05-03-2011, 09:48 AM | #126 | |
Re: The Brown Truck
Medium Fawn: 60% gloss DuPont: #9171-L Ditzler: #DL-22571 Rinshed-Mason: #65B84 Dark Fawn: 0% Gloss DuPont: #9202-L Ditzler: #DIA 22568 |
05-05-2011, 08:32 AM | #127 |
1961 crewcab
Re: The Brown Truck
that upper bbw seam came out great!
did you use panel bonding adhesive?
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
05-05-2011, 02:42 PM | #128 |
Re: The Brown Truck
05-09-2011, 09:53 PM | #129 |
Re: The Brown Truck
Started with the sound deadening this evening. It'll be a pretty big job, but should be worth the effort.
05-13-2011, 04:13 PM | #130 |
Re: The Brown Truck
My custom made white oak bed wood was delivered today. I'm very happy with how it turned out. I'll post pictures later this afternoon.
05-15-2011, 04:59 PM | #131 |
Re: The Brown Truck
I mocked up the unfinished wood with my stainless strips from Mar-K. My plan is to hit the wood with a high quality Marine Varnish. Notice the mirrored grain on the two center pieces... pretty cool.
05-17-2011, 10:54 AM | #132 |
meowMEOWmeowMEOW
Re: The Brown Truck
that cab looks CLEAN nice going man.
05-20-2011, 12:01 AM | #133 |
Re: The Brown Truck
Thanks!!
Here's a progress update from tonight. My dad came to town for the weekend, and it made things more fun having someone else in the shop. We got the M/C and booster installed and the new brake lines run. We also kept plugging away at the sound deadening. |
05-22-2011, 07:54 PM | #134 |
Re: The Brown Truck
Here are some more pics of the sound deadening, and of the wiring harness. We made a lot of progress this weekend, I just need to order crimpers from American Autowire.
05-22-2011, 10:53 PM | #135 |
1 thing at a time is progress.
Re: The Brown Truck
Very Nice work.
Alan
Philippians 2:14-16 |
05-22-2011, 11:57 PM | #136 |
Re: The Brown Truck
I just finished staining my bed!!! It turned out great! For best results!!! Stain once get a 300 grit foam and drain again!!!!! I have my entire process on my thread, but you seem pretty knowledgeable on most stuff!!!! Great job!!!!
http://67-72chevytrucks.com/vboard/s...ban+Retro:fro: |
05-25-2011, 08:40 AM | #137 | |
Re: The Brown Truck
Thanks Alan! It's coming along. I'm trying to keep my nose to the grindstone.
I ordered the special crimpers from AAW the other day, so hopefully I'll be back on track soon. It shouldn't be long before I have the interior ready, then I'll be probably waiting for the body again... |
05-26-2011, 11:23 AM | #138 |
Re: The Brown Truck
I thought I'd say a little about the sound deadening products I've been using. It is the Edead product line from Elemental Designs. I ended up using three different products. For most of the cab, I laid down two layers of 45 mil Edead butyl rubber deadening mat. (the 80 mil product was out of stock so I ended up installing two layers of the thinner mat). For the very contoured places, I used Edead V3 liquid sound deadening. I also ended up using the liquid on the back of the cab because I had extra left over and ran out of the mat. Both do a great job of keeping vibrations down. Finally everything will be covered with a high density foam mat that is designed to control higher frequency sounds.
Here's a picture of the three. I'm hoping that this effort will make for a nice quiet ride. |
05-26-2011, 01:02 PM | #139 |
The 60-66 GMC/Pontiac guy....
Re: The Brown Truck
Will those products work for those of us that prefer a rubber mat over carpet?
Personally speaking, I would prefer to hose out my truck if water wasn't so damaging to the metal in my cab. Carpet is on my never use it list in my own trucks and since I brought it up, are there any suggestions for a vendor for a good high quality rubber floor mat for our trucks?
Building Genuine Pontiac Firepowered cars and trucks for several decades. Why Pontiac?? That's just me daring to be different. Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac |
05-26-2011, 01:06 PM | #140 |
Re: The Brown Truck
Nice work. I just used the regular peel and seal for my cab, but used a closed cell industrial foam pad from the firewall to the back, then carpet over top. The difference it made in the sound inside the cab was HUGE. And that was before my doors were done, should be wicked quiet now.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
05-26-2011, 01:23 PM | #141 | ||
Re: The Brown Truck
I believe that most of the vendors sell a factory-style rubber mat, but I can't speak at all to their quality. Quote:
05-26-2011, 07:55 PM | #142 | |
Re: The Brown Truck
I ordered a mat from one of mail order guys and it's a $99 POS. Doesn't fit right and won't even if I trim it. I'm looking for something better.
06-07-2011, 09:11 AM | #143 |
Re: The Brown Truck
I finally got my special crimpers in from AAW, and set out on the wiring. The kit works very well for the most part. There is some splicing required to wire in the lights for the dash cluster. I've got everything wired up in the cluster, including a voltmeter out of a square body truck in place of the ammeter. Thanks for working through this Roy!
Can anyone tell me where bulbs were installed in the factory cluster? There are 6 round inserts for bulbs in the back of the cluster that appear to be for gauge illumination, but I can't imagine that they were all used from the factory. I got the steering column bolted up and wired, and I test fit the condenser in front of the radiator. I'm now trying to figure out a good place to install my trans cooler without blocking the flow of the condenser. |
06-07-2011, 01:04 PM | #144 |
Re: The Brown Truck
looking good! make sure you "Calibrate" your voltmeter so it runs kinda in the center. I thought I had mine right, but it's about 3/4 where it operates. I'm too lazy to pull it out and fix it . . . You going with the original hardline oil pressure hookup?
Roy
1965 Suburban Waiting on Time and Money Last edited by RoyL; 06-07-2011 at 01:05 PM. |
06-07-2011, 01:23 PM | #145 |
Re: The Brown Truck
I think I have the gauge centered pretty well, but we'll have to see. I do plan to run the original hardline for oil pressure.
06-07-2011, 03:00 PM | #146 | |
Re: The Brown Truck
06-07-2011, 04:37 PM | #147 | |
Re: The Brown Truck
YES, by the way, I want a rubber mat that goes firewall to cab rear and can be held down by the sill plates on the sides. That would be perfect. In Arizona, carpet is baked fast then falls apart and holds in TONS of dust and dirt. I can wipe out and nasty stuff with a damp sponge if I have a rubber mat. Side note; One of the vendors I have ordered from recently phoned me to express their frustration with my returning things. Well, if it wasn't Asian made garbage it would be in my truck. The rubber mats I have ordered were thin crappy junk.
06-09-2011, 10:10 PM | #148 |
Re: The Brown Truck
My new radiator came in today. After a lot of deliberation, I decided to go with the one from Engineered Cooling Products over the Champion radiator. Both products seem to be similar, but one is a two row with 1" tubes and the Champion is a three row with smaller tubes. I doubt there is any difference between the two. The ECP radiator is advertised as having a bigger trans cooler than the others but who really knows. I'm pretty happy with the product. There are a few fins that are a bit tweaked but nothing major. It'll definitely make the engine compartment look nice.
Here's where I'm thinking of installing the auxiliary trans cooler. Hopefully it works out ok. It's a big unit, but I don't want to fool around when it comes to heat on my new transmission. I'm trying to keep it out of the way of the a/c condenser as much as possible. I'm open to suggestions as to other places to mount it if anyone has any. |
06-09-2011, 10:22 PM | #149 |
Re: The Brown Truck
I am still up in the air on what Radiator to go with.
It is good that you are putting thought into it and not just doing what everyone else is. Leader not a follower, thats how I roll....
06-09-2011, 11:15 PM | #150 |
Re: The Brown Truck
Thanks! I'll be sure to let everyone know how it works. I'm installing a transmission temp gauge too, so I'll know how everything is working.
