Old 03-22-2011, 09:47 AM   #1451
watahyahknow
watahyahknow's Avatar
Re: 67 cheby's Dropmember build thread
Originally Posted by 67cheby View Post
thanks for the info and support !! here is a little progress from last night , we are reworking the drivers inner fender to round the opening a little better and pull it away from the cab (so if we do make a production run , you wont have to modify the cab) which in turn leave the cab mod i did useless !!! did a little work on the pass side inner fender, Gary and Mark are doing an awesome job at NEX Hotrods !! thanks guys
whell the cabmod isnt totally useless it might help keeping the roadnoise from those innerfenders from reaching the interiour of the truck and it prevent trapping dirt where it can cause rust
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 03-22-2011, 09:58 AM   #1452
67cheby
67cheby
67cheby's Avatar
and it will make a good foot rest or what do the race drivers call it a "dead pedal" and yes i love the look of the system in there with the buddy buckets also, cant wait to get it all fiberglassed and contoured nicely !!
67cheby is offline   Reply With Quote
Old 03-22-2011, 10:12 AM   #1453
67cheby
67cheby
67cheby's Avatar
Originally Posted by es67chevy View Post
hope you can keep moving forward. We need our nw arkansas cruise this year!!!
maybe you can pull mine on a trailer behind yours !!!
Old 03-22-2011, 11:13 AM   #1454
watahyahknow
where you going to tuck the Fiberglas in are you going to hide the edge where the mdf stops now or are you going to go up and over until the bottom pinch weld under the rear window and hide it under the rubber
if you do the last you can make it surround the seats and close the gaps to the rearwall
when go that way you prolly will have to shape it out of styrofoam or greatstuff expandingfoam sprayed ontoo it (cover metal , back of the seats and rearwindow with clingfilm or painterstape so you can pull it off and it doesnt go or stick where it shouldnt go when its ready ) to contour it to the shape of the box back of the seats and rearwhall once its set you can saw file cut and sand the blobs intoo the shape you want before slapping bondo over it sand some more cover it in glassmat sand some more (whell you get my drift ), its kindah like building a surfboard and its faster in getting the bulging contours of the whall and the fitting towarth the seat as it kindah grows against it before setting , if you want to safe some weight or just go fancy you could either hollow out the existing product untill you hit the glassfiber or pull a mothermould of the finished product and use that to rebuild it out of poliester
Old 03-22-2011, 11:36 AM   #1455
67cheby
67cheby
67cheby's Avatar
i want it to look similiar to this one ( if it is someones on the board NICE WORK) this one has been my inspiration !!
Old 03-22-2011, 02:04 PM   #1456
mac72
Funny, I've got that same pic saved,thats some quality work right there.
mac72 is offline   Reply With Quote
Old 03-22-2011, 02:06 PM   #1457
67cheby
67cheby
67cheby's Avatar
yes..i just hope i can do justice with my remake !!
Old 03-22-2011, 03:14 PM   #1458
watahyahknow
that one tucks in at the same spot as youre mdf is now , you might need to shave a little off the mdf to get it to fit with the soaked fleece pulled over it , he mightve made a seperate piece to go to the rearwindow im not sure , it does look verry nice though
to make the fleece that close to the amps top you need to frame those in mdf as whell
if you build a small pictureframe out of thin plywood or plexy or metal to fit flush inside a groove cut in the mdf frame you can make the big mdf frame big enough to clear the connections and still cover the connections on youre amps and still get to it when you take the pictureframe off
you can mount that pictureframe invisible with velcro strips or magnets
Old 03-22-2011, 03:19 PM   #1459
67cheby
67cheby
67cheby's Avatar
mine is going to be a little different the amp cover will be a seperate piece that i can take on and off for wiring
Old 03-22-2011, 08:15 PM   #1460
jwalk
What was I thinking?
jwalk's Avatar
Dude.... looking good!
Justin
'68 C/10 Custom Long wide bed
'78 GMC Sierra short wide
Project: Second time around...'68 short wide
http://67-72chevytrucks.com/vboard/s...d.php?t=423949
jwalk is offline   Reply With Quote
Old 03-22-2011, 11:15 PM   #1461
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I think that is hotrucks stereo.... Your truck will look great I think Id just go and buy clear and shoot it on so i could enjoy it this summer.. Besides who the hell needs paint with a bad ass ride like that..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 03-23-2011, 03:27 PM   #1462
Mt Man Chad
Mt Man Chad's Avatar
Very motivational thread for my 68 SWB...
Thanks!
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 03-23-2011, 03:31 PM   #1463
67cheby
67cheby
67cheby's Avatar
thanks to both of you for your great comments
Old 03-23-2011, 05:41 PM   #1464
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Looking good!!!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 03-23-2011, 05:46 PM   #1465
67cheby
67cheby
67cheby's Avatar
thanks...just plugging away !!
Old 03-24-2011, 04:10 PM   #1466
67cheby
67cheby
67cheby's Avatar
GOOD NEWS GUYS going into production with my front inner fenders stay tuned !!
Old 03-24-2011, 09:32 PM   #1467
kyull67
kyull67's Avatar
what? awesome.
kyull67 is offline   Reply With Quote
Old 03-24-2011, 09:59 PM   #1468
1stchevy
1stchevy's Avatar
That's cool, I think you may just have quite a few buyers from the board.
1stchevy is offline   Reply With Quote
Old 03-24-2011, 10:00 PM   #1469
Nathan28
Nathan28's Avatar
Awsome build!!! I see paint money in your future!
68'chevy swb 350/200r4
71’ chevy swb 6.0/4l80e
Nathan28 is offline   Reply With Quote
Old 03-25-2011, 09:19 AM   #1470
67cheby
67cheby
67cheby's Avatar
thats my hope i hope the headache of building these front inner fenders will reward me with the money to complete this build !! thanks guys
Old 03-25-2011, 11:05 AM   #1471
belowme51
belowme51's Avatar
im in cheby...Ill take the first set!!
belowme51 is offline   Reply With Quote
Old 03-25-2011, 11:06 AM   #1472
belowme51
belowme51's Avatar
it works out..you get some $$ for your truck and I get some bad a** fenders.
Old 03-25-2011, 11:11 AM   #1473
67cheby
67cheby
67cheby's Avatar
You are the first one that has actually said i will take the first set so keep in touch with me and i will try to make that happen !!
Old 03-25-2011, 11:30 AM   #1474
bmfpeterson
bmfpeterson's Avatar
mike I would be interested in some fenders too! ill stay tuned
bmfpeterson is offline   Reply With Quote
Old 03-25-2011, 11:50 AM   #1475
67cheby
67cheby
67cheby's Avatar
thanks guys , when i get a final date set more in me and my Partner will prob set up a group buy for the board !!! and i will become a board vendor before we sell any products
fiberglass inner fenders, pb hood hinges ", w/pb 4 link
