Old 11-30-2011, 01:49 PM   #126
Randy83
Randy83's Avatar
Re: crew cab short bed build " clifford"
I have been looking for a suburban frontend for mine.... looks good, crew looks good also.
Randy83 is offline   Reply With Quote
Old 12-01-2011, 11:54 PM   #127
rs72z
rs72z's Avatar
Thanks Randy.
I might know where to find one.
rs72z is offline   Reply With Quote
Old 12-02-2011, 12:09 AM   #128
rs72z
rs72z's Avatar
Well, i have made a little progress this week not near what i had planned. Still better than being at work.
Dropped front springs in. Supposed to be 2" drop looks more like 3 plus, which is ok.
Drive shaft figured out, now it needs to go to the driveshaft shop.
Instrument cluster plug reppined for the new electric speedo cluster. I succsefully made that hour long job into three hours. While i was tracing out the pins on the old cluster the fedex woman showed up with a box, while dealing with that i managed to get confused when i went back to work on the cluster. needles to say i had a bunch of pins in wrong place and took a while to get it straightened out.
Drilled and tapped the passenger head to 3/8 pipe for the temp sensor.
Rear shackles should be here tomorrow.
I'll try and post some new pics tomorrow.
Old 12-02-2011, 01:46 PM   #129
Randy83
Randy83's Avatar
Let me know, do you just want me to call you at the shop?
Old 12-02-2011, 02:17 PM   #130
jitteryguy
GoatLube Experss
jitteryguy's Avatar
looks good !
I dont know how far ya'll are from Grahm, but theres a place call'd K&N between Grahm and Breckinridge. I've bought 3 Suburban grills/core support assy's from them. the last time I look'd at there web site they had a couple on hand.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 12-04-2011, 12:05 AM   #131
rs72z
rs72z's Avatar
Originally Posted by jitteryguy View Post
looks good !
Thanks. we're in East Tx.
Old 12-04-2011, 12:12 AM   #132
rs72z
rs72z's Avatar
Here's a few new pics.
I installed the rear shackles, they are a 2" drop and removed thre leafs, probably will add helper bags later.
Installed 2" dropped front springs, looks more like about 4".
i hung the fenders so i could see how it looked and get the fusebox and aircleaner mounted before cutting in the fenders.
Long boarded the fenders and bed and reprimed for the last time.
Old 12-04-2011, 12:15 AM   #133
rs72z
rs72z's Avatar
more
Old 12-06-2011, 08:30 PM   #134
scottco
scottco's Avatar
What is the length of the rear driveshaft center cup to center cup now and is that where you will take the 14 inches out?
1964 C10 SWB original
1970 SS El Camino
1964 Impala SS
http://67-72chevytrucks.com/vboard/s...d.php?t=649951
scottco is offline   Reply With Quote
Old 12-06-2011, 10:46 PM   #135
rs72z
rs72z's Avatar
Mine is going to be 42 1/2 center to center, going to the driveshaft shop tomorrow. I didn't have a driveshaft to begin with, so i picked one up out of a 2000 ext cab shortbed. The front half is the right length, going to have a new tube built for the rear.
But to answer your question yes you would shorten the rear half, the front length shouldn't change.
Old 12-06-2011, 11:01 PM   #136
scottco
scottco's Avatar
Cool,,, Just wasn't sure how the 2 piece shaft thing would work,, Looks like you have a plan.. Mine will be one piece about 58".. Thanks for the info !!!!!
1970 SS El Camino
1964 Impala SS
Old 12-06-2011, 11:09 PM   #137
rs72z
rs72z's Avatar
No problem, glad to help.
Old 12-07-2011, 01:51 PM   #138
Randy83
Randy83's Avatar
Paul, do you think ya'll would interested in painting mine? It will just be solid black, no graphics or anything....
Old 12-07-2011, 03:35 PM   #139
rs72z
rs72z's Avatar
Yea we would do it. Might not be cheap though. Give us a call.
Old 12-07-2011, 07:41 PM   #140
rs72z
rs72z's Avatar
Dually fenders in first prime.
Old 12-09-2011, 09:10 AM   #141
rs72z
rs72z's Avatar
I got a little more done last night. My new fuel tank came in yesterday, 31 gallon burb tank from rockauto.
Got it all mounted up and made some new crossmembers.
Old 12-09-2011, 09:17 AM   #142
Randy83
Randy83's Avatar
looks good, also looks like you may be driving it before long....
Old 12-09-2011, 12:46 PM   #143
rs72z
rs72z's Avatar
Picked up my driveshaft this morning. Should be moving under it's own power by tomorrow.
Old 12-09-2011, 06:53 PM   #144
Conundrum
Conundrum's Avatar
Nice
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r
http://67-72chevytrucks.com/vboard/s...d.php?t=460030
97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver
220,000 miles, all stock for now
Conundrum is offline   Reply With Quote
Old 12-12-2011, 09:06 AM   #145
rs72z
rs72z's Avatar
Well i didn't get a lot done this weekend, my son had a basketball tourney.
I did get the driveshaft in only to find out that i just had 2 & 3 gear. I had read that when using the underhood fuse block that the trans had to have power to it from a different circuit. I had it hooked like i had read, but that was for a 2000 model harness and mine is a o4. So i found out what pin fed the trans 12+ and traced it to the fuse box and fed it 12+ from adiffrent source. Now it has all foward gears!
I did have a buddy of mine give me a set of aluminum wheels. The only problem is he had them chromed and someone did a crappy job. Most of the chrome has come off. I am going to get them powder coated either silver or chrome.
Old 12-14-2011, 11:30 PM   #146
rs72z
rs72z's Avatar
Wink Re: crew cab short bed build " clifford"
Not much progress, but i do have a couple of pics of the floor.
I'll give you the bad one first so that you Northern guys don't get jealous
I also plan on painting the bed and fenders this weekend.
Old 12-15-2011, 02:27 AM   #147
Devillusion
Devillusion's Avatar
Not all northern trucks are bad......in fact some are better...lol.
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s
1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater
1963 C10 reg cab long box
1970 Chevelle
1968 Biscayne 2dr post
"...there is no excuse for what I am about to do, but dangit....it's gonna be fun!"
Devillusion is offline   Reply With Quote
Old 12-15-2011, 08:34 AM   #148
rs72z
rs72z's Avatar
I was just poking a little fun.
I have watched you build very clean truck to start with, and that dash is looking cool
I guess the passenger side of the windshield or the heater core has been leaking for a while. The jute was still wet and it hasn't been outside in a couple of months.
Old 12-15-2011, 11:58 AM   #149
Devillusion
lol, ya I know.........was just givin' you the gears...lol. All good!
And thanks, wish I could find the time lately to get something done. The kids or the wife seem to have something on the go everytime I turn around. Think I've only been in the shop for a couple hours in the past month now...ughhh!
1970 Chevelle
Old 12-15-2011, 12:54 PM   #150
rs72z
rs72z's Avatar
Yea i know what you mean. I am juggling working on the truck with my two boys basketball schedules. That's ok thought, the kids will only be young once.
