#126 | |
Resident of Here
Re: The Boss Hoss, 72 C/30, 454, DUALLY!
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
#127 |
Nice bracket for the front. I've thought about doing the dually flat bed to mine but I only have a half ton frame and I would have to have a one ton to be happy with it. Grate progress.
Professional hot glue and pop cycle stick engineer. 72 K/20 soon to be C/10, 454, Th400, 9” rear. 01 GMC 2500HD 8.1, Allison, daily/towpig gas guzzler. 78 Bahner 19’ jet boat, 460 Furd turd. |
#128 |
high-Tech Red Neck
Today's progress:
![]() ![]() THE CAB IS BACK ON THE FRAME!!! This makes me very happy, they have been apart for a long long time now. I made a rig on my cherry picker this morning, worked amazingly well for pulling the cab. It can pivot 360* and it picks the cab up with ease. ![]() ![]() I am waiting on my cab mount kit that I ordered from ORD to show up so I can get the cab bolted down, and I need the rear spring pivot bushings that I ordered from ORD as well, when I get those I will be able to get the frame welded up and boxed, then I can start working on getting the Cummins mounted.
"He used to be a pretty nice feller, now he's a welder!" |
#129 |
![]() ![]() Join Date: Jul 2002
Nice to see the Boss coming back together!
#130 |
Resident of Here
She's looking good! Like a truck again!
#131 | |
1968 Chevy C10 6/8 drop ( great grandpas truck) under construction 1972 Ford Bronco project 2006 chevy Silverado 2500hd dd 1995 k2500 solid axles 12v cummins crew cab ![]() |
#132 |
high-Tech Red Neck
Yeah, that is a 51 that I am going through
#133 |
high-Tech Red Neck
Just a small update, I did not get a lot done today, but what I did get done was important.
I found out the parts I ordered from ORD are all on back order, that kind of eats at me, but the good news is that they are going to over nite them to me if they show up on wendsday which means I will have them friday. I also picked up a set of motor mounts for the cummins today, tomorrow I am going to start getting the engine cross member and mounts built. I am playing with different ideas on how to do it, but I think the final design is going to involve a removeable cross member that will allow me to drop the oil pan with ease should I ever need to. Once the mounts are built and welded in, I will get to work getting the frame boxed and getting all of the unessasary holes filled, then I need to also cut the holes for the front axle shackle hangers, once this is done I will get them welded up, drop the engine in, and I will start working on getting the tranny in and hooked up. Then it will be a matter of getting the radiator, intercooler, and boost pipes routed. Then all that will be left is to get it wired and plumbed up, rebuild the tranny as a 4x4, and get the driveshafts built, and it will be a truck that can move under its own power again. I am going to hammer down as hard as I can and try to have it to where it will run by the end of may. I am having a hard time deciding on what color I want to paint it, I am considering a dark royal blue, a metalic brown, and a copper color. We will see which one I wind up picking. Also the more I look at the bed I am building for my friend, the more I like it, and I think I am going to build a similar one for my truck. I was thinking it would be kind of cool to have a 12v fridge in the box.
#134 |
No no no, not metallic brown, brown with gold flake instead of the metallic flakes.
![]() Pm me your address and I'll send you a paint chip off mine so you can color match it.
Professional hot glue and pop cycle stick engineer. 72 K/20 soon to be C/10, 454, Th400, 9” rear. 01 GMC 2500HD 8.1, Allison, daily/towpig gas guzzler. 78 Bahner 19’ jet boat, 460 Furd turd. Last edited by modblacksmith; 03-14-2011 at 10:17 PM. |
#135 | |
high-Tech Red Neck
#136 |
#137 |
high-Tech Red Neck
we will see, right now im leaning towards copper, but if I go brown on the cab I am going to paint the waffle grille orange, the frame orange and the flat bed orange.
If I do the copper the frame and running gear will be black, I will do the grille in a charcol color, and the engine will be black with the valve covers painted red. Well they will be painted red once I know the cummins is making in excess of 460 hp. That way I can have a true red top! ![]()
#138 |
Copper and black would look way cool.
#139 |
high-Tech Red Neck
That is kind of what im thinkin.
Allthough I am still having a hard time deciding what bed to build. With one I get a much larger fuel tank, the other more ability to carry cargo on the bed.
#140 |
One of my old flat beds had custom built saddle tanks behind the tool boxes on the sides and a suburban tank in the rear. It made the side boxes kinda shallow but it was grate for long runs up to the farm. Just an idea.
#141 | |
high-Tech Red Neck
I can carry eveyrthing id need to change an engine short of a cherry picker in the truck pretty much. I want to get a set of tool box drawers and put them in one of the boxes too to keep my tools organized. That would be very nice.
#142 | |
I really dig your truck, have had thoughts of stripping my 84 and putting a 72 cab on it with a flat bed after seeing how well your is turning out.
#143 | |
high-Tech Red Neck
There are lots of the C/30's still out there, you just have to find them. I am really going back and forth on the bed, but at the moment I am thinking about how I will need the bed space, and how I can build a kennel for my dog that can ride back there so he can stay dry and clean on our longer outings instead of having to ride in the cab with me and my girlfriend. Me the girl and the dog in the cab of the truck gets a bit cramped.
#144 |
high-Tech Red Neck
Also the Boss is going to be a tow vehicle, I have decided when I sell my business at the end of the summer I am going to get a late 80's/early 90's Airstream Excella 34' to serve as a temporary home for about a year.
![]() If I do the copper paint theme on the truck, I think I will repaint the strips on the airstream to match like this. ![]()
#145 |
What frame are you using?
Is that the original? |
#146 |
high-Tech Red Neck
yeah original C-30 frame.
#147 |
wow i think you be taking wiiiiide corners for some time after that year long trip
be carefull not to wipe the second lane clear on the offramps that thing will hang its ass out quite a bit
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#148 | |
high-Tech Red Neck
![]() I have about a million miles behind me, that 34' airstream aint even a challenge. ![]()
#149 |
but not with that overhang in the back , i dont think i could drive it in the netherlands to many bends in the road narrow streets and stuff like that
drive a small truck for a while and i had a couple of sweaty hands and squished butcheeks moments in amsterdam doing deliveries
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts Last edited by watahyahknow; 03-15-2011 at 12:11 PM. |
#150 |
high-Tech Red Neck
![]() Yes with the overhang in the back too. The picture above is a model, but I used to pull a trailer like that, it was a tripple axle 53' high cube, the axles were non sliders, the center of the axle set was 34' from the king pin. I had no problem with it what so ever.
