Old 04-04-2014, 12:42 PM   #126
6lcummins
Re: Ultra Family and Hauler Mobile
Originally Posted by ryanroo View Post
ill go ahead and break it down since Ryan said it all wrong and you are speaking in turbo code.
the inducer is the inlet side of of the wheel, regardless of its orientation. the exducer is the outlet side of the wheel. so, in a turbocharger, the inducer side of the compressor is the side that you see when you look down its throat. the exducer side of the compressor is the big side that is at the back of the compressor housing.
the exducer of the turbine wheel is the small side, or the one you see when you look up the turbos butt. the inducer is the big side of that wheel in the front of the exhaust housing.
since the space available for the compressor to draw in air is the inducer and the space available for exhaust to exit the turbine is the exducer, you can get an idea for the air flow ability and depending on all kinds of other factors the power it will be able to make from knowing the size of the inducer on the compressor and the exducer on the turbine. the area of the exhaust housing, or the third number given in the size helps you determine how much fliud can pass through the housing at a given pressure. that will help determine the lag or how fast the turbo spools and has an effect on EGTs and drive pressure.
this thing seems to have a target on the gonad area, or maybe the wallet. but at least it should be a nice well done rig when finished! Ryan had it running/driving briefly, but it took a digger when the engine decided to knock.
So where did you copy and paste that? And 90%of people will get lost when describing the fun of proper turbo sizing so I have found it best to just keep to the KISS method on them.
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK"
ASSEMBLY THREAD
6lcummins is offline   Reply With Quote
Old 04-04-2014, 09:11 PM   #127
ryanroo
ryanroo's Avatar
off the top of my head at twenty after five in the mornin, dawg. i have been compared to an encyclopedia at least once...
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 04-08-2014, 04:47 PM   #128
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Last Saturday I pulled the rear axle apart and found the thumping noise. The parts are here so now the fun begins. Install of all new bearings and ring and pinion. Yeehaw!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 04-08-2014, 08:53 PM   #129
6BT 56
6BT 56's Avatar
Yep that would do it . I remember when my 99 3500 dodge chipped off a tooth. 250 mi from home and 1100 mi left to deliver the boat . I pulled the cover off in the truck stop parking lot . Realised it was fawked by now so I just re filled it and carried on as long as i could in 4X4. Made it another 150 ish mi and the thumping was actually making me sick to my stomach it was so bad . Pulled over and scratched my head for a while ?????????? Ended up taking the rear half of drive shaft out , leaving front in the hanger bearing and continued on in 4x4 . Or front wheel drive i guess... lol... Took it real easy with abt 6000lbs in tow (empty return )and made it home 2700 ish mi round trip . Thank god for 4x4 !
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 04-08-2014, 11:13 PM   #130
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Haha, awesome story 56!
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 04-09-2014, 08:12 PM   #131
6BT 56
6BT 56's Avatar
Ugh . Not so awsome when your living it Lol.....
Yay look at me I'm maken $$$$ Boo to me. When I get home I will put every penny of it back in to the truck . The story of my life .....
Old 04-09-2014, 10:40 PM   #132
Dieselwrencher
Isn't that the truth!!
Ryan
Old 04-09-2014, 11:51 PM   #133
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Sorry, yeah probably not so much fun at the time. Makes a good story looking back though!
Haha yep that's usually the way it goes...
Tony
Old 04-30-2014, 08:14 PM   #134
superduty_59
I loved reading your longhorn thread but I think I love this thread more. I read a thread about another guy who did a CR in an EX a few years ago. He made everything work as it should. Sucked about the drain plug. Sounds like my luck.
I always wanted to do a Cummins Ex for the wife but have never found one cheap enough. So my next thought was a Tahoe. I found a few cheap. I like your idea of a 24v VE. How is the performance?
superduty_59 is offline   Reply With Quote
Old 05-05-2014, 07:03 PM   #135
Dieselwrencher
The VE 24v runs pretty good. I'm still tuning on it and playing with it. I'm probably going to back the timing off a little more to try and reduce combustion knock to quiet it down. It's pretty loud compared to a vp or even a p pumped one.
Ryan
Old 07-07-2015, 05:05 PM   #136
DuramaxC10
update ?
1968 Chevy C10 6/8 drop ( great grandpas truck) under construction
1972 Ford Bronco project
2006 chevy Silverado 2500hd dd
1995 k2500 solid axles 12v cummins crew cab
DuramaxC10 is offline   Reply With Quote
Old 07-08-2015, 04:41 PM   #137
Dieselwrencher
The airtex lift pump I put on there in the begining crapped out so I put an airdog 150 on it and it's been happier. The wife has put 12k on it so far since last year. Now I've got to fix the a/c and it's golden. The new napa clutch on the compressor doesn't want to work. Go figure. (It's been that way since last year. I just haven't gotten to it yet.)
Ryan
