#126 | |
Ridin' Dirty
Re: '63 GMC Project
1978 C3500 Crewcab (Project) 1979 C2500 Crewcab (Driver/project) 1988 R2500 Crewcab (Driver) 1988 V3500 Crewcab 1988 R2500 Crewcab (Mint, Ex Fire Dept) 1968 Chev Suburban (4x4 conversion) LINK 1970 Chev C20 Suburban (driver/cruiser)LINK 2005 Impala (Incognito vehicle) 2004 Yukon XL Denali (Kid hauler) 1947 Case tractor Facebook Page(1000's of pictures of GM cars and trucks organized into albums) YouTube Channel |
#127 | |
Registered Loser
Re: '63 GMC Project
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
#128 |
Registered Loser
Re: '63 GMC Project
#129 |
chevy only
![]() Join Date: Sep 2006
Re: '63 GMC Project
slick kat nice work!!!
CHEVY ONLY... Nothin Else ! |
#130 |
Registered Loser
Re: '63 GMC Project
Hey, thanks Dino!
#131 |
Registered Loser
Re: '63 GMC Project
I took it out on the road yesterday for the first time and it wouldn't shift out of first. We never hooked up a vacuum line to the modulator. Got that taken care of today and took it out again and it was all good. It ran strong, smooth and straight. Just got to get the Porterbuilt hood hinges in and get the carb and timing dialed in and it should be ready to drive to a storage garage for the winter.
#132 |
SSN 706
Re: '63 GMC Project
Love the truck. Are you running a 2 piece drive line? If so do you remember the driveline angles?
#133 |
Registered Loser
Re: '63 GMC Project
Thanks!
Yeah, its a 2 piece shaft. My trans tailshaft points down about 5 degrees and the pinion angle was set at 0. I've only driven it on 2 short test drives up to about 60 mph but I didn't notice any vibration.
#134 |
chevy only
Re: '63 GMC Project
Nice work kat!!!
#135 |
Registered Loser
Re: '63 GMC Project
Thanks Dino.
I'm waiting on a call from Nate regarding my hood hinges so I can get that going. I'm also waiting for a direct mount water temp gauge that I ordered so I can see if the engine is getting hot or if the new sender and stock gauge just aren't getting along.
#136 |
Re: '63 GMC Project
I really like what you have done. It is exactly what I want to do. i have the opportunity to buy a 1964 from a friend of a friend. haven't seen it yet but i will be doing a full frame off like how you did. Good job!
1950 chevy PU work in progress. |
#137 |
Re: '63 GMC Project
Truck's lookin real good. Not a fan of LWB but can't deny hot trucks when I see 'em. Keep up the excellent work!
Betsy - 1966 C10 Stepside :: A very long-term work in progress |
#138 |
Registered Loser
Re: '63 GMC Project
Thanks guys!
I drove it to a small cruise-in on Tuesday and was pleasantly surprised by the reaction it got from the older hot rodders there. Just about the whole time we were there it had a small crowd of guys around it asking me and my friend questions about it.
#139 |
Re: '63 GMC Project
this truck came a long way looks great cant wait to im to this point
#140 |
Registered Loser
Re: '63 GMC Project
Thanks!
I drove it around for about 20 mins. today and when I parked it I noticed tranny fluid sizzling on the pan. I think it got really hot and seaped out of the dipstick grommet. I don't think the small framerail trans cooler is gonna cut it. The suspension was unbelievably smooth. I was expecting a decent ride but not Caddy smooth. The only problems I encountered was an air leak in one of the cheap fittings I bought and a very small air leak in one of the Dominator bags where the rubber meets the steel bottom. Niether of which are the fault of the suspension design or the installation. ...and man is that motor strong. it really pins you to the seat. ![]()
#141 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: '63 GMC Project
Yeah those frame rail tranny coolers usually don't cut it. You need to have your tranny cooler out front where it can get airflow. Unless you can put a good sized fan on the frame rail cooler.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 10-25-2010 at 12:49 AM. |
#142 |
Registered Loser
Re: '63 GMC Project
The cooler I have now is too small to put a fan on so I'm gonna make a trip to Summit Racing tomorrow and get a new, bigger cooler and an electric fan for the front of the rad to help with the engine temps.
#143 |
Registered Loser
Re: '63 GMC Project
I put a bigger trans cooler in up front and also added an electric fan to the front of the radiator. Got the Porterbuit hinges in and the hood back on but the only pic I have is a crappy cell phone shot (I know, I'm slackin'), I'll get some more when I find my camera.
#144 |
![]() Join Date: Feb 2003
Re: '63 GMC Project
Sweeeeeeeet.
#145 |
Registered Loser
Re: '63 GMC Project
Thanks Delmo! I noticed there are 2 holes in the bottom of each of the Porterbuit hinge pockets, did you put bolts through those into the cowl? Seems like they would leak into the cab so I didn't.
Man, I really need to clean those white walls!
#146 |
Ridin' Dirty
Re: '63 GMC Project
I love this truck!
#147 |
Re: '63 GMC Project
Ya I put bolts through the bottom otherwise there seemed to be to much stress on the front. My hinge pockets don't move at all. If you are worried about moisture just dab some right stuff (or silicone) around the washers.
lovin the truck though man. |
#148 |
Registered Loser
Re: '63 GMC Project
I think I might try making some plates to go on the outside of the cowl that bolt on using the hinge pocket hardware and spreads the load across more of the cowl.
#149 |
Registered Loser
Re: '63 GMC Project
#150 | |
Re: '63 GMC Project
![]() ![]() Nice work.
![]() 1960 GMC short fleet, full frame build... http://67-72chevytrucks.com/vboard/s...d.php?t=329718 Last edited by sams60gmc; 11-09-2010 at 02:57 AM. |
