Old 05-15-2009, 04:13 PM   #126
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: Post Your 60-63 Body Style Chevy/GMC Trucks
7.580 @ 89.7 - 1/8 mile is not bad!
How do ya have her set up?
Enigine/Tranny
Front end/Rear End
10.5 Slicks?
Etc.
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 05-15-2009, 05:30 PM   #127
Bears63
...just another truck junkie..
Bears63's Avatar
Here's a couple pics of my '63 C20:
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 05-16-2009, 04:41 AM   #128
Super73
Super73's Avatar
Well its got:
347ci LS1
Forged roatating assembley
Ported factory heads
243/250 @ .050 cam
Thise passes had an LS6 intake with a factory smoothed and ported TB
Had a factory mechanical water pump
Underdrive crank pulley
Manual steering box
Power brakes
4L80E trans
4,900rpm converter
3.73
30" x 14.50 ET Street (going through the traps in second gear with the converter locked aprox 7,100rpm)
Being all steel, the truck weighed in a 3,840 with me in the seat and 1/2 tank of gas.
The front suspension is stock minus the springs and shocks. According to Moroso, I was running a spring that would not work for the weight of my truck. But, according to the leverage ratio and my unsprung weight, I found it to be ummm, perfect Shocks were a Comp Engineering 3-way, but even on the 70/30 setting, there was still a little too much stored energy in the front. I have switched to a Rancho 9,000x.
The rear again is stock other than an adjustable lower control arm braket I made that allows you to move the mounting location, I think there are 5 holes. Also a Classic performance lowering spring, blocks and again a Comp 3-way shock.
Since that outing I have:
Switched to a single plain with a dominator throttle body
Removed the factory bench seat for a set of light weight buckets (50lbs)
Build a new front crossmember that retains the factory control arms (25lbs, but the intake/N20 plate and TB made up the difference)
Cutting off the 30-40lb tow hith I once welded on it
Putting a factory weight tailgate on it (had an extrat junk gate so I added about 100lbs to it)
Just received a 1 piece glass front end (75 lbs vs te 240 the factory stuff weighs)
Put a 4.56 gear in it
Put an electric water pump on it
Pray every night it goes 11.40-11.50 NA in the 1/4 and low 10's on the jug...
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 05-16-2009, 09:49 AM   #129
Chuck78
sounds awesome, I'm very impressed - wish I had some LS1's for my 63 panel and my 71 Camaro...
Chuck in Ohio
*1962 GMC 1000 Panel Truck - 305D/Saginaw 4sp soon: 351C V6 + AX15 5sp OD trans, & 75-87/91 disc brake front end
*1988 Suzuki Samurai 4x4 project, VW 1.9L mTDI, Toyota R151F transmission & Toyota full floater axles, LWB body tub stretch project
*Many 1977-1979 Suzuki GS motorcycles, Kawasaki KDX220R, '77 Suzuki PE250, etc
Chuck78 is offline   Reply With Quote
Old 05-17-2009, 02:36 PM   #130
1Bad62Pro/Street
Talking Re: Post Your 60-63 Body Style Chevy/GMC Trucks
Same here. Kinda glad I have a that 1970 LS9 350ci/355 vette motor in my ole' 62 truck. The block and heads are Nostalgia and kinda rare now.
SPECS:
BLOCK
Casting #
(1969-79)
3970010
350
4 Bolt Main
Vette
370 HP
HEADS
Casting #
3927186
302/327/350
Intake
2.02
Exaust
1.6
Old 06-05-2009, 11:15 PM   #131
1Bad62Pro/Street
Heck Yeah!
ROAST THE TIRES SLAP OFF!
POST'EM IF YA ROAST'EM FELLAS!!!!!
Old 06-06-2009, 12:37 PM   #132
Super73
Super73's Avatar
Something like this? This is my old truck.. Well, half of it any way.. Kept the 63 frame which is what y sheetmetal is riding on right now.
Tires were a litle old and I had a set of BFG drag radials on the way..
Old 06-06-2009, 01:09 PM   #133
TwoFiftyShifter
You always gotta get 'em hot once more before they come off!
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 06-06-2009, 01:36 PM   #134
1Bad62Pro/Street
Exclamation Re: Post Your 60-63 Body Style Chevy/GMC Trucks
Super73......................
THAT'S WHAT I'M TALKING ABOUT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
YOU HAVE GOT IT IN YOUR VEINS TOO.................................................
WE THINK ALIKE!!!!!!!!!!!!
Old 06-06-2009, 01:39 PM   #135
1Bad62Pro/Street
Post Re: Post Your 60-63 Body Style Chevy/GMC Trucks
Delete
Old 06-06-2009, 06:24 PM   #136
scotts62
One day...
scotts62's Avatar
i bet that landing hurt just a bit and not just the truck..
Scott
93 crew cab build
Project 62
Old 06-06-2009, 07:03 PM   #137
61chev1tondually
61chev1tondually's Avatar
i have three old chevs and gmcs. i have a wrecked gmc shortbox(62),a orange stepside shortbox(63) and a blue 1 ton dually chev (61) heres some pics of the blue one and orange one(ill have pics of the dually soon!)
61chev1tondually is offline   Reply With Quote
Old 06-06-2009, 07:11 PM   #138
61chev1tondually
these trucks are like the best old trucks from the sixties
Old 06-06-2009, 11:21 PM   #139
63sbssbbw
UCA63
63sbssbbw's Avatar
Welcome 61,from the other side
Cool stuff
What are your plans for them all?
I heard that you may have gotten some snow today!!
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 06-07-2009, 03:07 PM   #140
1Bad62Pro/Street
Oh yea.......
Maybe tore a new one......ha ha
I'd do it for $20,000 green stamps!!!!!!!!!!!!!
Lord willing I hope to take my dad here the next The Playground of Power.........Father and Son "ON THE BACK BUMPER" Bonding!!!!!!
OCTOBER-Sat 3rd- 2009 World Power Wheel Standing Championships
Check this out:
http://www.outlawracing.com/MESSAGEF...c/Default.aspx
World Power Wheelstanding Championships - $20,000 To Win!
Byron Dragway http://www.byrondragway.com/Home.html is a 1/4 mile dragstrip located in Byron, IL, about 1.5 hours from Chicago. It was originally opened in the 1960s. It was most known for running cars 4 at a time in the past, but this practice has been discontinued. For that reason, Byron is a comparatively wide track. It is currently best know for the World Power Wheel Standing
http://www.byrondragway.com/2009_Byr...y_Schedule.pdf
Old 06-07-2009, 03:12 PM   #141
Super73
Super73's Avatar
The problem I have with that is you are not garuanteed the coin. I have a lot of money in my junk even though it still looks like junk, I'd hate to have to buy things a second time around. Cool to watch though..
Old 06-07-2009, 03:18 PM   #142
scotts62
One day...
scotts62's Avatar
Yeah its more fun to watch someone else tear their stuff up
Scott
93 crew cab build
Project 62
Old 06-07-2009, 03:58 PM   #143
1Bad62Pro/Street
I hear ya buds...........
If had more money than since I'd do it........
I just have a few cents..
So I'll just have fun watching those fellas tuck and roll!!!!!!!!!!!!!!!!!!!!!
Like the Duke Boys always said, "Keep her between the ditches!"
Old 06-07-2009, 10:07 PM   #144
61chev1tondually
hey 63 thanks for the welcome. the blue one i am looking 4 another shortbox chassis (i found one but the guy aint ready to give it up just yet) so it sitting around, and the orange one is my aunties. i plan to hope fully get the blue one done before i graduate from school nxt yr, so i can use it for grad. haha
Old 06-08-2009, 05:24 AM   #145
1Bad62Pro/Street
Keep the Pictures coming guys!
Keep us updated of your progress...........
Old 06-08-2009, 03:00 PM   #146
GruntMoanCough
GruntMoanCough's Avatar
Hi RMH
T
Still waitin' for the snow to melt here..................
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 06-08-2009, 07:43 PM   #147
scotts62
One day...
scotts62's Avatar
^^ Yeah that sucks..
Scott
93 crew cab build
Project 62
Old 06-08-2009, 11:15 PM   #148
65GMCShortStep
65GMCShortStep's Avatar
New here, just bought the truck last Wednesday, haven't really had a chance to do anything yet but here we go.
65GMCShortStep is offline   Reply With Quote
Old 06-09-2009, 10:56 PM   #149
61chev1tondually
hi BC how r ya? all the snow left here 3 days ago(yay!) good luck on your project truck too dude. hope the snow melts soon 4 ya
Old 06-10-2009, 12:30 PM   #150
bobjob
looks like someone forgot there wheelie bars.. a lot of money to end up on your back like a turtle...
bobjob is offline   Reply With Quote
