefully that will take care of my squeaking front end.
Old 11-11-2021, 07:50 PM   #1374
Barnfind46
Barnfind46's Avatar
Starting on replacing the bed floor. I have a '72 parts truck with a steel floor bed. I am going to cut down the bed floor and adapt it to the stepside . It will be reversable. I will do a wood floor when I build the truck into a hotrod. I just want it usable now on the cheap. I have the parts and the skill and the time just no money for the replacement bed parts right now.
Old 11-11-2021, 07:51 PM   #1375
Canadian63GMC
This looks great, can’t wait till I’m near this state!
