Old 01-25-2007, 10:54 AM   #126
65-72 chevytoys
65-72 chevytoys's Avatar
Re: my official 68 shortstep ls1 thread (lots of pics)
Originally Posted by 68 short step View Post
ok im gonna make this my thread with the build up from here on out...
little progress this weekend...
painted new front suspension, installed brakes, and installed engine/trans.
i had lots of help from both my wife and daughter too
What type of paint did you use on the front suspension? I have been told you need a high temp paint with ceramic because of the heat that builds up in the calipers during braking. Any truth to that and if so what is the best paint to use.
2004 Chevy Silverado 1500LS SWB 5.3L
2004 Corvette Z16 #770
Wish I had not sold 72 blazer
65-72 chevytoys is offline   Reply With Quote
Old 01-25-2007, 11:04 AM   #127
Joe Gribben
Joe Gribben's Avatar
looks like you know what you are doing that thing is looking good ill be watching for more
Joe Gribben is offline   Reply With Quote
Old 01-25-2007, 11:15 AM   #128
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
looks like a good job your doing there...everything looks good.
honestly honey,,i have no idea how that truck got here.
68GMC454 is offline   Reply With Quote
Old 01-25-2007, 08:50 PM   #129
68 short step
Originally Posted by dishow View Post
if you still have the rear rims in this pic would you like to sell them????
i sold those already...
68 short step is offline   Reply With Quote
Old 01-25-2007, 09:04 PM   #130
68 short step
sounds logical.... what i do (and has lasted for over 5 yrs on my firebird) is blast the caliper ( dont touch with bare hand after that), give it a good rince down with acetone, and paint with automotive paint ( this is nason, custom blend color.....kinda a grey gunmetal metallic color) paint it with a few GOOD coats, then wait a few days, clean with a cloth, clear, clear, and clear it... wait a few days then install...
Old 01-28-2007, 10:32 PM   #131
68 short step
got more progress today.... i plumbed up the steam tube.... how i did it in a "hidden" fashion is drilled a hole in the water pump, tapped it, and put a elbow with a -4 AN fitting to the outlet of the steam tube (under the throttle body) heres a picture guide of what i did......
Old 01-29-2007, 12:42 AM   #132
shifty
Questionable
shifty's Avatar
Steam tube looks good. Very similar to what I did on mine. Glad to see someone is getting work done. I finally got my stupid ass fuel pump mounting plate drilled out this weekend after breaking off the bung. Now I gotta find two replacement NPT+barb to AN fittings to replace it.
Two questions for you about your work, which others might find of use later:
That's a nice polished elbow - notice it has a tab on it - is that a kit from somewhere?
Where the heck is your MAF? Or are you tuning out the MAF (which is totally possible to do)?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 01-29-2007, 01:00 AM   #133
mudslinger396
mudslinger396's Avatar
Looking great gunna be a nice truck!
-72 chevy short c/10 396
-70 chevy long c/10 350
-40 chevy coupe 350
-61 chevy impala 350
mudslinger396 is offline   Reply With Quote
Old 01-29-2007, 08:15 PM   #134
68 short step
kennedy off road on the intake assembly (for a 00 1500 truck, if it matters)
http://cgi.ebay.com/ebaymotors/1999-...spagenameZWDVW
the MAF sensor is just behind the air filter (have connection kinda towards the bottom)
Old 02-02-2007, 09:33 AM   #135
hp1967c10
hp1967c10's Avatar
I am curious if your drop spendles are from Early Classic and what spring your using in the front. The tubular control arms look great but from my understanding they are expensive. I have a picture of my 67 when from a few years ago that I will be posting, but I have completely started over with body work etc... I will be interested in your stance once you get it on the ground with body and engine weight. Great job and I will be talking to you.
hp1967c10 is offline   Reply With Quote
Old 02-02-2007, 04:12 PM   #136
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
If you decide you don't like your exhaust, give it to me
How does it sound, or have you fired it yet (I want a sound clip)
Very nice dude
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 02-02-2007, 04:22 PM   #137
shifty
Questionable
shifty's Avatar
You gonna battery relocate to driver's side? There is a stock tray for that.
Old 02-03-2007, 04:39 PM   #138
68 short step
Originally Posted by hp1967c10 View Post
I am curious if your drop spendles are from Early Classic and what spring your using in the front. .
no the spindles are "western" spindles from CPP and a 1" drop spring...
no i havent started it yet , but ill be sure to make a post with vid about it.
you're slipping , look up several pics, its mounted on the frame behind the dr side wheel....
Old 02-04-2007, 09:34 PM   #139
shifty
Questionable
shifty's Avatar
Sorry
Old 03-23-2007, 08:30 PM   #140
68 short step
heres a update...... i got a complete bed from MAR-K with the hidden handle /flush tailgate....also i tried primeing it, but i found out quick that primer doesnt stick to galvaized surfaces to well..... so thats why in the video its primer black (that i tried to wipe off) so now its two tone with some custom acetone streaks....... anywho.... i got the wiring squared away, and had to test it, as seen in video.... first attempt at starting it, it ran like crap then died... looked at my ground points (only 2 places) and they were both just finger tight...so i tightened them and WROOOOOMMMMM... like half a crank and it ran great..... i just put temperary power where needed to start it....
Old 03-23-2007, 10:13 PM   #141
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Sounds pretty good, but it's kinda hard to tell without hearing it in person... Rolls eyes
Sinister
Killer
Old 03-23-2007, 11:02 PM   #142
pcmcobra
pcmcobra's Avatar
sweet.
I'm diggin' your 2 helpers over there in the yellow vette...startem young!
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 03-24-2007, 02:46 AM   #143
ChevyDude
Great progress, lookin gooooood!!!
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 03-24-2007, 11:43 AM   #144
67shortie
Green club
67shortie's Avatar
I'm following this closely, I would love to do this engine swap into mine
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 03-24-2007, 01:24 PM   #145
jorgensensc
jorgensensc's Avatar
Looks awesome!! Just small 2 cents... Please either put it up on jackstands or disconnect your driveshaft.
I recently (November) was almost done restoring a '56 Bel Air. I just dropped it off of the Jackstands and told my 5year old daughter to move out from in front of it. She argued, but finally moved. I reached in and started it up. and it fired up wide open throttle. Before I could turn the key the tranny somehow dropped into gear and nearly ran into my house. I turned the wheel and made it down the driveway, but I was going to hit a the iron gate and the Trailblazer SS on the other side of the gate. I had seconds to react. i had to put the car into a tree on the property line. The tree was 30 ft from the front bumper and the wheels were burning rubber the whole way. Not trying to be a downer, but I would really hate to see you or your little ones get hurt. I immediately went over and hugged my little girl.
shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 03-24-2007, 02:20 PM   #146
shifty
Questionable
shifty's Avatar
Ok, you beat me. I'm jealous
I guess I should bust some ass and work on mine today, since I am so freaking close to finishing it ain't funny (have been for months). Everytime I think about it, I lose motivation though
Old 03-24-2007, 02:27 PM   #147
68 short step
shawn
Old 03-24-2007, 02:33 PM   #148
68 short step
ill add insult to injury too, i broke my feed fitting (like you) and replaced it with a fitting i found at ACE hardware...... this fitting was on the fitting shelf (you know the ones that people get the fittings, and instead of putting it where it belongs they put it on the shelf below) it was only 1.25$, but didnt see another like it..altho i quit looking when i saw it... so shift hurry up and git it going......
Old 03-24-2007, 05:34 PM   #149
watahyahknow
watahyahknow's Avatar
man youre so lucky you had a chance to at least steer the car out of harms way , next time go sit in the car before starting it while loading the brake to make sure nothing happens .
we drive mostly manuals here where learned at the driving school to hold the clutch and the brake and wiggle the gearstick to see if its in neutral before starting
youre lucky you didnt used one a fancy remote startswitch so you can turn the motor while working under the bonnet for valveadjusting and stuff
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 03-24-2007, 06:18 PM   #150
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I have had my blazer drive backwards through a house gotta be carefull.. Nice foundation you have so far..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
