Old 05-17-2011, 10:19 AM   #1376
Stricklinator
Stricklinator's Avatar
Re: ** YOUNG FRANKENSTEIN ** The truck Chevrolet should have built.
Originally Posted by 67HEAVEN View Post
Please. Anything BUT that. There's even a Honda Civic running around here with SS emblems on it.
Pretty soon everything ever built will be a "SS".
LOL, I see "Turbo" emblems once in a while and it it is hilarious!
Paul
1969 C/20, 307, 4-speed, rusty with manual steering and brakes!
Stricklinator is offline   Reply With Quote
Old 05-17-2011, 12:17 PM   #1377
VA72C10
VA72C10
VA72C10's Avatar
Originally Posted by drewskiren View Post
We had quite a ride!
Yes I will be back on the truck tomorrow!
I thought after game 6 you guys were going all the way...
...but glad the truck will no longer be neglected
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 05-18-2011, 12:57 PM   #1378
70truckguy
70truckguy's Avatar
Sorry guys. GO MAVS!!!
Rich
1970 C/10 Step, 383/700R4
http://67-72chevytrucks.com/vboard/s...d.php?t=466601
70truckguy is offline   Reply With Quote
Old 05-24-2011, 11:06 AM   #1379
packrat42
packrat42's Avatar
Any updates?
'72 Nova
'71 C10
'63 VW Beetle
...............................____
.................________-|___\____
..;.;;.:;:;.,;.|__(O)___|____/_(O)|
_______________________________________
packrat42 is offline   Reply With Quote
Old 05-24-2011, 04:44 PM   #1380
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Drew the truck is looking awesome! I had to go back several pages to pick up where I left off. Very nice work as always! I am really thinking about getting a burb lined up so I can build myself a hauler this winter. I want as much cab room as I can get. With that being said, seeing how you have done yours already. Do you think you could cut the burb body at the front of the rear wheel well and then add the truck cab rear portion on there?I'd like to have a lot of cab room if I can.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 05-24-2011, 11:31 PM   #1381
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
Yes you could have a longer cab by doing just that very thing. I personally didn't want any more total length, so I kept it at what the factory would have done.
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 05-24-2011, 11:44 PM   #1382
maynardtruckin
maynardtruckin's Avatar
the ones that were done for special orders like the one they modified to build the truck in your profile pic Drew were tad bit longer. the rear doors were the front doors and were something like 4" or 6" longer. that's just a guess on the measurements but you all get the idea.
Chris
67 c10 swb build in progress
70 c10 lwb driver pending parts for drastic overhaul
70 c20 lwb parts truck for above mentioned drastic overhaul
71 k20 lwb building for off road use and towing
maynardtruckin is offline   Reply With Quote
Old 05-25-2011, 12:10 AM   #1383
drewskiren
drewskiren's Avatar
Yep, I was meaning though if Chevy had designed it and built it on the line they probably would have wrapped the cab corner onto the existing door jamb like I did. Less engineering money to use what they had already designed.
Drew
Old 05-25-2011, 12:25 AM   #1384
drewskiren
drewskiren's Avatar
Ok, something worth posting finally. - Although I'm not quite sure-
Started in on my possible headliner that requires some creative fabrication. I used 3 layers of thin plastic to keep my roof and cab clean. Then I spread out the black fleece - I realize now I should have tried to stretch it tighter. I spread out the fiberglass resin on the fleece , but some areas cured quicker than others and it puckered up in one or two spots. Then I laid on my fiberglass resin again and spread out woven roving type fiberglass mat with more resin on top of that. It seems pretty stiff, I'll have to trim it around the edges and fit it in there. Then cover it with headliner material.
Now that I have done this, I have a different idea so I may not end up with this at all. If I love it great, if not, plan B.
Drew
Old 05-25-2011, 03:13 AM   #1385
Dieselwrencher
Nice work! I know that fiberglass work in big chunks like that can be a real joy!
Ryan
Old 05-25-2011, 09:58 AM   #1386
67cheby
67cheby
67cheby's Avatar
WOW...thats alot of fiberglass !!
67cheby is offline   Reply With Quote
Old 05-25-2011, 10:21 AM   #1387
BlackTopMotors
Too bad you couldn't put the cab on one of those rotating devices, tipping it upside down, working it from the inside.
BlackTopMotors is offline   Reply With Quote
Old 05-25-2011, 12:23 PM   #1388
thor
thor's Avatar
that was my thought too. that way it would fit the inside of the cab perfectly instead of the outside.
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 05-25-2011, 02:46 PM   #1389
Dieselwrencher
The way Drew is doing it is exactly how a lot of street rod guys do it. Once they get the shape they cut it, fit it, and then put it back together. Just think how nice it would be bending over, leaning in to do the fiberglass work because it isn't like you can sit on the inner roof panel to do it while it's upside down.
Ryan
Old 05-26-2011, 12:43 AM   #1390
drewskiren
drewskiren's Avatar
Yes, I am actually going to spray these 4 panels tomorrow. It's about dang time.
Drew
Old 05-26-2011, 01:07 AM   #1391
Dieselwrencher
Looking good!
Ryan
Old 05-26-2011, 11:43 AM   #1392
70truckguy
70truckguy's Avatar
Great, I can't wait to see this project come together. It's gonna look awesome.
Rich
Old 05-26-2011, 04:47 PM   #1393
thor
thor's Avatar
cool man. wasn't picking; just thinking out loud. many ways to skin a cat, er, headliner.
looks great drew. can't wait to see some color!
Old 05-27-2011, 01:18 AM   #1394
drewskiren
drewskiren's Avatar
Well, I did get paint on them. That's about all I can say.
I'll probably end up respraying 3 of the 4 panels shown here. Bummer.
Drew
Old 05-27-2011, 01:55 AM   #1395
VA72C10
VA72C10
VA72C10's Avatar
BUMMER....what's the issue?
Old 05-27-2011, 02:10 AM   #1396
Dieselwrencher
Thor, I didn't mean to come across harsh. I'm sure you could do that other ways.
Drew, that stinks about the paint issue. Was it a reaction or something?
Ryan
Old 05-27-2011, 07:54 AM   #1397
LONG 2B LOW
LONG 2B LOW's Avatar
Been following the build and it's lookin awesome, it keeps me motivated to work on my on my work, keep up the good work and don't feel to bad about the paint, I'm about to repaint my truck for the 3rd time in 3 months.
LONG 2B LOW is offline   Reply With Quote
Old 05-27-2011, 08:48 AM   #1398
drewskiren
drewskiren's Avatar
Runs and trash in the paint. I could wet sand and buff, but each bad area is near a body line and I would probably burn through and have to repaint anyway.
Drew
Old 05-27-2011, 11:20 AM   #1399
thor
thor's Avatar
it was just a couple of warm-up passes. now you're ready for game-speed painting.
Old 05-27-2011, 12:08 PM   #1400
drewskiren
drewskiren's Avatar
I'm going to try and redo it tonight, wish me luck!
Drew
