Old 02-03-2010, 12:25 PM   #126
kustombrad
kustombrad's Avatar
Re: Project "49 No Buck$"
I didn't give up on the wiper deal, I just decided to keep moving so can drive this thing this summer. I finished plumbing the brakes and took a quick phone pic. I just need to finish up taping the pipe fittings, blowing everything clean and bleeding them! I'll take some better pics, but figured I'd at least show what's going on.
It's all about the stance, baby!
http://67-72chevytrucks.com/vboard/s...d.php?t=320546
kustombrad is offline   Reply With Quote
Old 02-03-2010, 01:39 PM   #127
OrrieG
OrrieG's Avatar
I did not think you were supposed to use tef tape on brake or fuel fittings. A flare should not need it.
OrrieG is offline   Reply With Quote
Old 02-03-2010, 02:32 PM   #128
kustombrad
kustombrad's Avatar
I didn't use it on the flare, only on the pipe thread (residual valve, proportioning valve) parts of the system. If you look closely you can see what I used it on. You never want to use it on fuel systems 'cuz it could plug up a jet and leave you walking. I guess I could have gone and picked up some liquid teflon, but I've never had a problem in the areas I'm using it.
Old 02-14-2010, 11:18 PM   #129
kustombrad
kustombrad's Avatar
I need to take pics of my fuel and brake line routing. I think they both came out pretty cool! I wanted to throw new outer axle bearings and seals in and was going to just put a chrome cover on the back. Instead I took the cheap-ass route and blasted the stock one down to bare metal, painted it brown with a rattle can to somewhat match the truck and threw some striping on it. I think it looks cool! The weird round indentation in the cover is where the factory magnet is...
Old 02-14-2010, 11:20 PM   #130
Jonboy
Slots go on anything!
That cover is awesome. It would probably be the highlight of my truck.....
1974 Jimmy- 5.3/4L80e/NP241
Old 02-15-2010, 10:07 PM   #131
1950 GMC
1950 GMC's Avatar
Doesnt look like a cheap-ass route to me... I like it.
Thanks,
Garrett
My 1950 GMC Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=351867
My 1950 GMC Photobucket Account:
http://s565.photobucket.com/albums/ss95/1950GMC/
1950 GMC is offline   Reply With Quote
Old 02-16-2010, 08:15 AM   #132
0331grunt
Now what??
0331grunt's Avatar
I think it looks pretty good, too.
69 Long Fleet - Project
06 Ram 1ton Cummins 4x4-DD
01 Tahoe- wifes
"The quality of a persons life is in direct proportion to their commitment to excellence, regardless of their chosen field of endeavor." ~ Vince Lombardi
"A dream doesn't become reality through magic, it takes sweat, determination and hard work." ~ Colin Powell
my, um, build
USMC OIF Veteran SEMPER FI!
0331grunt is offline   Reply With Quote
Old 02-17-2010, 12:00 PM   #133
kustombrad
kustombrad's Avatar
Brake stuff! I love wrecking yards and being able to do the "junkyard crawl"! It's amazing what you can find when you walk around with a game plan and just look for stuff. I needed to move my rear brake housing mount over after the way I did the exhaust put it in the way. I looked under different trucks trying to find a frame mount for the rear line that was a bolt on bracket and grabbed one from a late 90's Ford f250 ( I know, I'm ashamed!) Perfect! On the rearend itself, I took the factory bracket that bolts to the rear cover, chopped off the bottom 2" and welded it to an "L" bracket I made out of some 1/8" steel. I used the u-bolt to hold it in place. I used a 2002 S-10 Blazer rear brake flexible line to go from the frame to the rearend. The fuel line I bent out of 3 pieces of 60"x3/8" tubing I got at NAPA, took my time and bent it up to make it as clean as I could. Anybody with a cheap $10 bender and a little patience can do this, plus it looks nice when it's finished.
Old 02-17-2010, 01:01 PM   #134
Daniel U
Daniel U's Avatar
Very clean!
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 02-17-2010, 04:22 PM   #135
0331grunt
Now what??
0331grunt's Avatar
That does look good. I hope mine turn out that clean!
01 Tahoe- wifes
my, um, build
Old 02-20-2010, 01:18 PM   #136
blitz'd
vintage car junkie
blitz'd's Avatar
Are those bolt on leaf spring perches? Where did you get those?
blitz'd is offline   Reply With Quote
Old 02-20-2010, 05:11 PM   #137
kustombrad
kustombrad's Avatar
The whole rear suspension setup is from TCI (minus the blocks). They make a very nice lowered suspension deal!
Old 02-28-2010, 09:15 PM   #138
kustombrad
kustombrad's Avatar
Finished all the brake and fuel line plumbing! Mounted the rear shocks and brackets (shocks might be a bit too short that came with the kit, will have to wait 'till it's put together). The original E-brake stuff all works with the S-10 stuff, so that's pretty cool! I finally decided to throw the wheels on just so I could get a feel for it again and I'm waay happy!
Old 03-02-2010, 12:07 PM   #139
Daniel U
Daniel U's Avatar
Nice!
Old 03-06-2010, 03:25 PM   #140
kustombrad
kustombrad's Avatar
Back in '81, Hot Rod Magazine did an article on a truck built by a guy named Greg Fleury. This truck was my reason for falling for the AD style trucks! What I really liked about the truck was it's 5" chop and all around stance. My friend Bob has been bugging me for the last couple of months to let him chop my truck, but I've been resisting. A couple nights ago I decide to do a 10 minute Photoshop top chop on my truck just to see what I thought and I about flipped! It's going over to Bob's in about 2 weeks for me to leave him alone and cut away! I'll mix up some brown metallic enamel with a ton of flattening agent so it (the top) somewhat matches the rest of the truck and keep moving forward. I just wanted to see what everyone else thinks of how these things look chopped.
Old 03-06-2010, 03:47 PM   #141
rjs53
truck looks great, the chop you have in mind for it seems very fitting great job
rjs53 is offline   Reply With Quote
Old 03-06-2010, 04:40 PM   #142
OrrieG
OrrieG's Avatar
I really like the look, just wonder how many of those curved side windows you will need to cut. all the rest of the glass is flat so that should go ok, but I have always heard that on the average it takes 3 tries to get 55-59 gm windshield glass cut right for a chop, hopefully the curved sides will not be as bad.
Old 03-06-2010, 05:34 PM   #143
britnjc
britnjc's Avatar
you will ruin your cool paint job. So I guess that means you will be painting if it happens
britnjc is offline   Reply With Quote
Old 03-06-2010, 09:48 PM   #144
kustombrad
kustombrad's Avatar
Naah... Lots of flattening agent and a little creativity and it will still look old! That was kinda my dilemma with the whole thing too. I'll make it work.
Old 03-06-2010, 10:16 PM   #145
kustombrad
kustombrad's Avatar
Hmmmm..... I may have to rethink this! I was ready, seat mounting is already perfect, kinda bummed about killing the wore out paint on my roof, sheesh...
Old 03-06-2010, 10:40 PM   #146
britnjc
britnjc's Avatar
ooops sorry dude, didnt mean to bum you out. It will look cool either way. I do love it as it sits though
Old 03-06-2010, 10:43 PM   #147
britnjc
britnjc's Avatar
you could just break the paint at the body line and go with a cream top or something of the sort
Old 03-06-2010, 11:44 PM   #148
LEEVON
LEEVON's Avatar
pleeeEEEEEEEEEEEEaaaaaaaAAAAAAAAAssSSeeeee don't chop your truck, I'm begging you.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 03-07-2010, 09:26 AM   #149
ghettoluxury
ghettoluxury's Avatar
it will not be the same ever again
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 03-07-2010, 09:44 AM   #150
50adrod
50adrod's Avatar
I also do not like the chopped look on this model truck, unles you plan on sectioning the body also. it just looks out of proportion to me
1971 Corvette convertible 454@ 525 hp
1936 Chevy Truck street rod
1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up
1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html
1950 custom Chevy Truck
50adrod is offline   Reply With Quote
