Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 03-17-2013, 03:04 AM   #126
y5mgisi
Second Chance Program
y5mgisi's Avatar
Re: project pacific wonder
Nice work! Subscribed!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 03-19-2013, 02:06 PM   #127
Coboyle04
Coboyle04's Avatar
well subscribers...stay tuned we should have the intercooler/radiator installed this week, following that the install if the accesory bracket with alternator, ac compressor, ps pump, etc....
we did not expect to have as much room as we do between the motor and radiator and had planned to squeeze an electronic fan.....with the room we now have we will install a mechanical fan instead wich will run off the fan belt. never had much luck with the elctric ones anyways.
hope to have some more pictures for you soon.
Chuck
Coboyle04 is offline   Reply With Quote
Old 03-28-2013, 10:45 AM   #128
Coboyle04
Coboyle04's Avatar
power steering pump is installed and lines are nearly finished being routed....a couple of mods need to be made with the tube bends.
the coolant intake is installed and ready as well as the water pump.
the mout for the mechanical fan is here.
Chuck
Old 03-28-2013, 10:49 AM   #129
Coboyle04
Coboyle04's Avatar
the lower mount for the intercooler/radiator is complete-minus the paint.
final mods to the intercooler are being made. the port wasnt in a great location.
The passenger side port on the radiator was a little too close to the inner fender so we had to notch it out.
Chuck
Old 03-29-2013, 09:39 AM   #130
blfuller123
blfuller123's Avatar
This is really an amazing build you have here!!!
blfuller123 is offline   Reply With Quote
Old 03-29-2013, 12:14 PM   #131
Coboyle04
Coboyle04's Avatar
forgot to post this one....more pics to come soon....we hope to fire it up for the first time by monday
Chuck
Old 03-29-2013, 07:09 PM   #132
logansdad
logansdad's Avatar
Roll Coal
logansdad is offline   Reply With Quote
Old 03-29-2013, 07:32 PM   #133
Coboyle04
Coboyle04's Avatar
Chuck
Old 03-29-2013, 07:34 PM   #134
logansdad
logansdad's Avatar
when you crank it up and press the pedal on the right you'll see what I meant.
Old 03-29-2013, 07:36 PM   #135
Coboyle04
Coboyle04's Avatar
gotcha...i cant wait
Chuck
Old 04-01-2013, 11:43 PM   #136
mosesburb
I had a V-8
mosesburb's Avatar
Man, that water inlet is friggin' sick!! I was wondering where you were going when you posted pics of that lifting bracket. I sure didn't expect that!! Very nice!! This whole conversion is turning out very nice. More pics!!
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
Old 04-02-2013, 01:35 PM   #137
Coboyle04
Coboyle04's Avatar
thanks moseburb....maybe we will cross paths when i finally get this pig on the road.
Chuck
Old 04-02-2013, 01:37 PM   #138
Coboyle04
Coboyle04's Avatar
here is the actual fan we will use and the top mounting plate for the intercooler/radiator is about finished....it looks white due to the protective film on it.
Chuck
Old 04-02-2013, 05:33 PM   #139
y5mgisi
y5mgisi's Avatar
I cant wait to hear what you think of the 4bt as a burb power plant. I have heard, that in stock form for the most part they put out about 300lb.ft of torque which is the same as a TBI 350. Im just curious if the 100ish hp they have will have an effect on its hill pulling power. For example, a TBI 350 burb will pull itself and a trailer full of wood over mild grades while maintaining 55mph fairly easily. I wonder if the 4bt will do the same. Furthermore what i wonder is if a slightly modified 4bt will, if a stock 4bt wont. Either way, i think they are super cool motors and i want one!
Old 04-02-2013, 06:17 PM   #140
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
How about 1000hp 4bt? http://www.zzcustomfabrication.com/4...ct_page08.html
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 04-02-2013, 10:54 PM   #141
y5mgisi
y5mgisi's Avatar
Sorry for the hijack Coboyle04.
1000hp is fine and dandy. Im more looking at a woods truck type situation. The fuel efficiency and "tractor" like qualities of the 4bt make it an appealing motor for a woods/hunting/expedition type truck (ie. my 78 GMC 3/4ton 4x4) but i cant help but worry myself with its potential lack of grunt as the truck gets loaded with fire wood and still needs to drive home and hopefully maintain 55mph the whole time. Basically, i look for the perspective of someone like the OP to hear their thoughts on the 4bt power. If it sounds like it may not cut the mustard without heavy modification, i would just go the way of the 6bt. Im not trying to pre judge the 4bt by any means! I know lots of folks use it and love it! I just wonder if its the right motor for ME, and i can help make that decision with feedback from folks like the OP, who are using it.
Old 04-03-2013, 12:01 PM   #142
Coboyle04
Coboyle04's Avatar
They guy who is installing it has one in his 2001 expedition and says he had close to 30mpg all the way from portland to san fran ...even through the passes at 65 mph
but the 4bts can be built for whatever you want....i wanted mine for mpg
you should look up the 4bt camaro video on youtube
Chuck
Old 04-03-2013, 12:03 PM   #143
Coboyle04
Coboyle04's Avatar
i am nervous and excited to see how this holds up....what my mpg actually is, top speed, acceleration and towing.
Chuck
Old 04-03-2013, 01:38 PM   #144
Coboyle04
Coboyle04's Avatar
update: pics will be comming soon, we are going to use a remote oil filter to make room for alt and ac compressor, air box and cooler tubing..anyone ever use one?
Chuck
Old 04-12-2013, 12:23 PM   #145
Coboyle04
Coboyle04's Avatar
Installed my new e brake cable, new reverse light lenses, and here is apicture of the air box we will be using
Chuck
Old 04-12-2013, 01:40 PM   #146
Coboyle04
Coboyle04's Avatar
ready for the belt, you may notice the fan blade is close to the frame..we will be notching this out to give it a little space.
Chuck
Old 04-12-2013, 01:43 PM   #147
Coboyle04
Coboyle04's Avatar
we are going to have to shorten the tube comming off the intercooler but it will be a nice clean fit when its done.
Chuck
Old 04-12-2013, 01:48 PM   #148
Coboyle04
Coboyle04's Avatar
mounting brackets are completed on the intercooler/radiator
turbo is in and the tubes are just about finished.
the AC lines are about done, just waiting to see where and how we mount the air box and run the lines. then we can make a down pipe and wire it all up. then start up the beast.
Chuck
Old 05-09-2013, 12:06 PM   #149
Coboyle04
Coboyle04's Avatar
the air box installed with machined hinge bracket
Chuck
Old 05-09-2013, 12:09 PM   #150
Coboyle04
Coboyle04's Avatar
transcooler and sway bar mounted. the cooler is actually angled more than it looks......if it doesnt cool enough we can easily adjust its angle or move to a better location
the front bumper back in place.
Chuck
