Old 09-13-2013, 02:04 PM   #126
l79m20
Re: The Green Monster Just an old farm truck
ttt
l79m20 is offline   Reply With Quote
Old 09-14-2013, 08:16 PM   #127
TheBlueBomber
TheBlueBomber's Avatar
Man whenever he gets back I hope there are tons of updates cause this is one awesome build. Saw the vids on youtube before I saw this thread. Great build and its been an inspiration for my k10 and what I want to do with mine.
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
TheBlueBomber is offline   Reply With Quote
Old 10-02-2013, 12:35 PM   #128
TheBlueBomber
found an update!!! messaged 84-400, hopefully we can get him back on here with some juicy details lol
Austin
Old 04-14-2018, 11:40 AM   #129
84 400
Sb 400 club
84 400's Avatar
Wow wow wow... it has been years too long.
A lot has changed in my life but I still have this truck!
Update time!
The truck now has a 1985 6.2 out of a M1028 cucv with 14k original mikes. Since install in 2014, I have put about 15k on it with no issue.
The axles are also now changed. The axles came from a 1986 M1028. So that means a Dana 60 with a limited slip and a 14FF with a Detroit and both 456 gears.
The transmission is still a SM465 but I picked up a ranger Od 3. Still has not been installed.
The truck now rolls on 37 military oz on 12 bolt beadlock wheels.
It is my daily driver. I hope to get pics soon. If you have questions just ask.
Good luck with your projects!!
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 04-15-2018, 05:18 PM   #130
Glad to hear you still have it and seh is going good. Look forward to some pictures.
Old 04-06-2020, 05:31 PM   #131
84 400
Sb 400 club
84 400's Avatar
So MA changes their lift laws...
This state sucks. Truck has been taken off the road and will be registered else where.
Here are some pics tho.
with 39.5 bigger and it's trailer.... Oh and my camper build.
Old 04-06-2020, 06:47 PM   #132
Truck looks really good!
Old 04-21-2021, 01:08 PM   #133
84 400
Sb 400 club
84 400's Avatar
So the day had finally come to tackle the cab rot on the stepside.
Kick panels both sides
Inner and outer roxkers
Cab corners
Floor pans
Front cab mounts.
Plan is to raptor line the floor then mill at then res carpet.
Also plan to repaint the truck back to the old lime green.
Old 07-19-2021, 12:06 PM   #134
84 400
Sb 400 club
84 400's Avatar
So here we go…
To start i needed to get rid of the old wheels and tires and lower the truck down some. Also wanted to free up some cash and sell the old beadlocks and 37’s
Wheels are ford 16x7 acuride steel rims off an e250/350 van. From the pick and pull these were $100 for 4.
Primed and painted with the GM 517 poly lime green the truck will be.
Tires are super swamper TSL SXIi 35/10 r16 bias ply
Balanced with 6 oz of beads per wheel.
1985 C10 LWB Sold
Old 07-19-2021, 12:17 PM   #135
84 400
Sb 400 club
84 400's Avatar
Now its time for the truck to come apart for new fendrrs and doors, cleaning the frame and coating the new cab floor.
Used a grinder , sander and dustless blaster on the pressure washer with playground sand. Wish i had more before pixs but was going quick.
Chassie got two coats of eastwood rust encapsulator and then extreame chassis paint all sprayed from an HVLP
You can see how the bed sagged down in front because of the wood floor rotting out.
An engine hoist is one of the best tools to own…
1985 C10 LWB Sold
Old 07-19-2021, 01:17 PM   #136
84 400
Sb 400 club
84 400's Avatar
This is after needle scale, wire wheel, sandblast and coating with eastwood. This time its all black and no accent colors. Frame will be fluid filmed or bar and chqin oiled before each winter to reduce rust in the future.
The DIY4x shackle flip has held up real well. Eventually i would like to flip it and run 56 inch rear leafs.
1985 C10 LWB Sold
Old 07-19-2021, 02:02 PM   #137
69Tom
69Tom's Avatar
I like the steel wheels. Always liked that color green too.
So I just purchased new fenders for my 74 C20 from tkorinek here on the forum, as he's local. I got the newly tooled ones. They're as heavy duty as OEM fenders. However, with that said, I had a bunch of issues with the driver's side fender. Maybe it's just my truck, but the top part of the fender that meets up with the A-pillar doesn't seem to be stamped correctly. No matter now many shims I used, it just wasn't curved right and I ended up having to bend it outward, which I wasn't happy about. The passenger side fit great, so i'm happy with that one.
Anyway, something to keep in mind. And from what I've read/been told, the "cheaper" reproduction fenders are total junk.
69Tom is offline   Reply With Quote
Old 07-19-2021, 03:30 PM   #138
84 400
Sb 400 club
84 400's Avatar
I used a LMC premium on the drivers side and had an older aftermarket i used on the pass side. The stamping was not as crisp on the premium but it beats the rotted ones i had. Fit was so so. I will work on updating this. The wheels also have dog dish caps so those will be put on soon.
If i had a ton of money i would love to put the right year hood back on it but that cash could be better used replacing the bed floor.
1985 C10 LWB Sold
Old 08-01-2021, 07:59 PM   #139
84 400
Sb 400 club
84 400's Avatar
So with the frame wrapped up i needed to sand prime and paint the body..
No real care was taken to fix the dents. Seam sealer and rust prep wheb beeded. Any filler was minimal.
1985 C10 LWB Sold
Old 08-01-2021, 08:27 PM   #140
84 400
Sb 400 club
84 400's Avatar
2 coats of primer
3 coats of 517 GM green
Nassar fast dry single stage. Should of gone heavier on it and may do a wet coat later
About 1000 pounds of scrap in the back mostly old doors and fenders.
1985 C10 LWB Sold
Old 08-02-2021, 12:58 PM   #141
lunatic1968
I really like the detail on the hood.
lunatic1968 is offline   Reply With Quote
Old 08-10-2021, 08:11 PM   #142
84 400
Sb 400 club
84 400's Avatar
Okay so hauled in the scrap and on to the interior…
1985 C10 LWB Sold
