Old 11-19-2013, 09:42 AM   #1376
gdavis
gdavis's Avatar
Re: 1968
Originally Posted by cubber View Post
That water neck should fit fine, George. As long as the angle is good, you are fine.
I am moving about 40 mi away, closer to church and work, bigger house and bigger shop!
The bigger shop is a plus. one can't have too large of a shop good luck. so far snow is not a issue
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 11-19-2013, 06:53 PM   #1377
gdavis
gdavis's Avatar
Re: 1968
Today was the first time I could spend the day working on my truck. Got to install some parts that I have had stored for months.
installed the new chrome thermostate houseing on the Edelbrock intake
I mounted thealt also
then I installed the new HEI distributor
Then came the valve covers from edelbrock
It is starting to look like a engine now. I hope I can do my distributor wires tomorrow.
Check out Patches
Old 11-19-2013, 07:22 PM   #1378
sduckworth13
sduckworth13's Avatar
Re: 1968
George you do nice clean work, looks great!!
Scott
sduckworth13 is offline   Reply With Quote
Old 11-19-2013, 08:39 PM   #1379
mcbassin
Still Learning
mcbassin's Avatar
Re: 1968
Lots of good progress. Love all the new parts. that powerplant is looking sweet too.
mcbassin is offline   Reply With Quote
Old 11-20-2013, 11:36 AM   #1380
dfwright
dfwright's Avatar
Re: 1968
It's really looking very nice! Excellent work!
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 11-20-2013, 07:19 PM   #1381
gdavis
gdavis's Avatar
Re: 1968
Thanks I do try.
Check out Patches
Old 11-20-2013, 07:21 PM   #1382
gdavis
gdavis's Avatar
Re: 1968
Yea it shows what a few new parts willdo.
Check out Patches
Old 11-20-2013, 07:21 PM   #1383
gdavis
gdavis's Avatar
Re: 1968
thanks.
Check out Patches
Old 11-21-2013, 06:33 PM   #1384
gdavis
gdavis's Avatar
Re: 1968
Today my new carpet came in and is put up untill I need it. I also got the clip for the wind shield wiper arms and the speed o-meter cable. Going to install them tomorrow.
Check out Patches
Old 11-21-2013, 08:28 PM   #1385
Mustard72
Mustard72's Avatar
Re: 1968
Nice progress, George. If you get lost in Illinois on December 1 and end up 5 hours north in Rusk County, look me up.
Nick
Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986
http://67-72chevytrucks.com/vboard/s...d.php?t=545356
Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears
Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck.
Mustard72 is offline   Reply With Quote
Old 11-22-2013, 06:46 PM   #1386
gdavis
gdavis's Avatar
Re: 1968
Stepside rear turn signal lens came in today. Now I have a new set to go back on the truck. I have a major set back today. I have to pull the transmission and replace the flex plate. I was told that the six cly and the 8 cly flex plate was the same. I should have investagated it before jumping into installing it. The starter does not even come close to ingaging the flex plate. But I have learned a lot since I started this build. One thing is don't assume nothing. Now I have about 6 hours worth of work to do. I should get my door panel trim this next week. The dash cluster also.
Check out Patches
Old 11-22-2013, 08:45 PM   #1387
swamp rat
swamp rat's Avatar
Re: 1968
Setbacks seem to be the name of the game with these trucks, i have had and continue to have my share.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-23-2013, 04:19 PM   #1388
cubber
Re: 1968
I know how you feel, George. You will get it sorted, though.
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 11-23-2013, 08:50 PM   #1389
gdavis
gdavis's Avatar
Re: 1968
If it wasn't for de backs I probably would not have anything to do.
Check out Patches
Old 11-23-2013, 08:51 PM   #1390
gdavis
gdavis's Avatar
Re: 1968
Yea I did get it figured out. Replace the flywheel/flex plate
Check out Patches
Old 11-23-2013, 09:02 PM   #1391
gdavis
gdavis's Avatar
Re: 1968
Got somemore parts in today. Heater hose fitting and chrome plugs for the edelbrock intake.
New flex plate. There is a large difference between the two. The six cly is 12 7/8 inches and the v8 350 is 14 1 /4 inches from side to side
I movied the transmission back about 8 to 10 inche. Pulled the old six cly fex plate off the rear of th engine.
Monday I will insall the flex plate and re-install the transmissin.
It sounds a lot harder than it really was. Piece of cake.
Going to install with locktite on the bolts this time. I think I should have done this the first time. Here is the torque specks for the bolts. 60 Lbs on the engine side 6 bolts with star washers and locktite and 46 Lbs on the torque converter side three bolts with locktite.
Check out Patches
Old 11-24-2013, 06:15 PM   #1392
gdavis
gdavis's Avatar
Re: 1968
A cool Sunday so I did not do anything on the truck.
Check out Patches
Old 11-25-2013, 08:01 PM   #1393
gdavis
gdavis's Avatar
Re: 1968
Well today I re-installed the transmission. The transmission never hit the floor. I left the transmission mount attached to the cross member. Removed the ten bolts attaching it to the frame. Jacked up the rear of the motor. Slid the transmission back with a come-a-long. use two pieces of 1/4 all thread and two pieces of short chain. Used them to slide it back in place. It was the easiest transmission I ever pull and replaced the fly wheel.
I also replaced the filter in the transmission. It was the cleanest pan I ever seen. just a little wipe and it was clean.Then replaced the gasket and r-installed the pan.
I see a couple places that I missed with the chevy orange. I will repaint tomorrow.
I recieved two door panel top trim today. All I have to do is polish them up and they will look new again. I will put them up untill I need them. Anothe fine day here in Florida. Got eveything done that I wanted too.
Check out Patches
Old 11-26-2013, 08:05 PM   #1394
gdavis
gdavis's Avatar
Re: 1968
Today I re-painted the transmission pan. I painted a lot of other parts also. I will install the starter tomorrow and test it to see if the fly whell isok.
Check out Patches
Old 11-27-2013, 11:26 AM   #1395
Low Elco
Re: 1968
Gettin' close!
Low Elco is offline   Reply With Quote
Old 11-27-2013, 12:06 PM   #1396
mcbassin
Still Learning
mcbassin's Avatar
Re: 1968
Very nice progress!
Old 11-27-2013, 12:36 PM   #1397
gdavis
gdavis's Avatar
Re: 1968
Originally Posted by Low Elco View Post
Gettin' close!
yea but not close enough
Check out Patches
Old 11-27-2013, 12:37 PM   #1398
gdavis
gdavis's Avatar
Re: 1968
Very nice progress!
thanks a lot and good luck with your build.
Check out Patches
Old 11-27-2013, 07:48 PM   #1399
gdavis
gdavis's Avatar
Re: 1968
Today is the first cold snap we have had this winter. near freezing. and raining so nothing was done on the truck.
Check out Patches
Old 11-28-2013, 10:36 AM   #1400
gdavis
gdavis's Avatar
Re: 1968
Today Is Thursday thanksgiving and I want to give all you a guys a very warm holiday.
Happy Thanksgiving to all.
Check out Patches
