Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 05-17-2011, 11:15 PM   #126
Captainfab
60-66 Nut
Re: D52 Caliper Rear Disc Brake Brackets
For a rear disc conversion on a C30, you will have to use the K20 front rotors and the '76-'78 Eldorado rear calipers with the e-brake
Originally Posted by madcow75 View Post
What caliper is used with a C30 disc conversion. Want to keep e-brake type caliper. I will be also using 16" facory steel wheels
Old 05-17-2011, 11:19 PM   #127
Captainfab
60-66 Nut
I haven't really dealt with the C30's, so I'm not sure. It is possible that you may have the smaller of the brakes available for the C30's. I do know that there were bigger drums available on some of the dually's in the rear, so maybe there is a bigger caliper available? Does your truck already have hydroboost?
Originally Posted by truckzilla View Post
Thanks Capt'n! Any idea of a front brake improvement for the early '80s C30 duallys?
Old 05-18-2011, 07:02 AM   #128
madcow75
madcow75's Avatar
Yes my truck allready has hydroboost. I have a 76 cc dually which I am converting to 4wd. I have read before about possible clearance issues with d-52 calipers with smaller wheels. Just trying to clear it up hopefully with someone with experience. I have heard about using a 2003 chevy express van rotors on the c30's instead of the 3/4 ton front rotors, with 1/4" spacers. I have a dana 70HD.
madcow75 is offline   Reply With Quote
Old 05-18-2011, 11:17 PM   #129
Captainfab
60-66 Nut
When converting to rear disc on any of the 8 hole differentials, you need to run at least 16" wheels. Otherwise you will need to do a bunch of grinding on the outside of the caliper. I'm only familar with the conversion using the '73+ K20 rotors. What is the advantage to the Express/Savana rotors? Are they a larger diameter?
Old 05-19-2011, 07:03 AM   #130
madcow75
madcow75's Avatar
I do not have the facts but they appear to be altleast 8" deep, that would get the caliper away from the wheel, as appose to the 3/4 ton rotor which is probebly only 2" deep.
Old 05-19-2011, 11:02 PM   #131
Captainfab
60-66 Nut
The '71-'86 K20 front rotors are 12.50" diameter, 1.29" thick, and 2.81" in overall height. The '99-'10 Express/Savana front rotors are 12.79" diameter, 1.50 thick, and 3.51" in overall height.
So yes they are a bit deeper, .70" to be exact. And they are slightly larger in diameter, and thicker as well. However you won't be able to use a D52 caliper on these, as they are just too thick. You would likely have to use the Express/Savana rear calipers, which may not be a bad thing, since I believe they are a dual piston caliper.
You might also be able to use the rear rotors and calipers for the Express/Sanvana. The rotors are 13.0" diameter, 1.40 thick and 3.42" in overall height.
This is the first that I've heard of using these rotors for a rear disc conversion of this type, so I don't know for sure if you could run 15" wheels without grinding these calipers also. Where did you hear/read about this?
Old 05-20-2011, 08:08 AM   #132
madcow75
madcow75's Avatar
I seen another guy on pirate 4x4 experimenting with this set up but he was just using 3/4 ton caliper thou as it was strictly for off road -no need for the emergency brake. He is running the e4xpress van rotor with 1/4 spacers for caliper aligment with his 3/4 ton calipers.
Thanks for the specs it is greatly apprecited. I will be running 16" steel dual factory steel wheels with my dana 70hd.
I am in the middle of a restoration converting a 1976 2wd CC crewcab to 4wd.
Old 05-20-2011, 01:06 PM   #133
truckzilla
truckzilla's Avatar
No, Captainfab, no hydroboost . . . yet. Plan on it though just to replace the bulky looking vac booster. The reason I was looking for some front brake improvement for my '81 C30 DRW (which is really a converted C20 SRW), is that I tend to drive it, lets just say, aggressively.
I know, I know, shame on me!
truckzilla is offline   Reply With Quote
Old 05-20-2011, 01:10 PM   #134
truckzilla
truckzilla's Avatar
I know its somewhat off topic, But I'm wondering what Madcow75 is doing with my avatar? But then I noticed the extra set of windows behind the cab!
Wait until you see my dog of a dually! We're talking ugly enough that only a metal crusher would love it!
Old 05-21-2011, 04:46 AM   #135
70chevyolbetty
look good im gonna order one in a few weeks. couple questions. will my disc/ drum brake booster work, or will i need the disc/ disc booster?and just to clarify its adding half inch to the width of the rearend or half inch on each side?clean work.
70chevyolbetty is offline   Reply With Quote
Old 05-21-2011, 11:38 PM   #136
Captainfab
60-66 Nut
Your booster will be just fine. However you should change your master cylinder to a disc/disc master. You will also want either a disc/disc proportioning valve, or an adjustable valve in the rear line. Wilwood makes a nice unit that is all in one.
http://www.summitracing.com/parts/WIL-260-11179/
Old 05-31-2011, 08:25 AM   #137
CoreyLeo223
CoreyLeo223's Avatar
Captainfab----- you wrote: "These brackets will bolt onto the truck 12 bolt rear differentials from '64-'82 and the 10 bolt truck differentials from '83-'87"...
What is the reason this wont work with a 12 bolt from an 83-87?
1983 Chevy C10 lwb 305
1984 Chevy C10 swb (planning an LSx swap)
2005 Ford Crown Vic A4 (patrol car)
SOLD...1998 Camaro Z28
SOLD...2005 GTO
CoreyLeo223 is offline   Reply With Quote
Old 05-31-2011, 11:37 PM   #138
Captainfab
60-66 Nut
Because GM didn't make any 12 bolts from '83-'87. The last year for the 12 bolt in the C10's was 1982.
Old 07-17-2011, 05:59 PM   #139
n2billet
Village Idiot....
n2billet's Avatar
I bought my kit just over a year ago and just now put them on......I went ahead and blasted, painted them before even test fitting them. I can't tell you how nice it feels when EVERTHING bolts up like it's suppose too....very nice product!!
http://www.hubgarage.com/mygarage/n2billet
-67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold
-71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold
n2billet is offline   Reply With Quote
Old 07-17-2011, 11:12 PM   #140
Captainfab
60-66 Nut
That looks great
Thanks for the compliment
Old 09-18-2011, 07:06 PM   #141
flamingbig10
6.0 powered square
flamingbig10's Avatar
do you have any in stock, my leaking disc/drum proportion valve has forced me to go ahead and do a rear disc brake conversion using wilwood d-52 calipers and rear diff rebuild
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 09-18-2011, 11:16 PM   #142
Captainfab
60-66 Nut
Yes I have a few sets in stock in bare steel. Powder coated ones will be a week or so to have done.
Old 09-18-2011, 11:45 PM   #143
flamingbig10
6.0 powered square
thanks I'll take a bare set
Aaron
Old 09-19-2011, 02:08 AM   #144
Captainfab
60-66 Nut
PM sent.....
Old 09-19-2011, 11:38 AM   #145
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
I need a set in bare steel as well, sending PM.
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 09-19-2011, 09:48 PM   #146
Twisted78SS
Wide n'Low
funds sent, Thanks!
Air Force Retired
Old 09-26-2011, 01:15 PM   #147
Twisted78SS
Wide n'Low
A box arrived over the weekend, but the kids put it out of the way, I will be digging in tonight when I get home.
thanks for the quick response and fast shipment!
Air Force Retired
Old 09-26-2011, 06:54 PM   #148
flamingbig10
6.0 powered square
I received mine Friday every thing looks top notch
Aaron
Old 09-26-2011, 10:58 PM   #149
Captainfab
60-66 Nut
Thanks guys
Old 09-27-2011, 12:20 PM   #150
TRUKLUVR
Hello to everybody.I need a set in plain steel.Can i have a set delivered to canada? Capt please email me with particulars.Much appreciated.I have the wilwood d52 calipers just need your brackets thanks.
TRUKLUVR is offline   Reply With Quote
