Old 09-16-2016, 01:44 AM   #126
tetfemal
Re: "Mable" 1959 Apache Build On A S-10 Frame
Originally Posted by Task Force Era View Post
To make life so much easier with replacing just about every part of the 59 suspension I bought a 92 ext.cab S-10 off of craigslist that had been wrecked in the front a little for $500 bucks. Everything is there even a 4.3 V6 that fired right up! So with the S-10 frame I have updated brakes, steering and suspension. Many problems solved with this purchase...
Hated stripping it down. Coulda been a good little beater truck. But sacrifices must be made, haha
I'm no fabricator by no means and have no shop to work in so a good friend of mine (Nathaniel) is handling all the welding and technical ****...
Chopped down the frame 7 inches to get the wheelbase lined up and have the front wheels more centered and new cab mounts built. Just a rough pic, not finished
Thinking about buying an Apache. Should a single cab long bed s10 be used instead of the extended cab?
tetfemal is offline   Reply With Quote
Old 11-05-2016, 03:24 AM   #127
55dude
55dude's Avatar
Re: Eisenhower '59 Apache Build On A S-10 Frame
they made way more extended cab S10 trucks than long beds, you will spend less time cutting out 6" of frame than locating a long box S10.
55dude is offline   Reply With Quote
Old 11-12-2016, 08:45 PM   #128
big_moss
big_moss's Avatar
following and gonna use a lot of info from this thread. about to start on my girlfriends 59 32 series and wanting to do a later model frame swap. glad i found out that it is do able on an s10. i also have a 07 silverado front clip i was wondering if it would fir but it seems to be a little wide
big_moss bagged 51 3100 build
big_moss is offline   Reply With Quote
Old 05-07-2017, 12:45 PM   #129
goathog02
Is the regular/long more of an exact match?
goathog02 is offline   Reply With Quote
Old 07-25-2017, 11:51 AM   #130
ORBowtie
Thank you for all the great information! This will be my winter project on my '59 3100. Only problem is I can't see any of the pictures s is there something I can do to see them?
Either way the info is still awesome!
Cheers!
ORBowtie is offline   Reply With Quote
Old 08-22-2017, 07:21 PM   #131
gmoney38
What he said. The pics are not there. What do we need to view the pics?
gmoney38 is offline   Reply With Quote
