#126 |
Re: Extreme Powder Coating '65 C-10 Shop Truck
With the 2" dimple die holes do you still have room to weld a cage if you choose too. I plan on running an extensive frame cage and like the look of the dimple die holes?
FAT MIKE My 59 http://67-72chevytrucks.com/vboard/s...d.php?t=400201 My 47 http://67-72chevytrucks.com/vboard/s...d.php?t=386848 |
#127 |
Should be room.
#128 |
chevy only
![]() Join Date: Sep 2006
DUUUUDE LOV IT!!!!
CHEVY ONLY... Nothin Else ! |
#129 |
#130 |
looking good man!
#131 |
New custom arm rests - Thank you Lakeside Rods and Rides
![]() Last edited by kart34; 01-07-2011 at 10:15 PM. |
#132 |
i fall in love
guys,,,im overseas member..so please ,,respond me with easy english,coz its my second language....thanks --c30 1966 frame off 5 years restoration ; Finished; Chevy suburban 1958 restoration ( In progress ) 85 c10 "back to original project <Finished> " 81 c10 "back to original ( later) " 85 c10 cattleman edition lifted ( finished)> K1500 1989 full restoration ( soon ) S10 1991 in progress |
#133 |
Allllright - we will admit that we are using some FORD parts on this 'lil Chevy pick-up truck...grrrr...
You're looking at a 1965 Mustang fuel tank AND (the best buy ever) 2010 Mustang Shelby GT 500 take off mufflers. EBAY score - $20.00 a pop! ![]() |
#134 |
1# Drobmember in Germany
![]() Join Date: Aug 2008
Pretty Cool!!!!!!!!!!!!!!!!!
![]() Canīt wait to see more!!! ![]() Pat
Pat |
#135 |
Awsome build
#136 |
#137 |
67 series 1 No CLR here we have done testing and will be powdercoating a flat clear over the patina to lock it in. Then Krazy Kolors will add the logos. Stay Tuned This truck will be the new test mule for Extreme Powder Coating .
#138 |
We chopped up some pipe and got this 2.5 inch exhaust system mocked up
![]() Last edited by kart34; 01-06-2011 at 09:35 PM. |
#139 |
The exhaust from the underside... Custom 1 off exhaust by Wally's Speed Shop We will ceramic coat these in house by Extreme Ceramic Coatings
#140 |
Great Truck! Also love the rendering Carter! Came out good!
1955 First Series Thriftmaster Blown 355 TH400, S10 Chassis,narrowed 9 Inch rear, air ride, 4 wheel disc brakes, 20s and 22s, |
#141 |
The exhaust system is all mocked up. Waiting on 2.5 inch electric exhaust cut outs. We got the box on to see how she sits!
...lookin' super low 'n lovin' it ...... Full Porterbuilt Drop Member and Rear Notch Kit with Trailing Arms very trick set up ![]() Last edited by kart34; 01-06-2011 at 09:24 PM. |
#142 |
Raised the tunnel to clear the T-56 6 speed transmission - and sectioning the center console to avoid moving the shifter! Makin' it work!!!
#143 |
chevy only
very cool very cool!!!!
#144 |
I think you should put the BIG back window in so you can turn your head and see that exhaust and suspension !
#145 |
Keeping the small back window sorry
#146 |
I have to ask...where did you get the door handles and window crank handles? Those are bada$$
Pro Touring 1964 C10-Under Construction ![]() Project '65 Short Step Daily Driver http://67-72chevytrucks.com/vboard/s...d.php?t=661948 |
#147 |
Lokar Lakester Series these are in raw steel
#148 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Im in this is killer...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#149 |
thanks guys it has been a fun project so far !! Working with some talented kats on this ride !!!
#150 |
where did this build come from, this truck is unreal!
![]() 1960 GMC short fleet, full frame build... http://67-72chevytrucks.com/vboard/s...d.php?t=329718 |
Tags |
'65, c-10, carter hickman designs, extreme powder coating |
