Old 05-25-2011, 06:30 PM   #126
oldman3
oldman3's Avatar
Re: Jimbo's 67 Long bed step side build
After talking with the owner, he wanted a raised panel look, like I have on my 54 bed. His sides were so bad and wavy that we decided to add 14 ga. sheet metal to the outside on panel.
Here metal has been placed for fitting.
oldman3 is offline   Reply With Quote
Old 05-25-2011, 06:34 PM   #127
oldman3
oldman3's Avatar
Pic 1 Here the metal has been trimed, and attached with panel glue.
Pic 2 Close up view with metal clamped in place.
Pic 3 24 hrs later and metal is attached with no problems.
Old 05-25-2011, 06:35 PM   #128
oldman3
oldman3's Avatar
Metal cut to shape for the drivers panel.
Old 05-25-2011, 06:38 PM   #129
oldman3
oldman3's Avatar
Pic 1 Driver bed side, here panel glue is being applied.
Pic 2 Same panel at the rear (My paint store let me borrow their gun to apply glue.)
Old 05-25-2011, 06:41 PM   #130
oldman3
oldman3's Avatar
Here the metal has been added, (note metal extended to bottom of fender and then back to stake pocket area), I'm working on a raise panel detail that will also be added (templete out of door board).
Old 05-25-2011, 06:42 PM   #131
oldman3
oldman3's Avatar
Detail panel for up front on bed side.
Old 05-25-2011, 06:45 PM   #132
oldman3
oldman3's Avatar
This is the panel cut out of 14 ga sheet metal for pass side front panel.
Old 05-25-2011, 06:46 PM   #133
oldman3
oldman3's Avatar
Close up shot of raised panel.
Old 05-25-2011, 06:47 PM   #134
oldman3
oldman3's Avatar
Another view showing how it lines up with top of fender and the body line of fender.
Old 05-25-2011, 06:49 PM   #135
oldman3
oldman3's Avatar
Since panel is close to stake pocket, filler was added now, will be sanded down and then install panel.
Old 05-25-2011, 06:51 PM   #136
oldman3
oldman3's Avatar
Also before installing panels, decided to extend the stake pocket to tie into running boards.
Old 05-25-2011, 06:53 PM   #137
oldman3
oldman3's Avatar
Runnin board is also bolted to the extension from back side.
Old 05-25-2011, 06:55 PM   #138
oldman3
oldman3's Avatar
This has been a detail post on part of what was done to the bed. Tomorrow I will take you on the rest of the journey.
Old 05-26-2011, 08:31 PM   #139
oldman3
oldman3's Avatar
Ok folks, let's get to todays post.
While working on the extensions, we got in the new Cadallic taillights, so we cut the hole in the rear stake pocket.
Old 05-26-2011, 08:32 PM   #140
oldman3
oldman3's Avatar
Installing their filler piece.
Old 05-26-2011, 08:34 PM   #141
oldman3
oldman3's Avatar
All welded in, ready to be ground smooth.
Old 05-26-2011, 08:35 PM   #142
oldman3
oldman3's Avatar
View of both panels, right side done, left side tacked in place.
Old 05-26-2011, 08:37 PM   #143
oldman3
oldman3's Avatar
Temporary hook up of the LED lights.
Old 05-26-2011, 08:38 PM   #144
oldman3
oldman3's Avatar
Getting filler sanded, before installing raised panel.
Old 05-26-2011, 08:41 PM   #145
oldman3
oldman3's Avatar
To get a raised panel look on the inside a long single piece was installed on the panels. These were installed same as the outside panels.
Old 05-26-2011, 08:43 PM   #146
oldman3
oldman3's Avatar
Pic 1 Filler on inside of bed panels. Here you can see the single panel better.
Pic 2 Another view.
Old 05-26-2011, 08:44 PM   #147
oldman3
oldman3's Avatar
pics didn't show
Old 05-26-2011, 08:46 PM   #148
oldman3
oldman3's Avatar
Bed sides were installed on bed for checking look, etc.
Old 05-26-2011, 08:48 PM   #149
oldman3
oldman3's Avatar
Outside view, here you can see the raised panels with filler to smooth the edges.
Old 05-26-2011, 08:50 PM   #150
oldman3
oldman3's Avatar
Bed put on truck for checking overall look.
