Old 05-19-2011, 07:33 PM   #126
(joey)
(joey)'s Avatar
Re: Project...praise the lowered
Originally Posted by 67cheby View Post
thanks maybe we should get a set for your truck !!
maybe after i get all the bugs out.for now i bought some trailer fenders im going to tack in place
check out my build (the start of a shaved,channeled,bagged 67 gmc with a 01 gmc frame and drivetrain)
http://67-72chevytrucks.com/vboard/s...d.php?t=434253
(joey) is offline   Reply With Quote
Old 05-19-2011, 07:38 PM   #127
(joey)
(joey)'s Avatar
Originally Posted by slick copper View Post
Yer keepin' her a 6 lug! Sweet! Let me know when you get it all back together or if you already know how much of a difference it changes your spacing from stock. This is an upgrade i'd love to do in the future, but want to keep my stock wheel spacing. Also what brand or kit did you go with? Sorry for so many questions. Any info would be much appreciated! Thanks,
no problem,more questions the better.now assuming you mean the rear disc setup,its just the stock rear end from the 2001 donor truck im using.where im swaping the 67 body onto the newer frame,im using as much stock suspension setup as i can.only for the rear instead of leafs im using bags and the trailing arms i fabbed.but what i can do is get a width measurement of both rear ends so in the future you guys could possibly just do the swap,cut the brackets off the old rear end and weld them on the new style one.then disc in the rear as simple as that
Old 05-19-2011, 07:40 PM   #128
(joey)
(joey)'s Avatar
almost forgot.more goodies in the mail.compressor ,pressure switch and got some locking lug nuts.
Old 05-20-2011, 10:26 AM   #129
slick copper
slick copper's Avatar
Red face Re: Project...praise the lowered
Forgot there for a minute you're using the newer chassis! But that's still be some good info on how close the stocker is to the later model rear end. Thanks!
Raymond
1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594
The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939
Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402
slick copper is offline   Reply With Quote
Old 05-20-2011, 08:06 PM   #130
(joey)
(joey)'s Avatar
haha.a buddy of mine reminded me that the newer style rear end will be weider then the old.i will get a measurement on sunday
Old 05-22-2011, 07:53 PM   #131
(joey)
(joey)'s Avatar
from face to face of the newer style rear end is 68 inches.old rear end is 62 1/2 inches.quite a difference. but now everyone knows.
today me and my girl finished stripping all the crud off the rear half of the frame.ground off all the welds from the stuff i cut off,then primed and painted with box liner.turned out perfect.then i got the front suspension (minus the bags) installed and tonight i threw a couple wheels on and dropped her down.its going to lay real nice.should have the rear axle mocked up tomorrow.finally we have some nice driveway working weather.
Old 05-22-2011, 07:58 PM   #132
67cheby
67cheby
67cheby's Avatar
so you are putting your truck on the new body frame ??
67cheby is offline   Reply With Quote
Old 05-22-2011, 08:02 PM   #133
(joey)
(joey)'s Avatar
yup.67 on the newer frame.using as much as i can from the newer truck.motor/trans/wiring/most of the suspension/wiper motor/steering column/gauges/air conditioning eventually ect and pretty much the complete body from the 67
Old 05-22-2011, 08:08 PM   #134
oldman3
oldman3's Avatar
Looking real good, Jim
oldman3 is offline   Reply With Quote
Old 05-22-2011, 08:12 PM   #135
67cheby
67cheby
67cheby's Avatar
oh thats cool man
Old 05-23-2011, 07:39 PM   #136
(joey)
(joey)'s Avatar
another good day for the driveway build.today i mocked up the rear end.me and the mrs got the wheel base with in an 1/8th first try.after we got it perfect i got the control arms measured and marked out where im going to build the rear bag mounts/axle pads/and u bolt mounts.after going out for the afternoon i cut up some box sides when i got back.from long box to short box.it wasnt a bad job at all.
Old 05-23-2011, 07:41 PM   #137
kev2809
low n' slo
kev2809's Avatar
so are you gonna make a bracket that bolts to the axle to hold the link bar? or are you going to weld it to the axle?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 05-23-2011, 07:51 PM   #138
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looks like you could get away with the u bolts possibly??
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 05-23-2011, 07:53 PM   #139
(joey)
(joey)'s Avatar
im going to use some of the stock mounting hardware from the newer truck setup.in the first picture you can see one of the axle pads under the u bolt.its what kept the axle flat on the leaf springs.where the leafs sat on top of the axle i cut it off and im rotating them around to the bottom to sit on top of the arms.in the top left of the same pic you can see some more u bolt mounting brackets.im going to set that on top of the axle and drop the u bolts through a couple of brackets im going to weld to the arms.hard to explain but i will post a pic as soon as i get it done
Old 05-23-2011, 09:29 PM   #140
kev2809
low n' slo
kev2809's Avatar
nice. im likeing that setup. are you mounting your bags on the bars behind the axle?
i wonder if i could make something like this myself for my truck that would just bolt on...
-_--_--_ _________
Old 05-23-2011, 10:13 PM   #141
black_sheep454
That front clip looks amazing, nice build.
1968 chevy lwb, getting ready to join forces with the 70 gmc
1970 gmc swb, getting ready to be a 68 chevy swb
1971 gmc lwb 2500 2wd Sierra Grande
1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins
black_sheep454 is offline   Reply With Quote
Old 05-24-2011, 05:45 PM   #142
(joey)
(joey)'s Avatar
as always thanks for the input.
Kev im sure you could do something like this setup.and the bags are going to mount behind the axle.i made some bag mounts and u bolt mounts today at work.i should have the arms finished tomorrow.i will post a pic as soon as i can.today i did a little more blocking on the dash.about another hour and it should be ready for primer.after fitting up the gauge cluster i discovered i have to re bend the mounts a little.not a big deal.i also snaped a pic of the paddle valve setup and gauges.hides most of the seam where the dash meets the console real nice.
Old 05-25-2011, 05:31 PM   #143
(joey)
(joey)'s Avatar
i got the rear arms complete.minus the paint and shock mounts.after i set my ride height this weekend i should be able to make the upper bag mounts.
Old 05-26-2011, 08:24 PM   #144
(joey)
(joey)'s Avatar
i had a little over sn hour of spare time to work on the ol girl today so i installed the shifter and the parking brake.a little more metal shaping and the console will be ready for fill.
Old 05-26-2011, 10:31 PM   #145
67cheby
67cheby
67cheby's Avatar
looking good man !!
Old 05-27-2011, 12:07 AM   #146
VA72C10
VA72C10
VA72C10's Avatar
nice work!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 05-27-2011, 11:23 AM   #147
thor
thor's Avatar
i'm loving the lines of that console!
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 06-05-2011, 03:26 PM   #148
(joey)
(joey)'s Avatar
sorry for not having any updates for those of you following.i have been quite busy with the build and enjoying the summer.so here is where i am now.drivers side box is now one piece,welded together,wheel arch patch in place,body work done including hours and hours of blocking (had some help from the build foreman),epoxy primed and high build primed.brake lines are all built,bent,just need flared.abs heart is cleaned,painted and ready to go.and now in the works is a custom stainless fuel tank to take place of the stocker from the newer donor truck.when i moved the rear axle ahead 4 inches it was hitting the rear of the tank.heres some pics of the build and a couple trucks from a car show i went to yesterday.
Old 06-05-2011, 03:30 PM   #149
67cheby
67cheby
67cheby's Avatar
nice work and COOL
Old 06-10-2011, 05:04 PM   #150
(joey)
(joey)'s Avatar
67cheby im going to have to get you a number 1 fan t-shirt haha
after blocking and sanding for the past week i managed to do some paint and primer.the dash didnt turn out too bad for combining the newer gauge housing and playing around with a little sheet metal.feels good to spray a little color.
