Old 12-18-2011, 06:39 PM   #126
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
Re: Mesquite 1966 C10 - LS3 W/Air Ride
I cant believe how clean the shop is!!!super nice build nice work i just got my ls 5.3 runnung and drove it and it was great yours should be awesome!! Thanks for all the pictures!!!
gostranger is offline   Reply With Quote
Old 12-19-2011, 01:53 AM   #127
66ChevyMax
66ChevyMax's Avatar
Not sure yet, I like the bench seat, but I'm also thinking about building a center console out of mesquite as well.
Originally Posted by duallyjams View Post
Are you keeping the bench seat or switching to buckets ?
Thanks, I learned a year ago on this site pictures are worth a thousand words and that saves me a thousand misspelled words
Originally Posted by youngrodder View Post
Very impressive build....
Keep up the great work (and pics)
Marc
Thanks, I can only imagine (for now) what it will be like to drive
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 12-19-2011, 02:00 AM   #128
66ChevyMax
66ChevyMax's Avatar
Got the front of the motor installed, air conditioner compressor is tight, I will have to drill some holes in the rails to install the bottom two bolts, or remove the motor again.
I sure hope someone makes some short 90deg A/C line.
Craig
Old 12-19-2011, 02:04 AM   #129
66ChevyMax
66ChevyMax's Avatar
I'm very surprised at how short the throw of this transmission is, cross member is temporary.
Craig
Old 12-19-2011, 02:27 AM   #130
Captainfab
60-66 Nut
Yeah, the A/C mounting seems to be about the biggest issue with the LSx swaps. I haven't kept up on what guys are doing about it, since I am still working with Gen I engines. If you haven't been there yet, you might check out possible solutions in the LSx Swap section......
http://www.67-72chevytrucks.com/vboa...ysprune=&f=206
Old 12-19-2011, 11:28 AM   #131
E911manager
Wow.. That is so nice. You are gonna have a truck that is by far better then a new one you can buy at any dealership.. I know the planning that goes into this is extreme. Do you sleep at night?
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice
http://67-72chevytrucks.com/vboard/s...d.php?t=492640
E911manager is offline   Reply With Quote
Old 12-19-2011, 01:47 PM   #132
Clownpuncher
Clownpuncher's Avatar
Man Im glad you posted pictures of the Vette accessory belt system. I new it would clear..haha The truck setup that most people run is uber ugly. After owning a Nova with an LS2 and Vette accessories it looked like it would clear on these trucks. You just proved it..
Thanks again!
Clownpuncher is offline   Reply With Quote
Old 12-21-2011, 12:53 AM   #133
66ChevyMax
66ChevyMax's Avatar
Sleep like a baby "when thing go perfect" no so much when they don't.
Glad the pics help, I'm glad to do it. I was nervous until the A/C unit was finally in.
Thanks again!
Craig
Old 12-21-2011, 01:10 AM   #134
66ChevyMax
66ChevyMax's Avatar
Well the front rail has two new holes. Lower left hole is half way on the cross member bolt. To get the lower left bolt in it has to go in first and I had to shorten the treads by about 1/2".
Upper left bolt was replaced with a standard bolt, it's all tight now!
Starter is in.
Craig
Old 12-21-2011, 01:17 AM   #135
66ChevyMax
66ChevyMax's Avatar
Rear disc brakes are in "finally"
Craig
Old 12-21-2011, 01:24 AM   #136
66ChevyMax
66ChevyMax's Avatar
Two more
Craig
Old 12-21-2011, 02:27 AM   #137
likaroc13
Rollin' Old Skool
niiiice!
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 12-21-2011, 12:08 PM   #138
Iron-Butt
454 club
Iron-Butt's Avatar
nice build
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 12-21-2011, 12:45 PM   #139
Clownpuncher
BTW did you ask to have a double bellowed air bag in the bag? My understanding was thatn type of bag was used for hauling it's almost to much for the back end of our trucks, versus just a single sleeved bag that is much softer and really on handles the hieght of the vehicle.
Just curious
Old 12-21-2011, 12:50 PM   #140
SCOTI
SCOTI's Avatar
Just curious
Sleeve bags work when mounted directly to the rear end housing.
Double convoluted bags work well in a truck arm application because the leverage is increased because they're located further forward of the rear end vs when the bag is mounted directly to the rear end housing. The dbl convoluted bag is the standard bag spec'd for these truck arm set-ups.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-21-2011, 12:58 PM   #141
custom63
custom63's Avatar
Awesome, clean and well thought out work man!
Those CPP rear disk setups look well made. Any install issues?
BTW what ever happened with that BOSS front wheel issue? I know alot of guys on here have talked about how the BOSS 338's have fitting issues with the larger 1 1/4" rotors and wont fit over the hub unless you have it machined down.
For your engine I see that you used CPP perches...are those the motor mounts and adapter plates they sell as well? Kinda like a complete kit?
What headers are you thinking of running?
Keep up the great work and keep the pics coming!
Tommy~
The difference between genius and stupidity is that genius has its limits
-- Albert Einstein
63 build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=317341
custom63 is offline   Reply With Quote
Old 12-21-2011, 02:06 PM   #142
Clownpuncher
Makes more sense with the amount of leverage these arms have..
Old 12-21-2011, 03:34 PM   #143
66ChevyMax
66ChevyMax's Avatar
Thanks a million
niiiice!
Originally Posted by Iron-Butt View Post
nice build
Craig
Old 12-21-2011, 03:36 PM   #144
66ChevyMax
66ChevyMax's Avatar
Well obviously scoti knows more than me. This is my first experience with bags, I've used air shocks before but not bags.
This kit it the Level 3 kit from ridetech, as listed on their website with no modifications.
Just curious
Craig
Old 12-21-2011, 03:56 PM   #145
66ChevyMax
66ChevyMax's Avatar
Thanks custom, drivers side rear disc went on with no issues, I had to persuade the bracket on the passenger side a little. Outside pad was way too tight.
As for the BOSS problem, there is apparently two versions of this wheel out there. The first pic on left is the one that fits, the second does not. Notice the difference in the center bore and the cap mounts completely different as well.
CCP mounts and perches work well and come as a kit. They do create header problems. I tried some BBK headers for a camaro but no luck (pic below) sanderson headers has one (shorty) that looks promising. Talked to Doug Thorley Headers they say they will have one in about 6 weeks?
Craig
Old 12-21-2011, 03:58 PM   #146
66ChevyMax
66ChevyMax's Avatar
Fellow Texan, you da man!
Craig
Old 12-21-2011, 04:20 PM   #147
SCOTI
SCOTI's Avatar
Where exactly is Wolfforth anyway?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-21-2011, 05:05 PM   #148
66ChevyMax
66ChevyMax's Avatar
Just West of Lubbock, actually the two have grown together. Frenship School District.
Craig
Old 12-21-2011, 05:20 PM   #149
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
66ChevyMax, I used the Sanderson Shorties, CSLS1 is the part number, I am very pleased with them.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-21-2011, 05:49 PM   #150
SCOTI
SCOTI's Avatar
Just West of Lubbock, actually the tow have grown together. Frenship School District.
Ahhh.... I was just in Lubbock last Wednesday (Texas Tech). My GF's daughter was in a car accident the night before their semester ended for the holiday break. We had to go pick them up & move 'em home for a month.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
