Old 01-18-2014, 12:15 PM   #126
TommyDuncan
Re: 1966 GMC 305 V6 Service
Originally Posted by awbrown View Post
rufton , what port do you have the vacuum on now ?? From what you are telling us it looks like it is on the ported vacuum , it should be on manifold vacuum .. all the vehicles I have had got much better milage on manifold vacuum than ported...
Anyone else have an opinion on this?
The Holley PDF says to connect it to ported. I tried both but I made so many changes at once that I haven't figured it out yet.
TommyDuncan is offline   Reply With Quote
Old 03-10-2014, 05:01 AM   #127
monolith
Zero Albedo
monolith's Avatar
Gorgeous write up!
Makes me want to drag my 64 out of the back 40 and see what the racket was all about and maybe try to do something about it.
Baz
"Deserve's got nothin' to do with it."
66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467
65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432
65 Chevy Panel (former U.S.Navy truck)
64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348
64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now)
68 Dodge Charger
monolith is offline   Reply With Quote
Old 11-04-2014, 09:42 PM   #128
Rufton
Thanks for the compliments.
I took the GMC 305E on an I-75 trip 3-4-14 and got 13.4 mpg and 14.1 mpg driving approx 70mph. Need to get her out more but I've been tied up.
Rufton is offline   Reply With Quote
Old 11-30-2014, 02:52 PM   #129
starrman30
starrman30's Avatar
wow what tranny do you have? my 69 feels like its revving up to 5000 rpm when I hit 60MPH. I'm pretty sure they al came with the 4 speed granny low tranny, except the automatic version. I have never tried to hit 70 MPH
starrman30 is offline   Reply With Quote
Old 07-22-2015, 12:45 PM   #130
gmcbrandon
Great thread with tons of information and detailed pics. I myself am rebuilding one of these and was wondering did you use as far as the rear main seal? I order felpro set from summit, seal bs40048 and its just a rope seal, curious if you were able to find a two piece rubber or you settled with the rope seal? Thanks alot
gmcbrandon is offline   Reply With Quote
Old 10-22-2015, 09:28 PM   #131
BigDan3131
BigDan3131's Avatar
I know this is an old thread but now that you seem to be a master rebuilder of these engines have you thought about adding some performance upgrades to them? From the look of the heads they could handle much larger valves and do they really need 4 rings on the pistons? Knife edging the crank to make it lighter and blueprint the rods too. Not in the sense to make it rev higher but to increase performance at its regular rpm range. Has anyone stuck the massive 472 with its 5" bores in one of our trucks yet?
My 65 had the 305E behind the Powergilde, was there an adapter plate needed to mount the glide to the 305E? I know where one is...can it be used to bolt other autos to it?
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 10-22-2015, 09:37 PM   #132
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Guy stuck a 478 in a 68 Chevy so I know its possible. Also a guy took a 478 and put hemi pistons and rods in it. Had a custom cam ground. Catapiller diesel valves were installed in the head. Needless to say it KILLED anything near its cubic inch. Had a WAY better cool factor than a BBC. lol Guy who owned it said it would do 6K. I installed a 4 barrel on my 305. Did a 4 down to 2 adapter. Worked out really nice. Plan to install flat top pistons, shaved 351M heads and have the intake machined to directly fit a 4 barrel. Might have a little more duration added to the cam.
https://www.youtube.com/watch?v=mdZlZlWRRMI
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 09-30-2018, 12:01 PM   #133
Matt's k5
BLAZER THIRTY!!
Matt's k5's Avatar
Originally Posted by Rufton View Post
Converted clutch to diaphragm a few years ago and like it.
question for you, did this kit work great? no modifications of the disc? I'm looking for a clutch for my 62 with the 305 I found for sale on ebay nu551 and wanted to verify before purchasing thanks
49 chevy 5 window 20 year project (sold)😟
57 ford fairlane (dad's car never got to it before he passed away R.I.P I LOVE YOU DAD.)
62 GMC 305 V6 custom L/B
72 HIGHLANDER K5 BLAZER 2nd owner
71 K5 MAMMA'S RIDE!
63 GMC 4X4 305 V6
62 GMC SHORT BED SERVICE BODY V6 (STUMPY)
74 GMC CUSTOM 1500 L/B
Matt's k5 is offline   Reply With Quote
Old 09-04-2022, 01:48 PM   #134
factorystock
factorystock's Avatar
Old post yes, but, there are plenty of V6 owners out there that might find this old post and this article I found recently interesting. Mileage reported by Rufton is almost indentical to the owner of the GMC in this 1967 letter to the editor. The "cold" plug and the "hotter" plug confusion may be the culprit of some V6 owners reporting lower gas mileage than they should be getting.
factorystock is offline   Reply With Quote
