Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 11-05-2013, 01:51 AM   #126
swamp rat
swamp rat's Avatar
Re: Rat repair.
One vote for Skyjackers...
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-05-2013, 01:56 AM   #127
swamp rat
swamp rat's Avatar
Re: Rat repair.
I did find shocks on the fox webpage that fit my truck properly, but according to the BDS tech guy shocks direct from Fox are not valved the same and the Fox shocks they sell the valving is specific for their springs... So i just emailed Fox to ask them if its true.... The webpage does say application specific valving..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-06-2013, 09:44 PM   #128
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Rat repair.
This is a great thread. I really enjoyed reading it.
Sorry to hear about your tribulations with the shock absorbers. I'd be pretty skeptical of the shocks being special made for BDS. Sounds like a great way to up the price on a shock absorber.
Old 11-06-2013, 10:56 PM   #129
swamp rat
swamp rat's Avatar
Re: Rat repair.
Thanks for the comps, sometimes i think the thread needs a little less talk and a lot more action.. LOL!
Actually there Fox Shocks that are just Valved to BDS's specification.. BDS charges $115 for then each if you buy them outright but to upgrade from their regular shocks to the Fox's its an additional $269 or something like that, i don't know how much they would charge for the regular white shocks or who makes them, maybe they turn a little profit with the upgrade??
So i talked to my local shop about it again, i decided I'd give the front shocks a shot even tho they only have 4.25" of compression travel left when sitting on the wheels, they did order me different rear shocks that give me more travel plus BDS is tossing in a set of the 5/8's U bolts that my truck had originally to replace the 1/2" set that came in the kit..
I figure i mainly drive on blacktop with an occasional dirt road for camping or maybe dirt biking so i should be ok, but i do have some concerns if i get into a pot holed out spot on the road. it may be a mistake but i admittedly am curious about how the shocks handle.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-06-2013, 10:59 PM   #130
swamp rat
swamp rat's Avatar
Re: Rat repair.
I did pull my stabilizer off so i could set my toe in and should be reinstalling it tomorrow, but going to try installing it a little differently. I'm figuring i'll give the breaks another shot this weekend cause i get another weekend off, i sure hope its not raining!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-09-2013, 04:06 PM   #131
swamp rat
swamp rat's Avatar
Re: Rat repair.
Maiden voyage sans shocks and stabilizer, brakes seem to pull a little to the right when going forward, don't know if its just the crown in the road or not, seemed to not pull at all when in reverse. I just went around the block for the time being till i get shocked. All the calipers are grabbing the disks ok, all the surface rust is rubbed off.
Pretty happy with the stance of the lift kit, its a little more level than the old Rancho kit but still a little higher in the back. When the time comes to tow with it i may have to put some air bags on it too.
Now for some possible bad news, the fluid was leaking out of the master cylinder lid! sigh.. i took it off and wiped everything down but not too convinced that the new lid is flat, i went ahead and reversed it for now even tho its symmetrical, if it continues to leak i hope the auto parts store can find me a better one without doing an exchange, and before i totally distroy the paint on it and the surrounding area.
Parked back under the cover for now finally, time to clean the driveway! Tonight- Steak and a beer!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-10-2013, 10:26 PM   #132
freakshow108
freakshow108's Avatar
Re: Rat repair.
Congrats brother! I know how that feels, the first drive. They are only little bugs to be worked out. Hope to see you out and about.
freakshow108 is offline   Reply With Quote
Old 11-11-2013, 01:00 AM   #133
swamp rat
swamp rat's Avatar
Re: Rat repair.
Welcome back Randy!
I think the brakes pulling to the right may be air in the lines, unfortunately my vacuum bleeder turned out to be a POS. I need a better way.
It will be a bigger bug if the auto parts store tells me if i wanna get a better lid to the master that i have to yank it and do a complete master exchange.. Lets hope its gonna seal ok.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-14-2013, 12:52 PM   #134
Skid99
Re: Rat repair.
looks killer man.
i think ill keep the drum brakes on mine though since i plan to pull a goose neck with it once in a while.
2004 GTO H/C/I/E 6mt 430hp
2001 2500HD 6.0 Gasser Leveled on 33's
73' C10 SWB 5.3 L59/4L60E 4/6 Dropped
70' K/20 "Family Heirloom" 292/SM465/NP205 - Project
Skid99 is offline   Reply With Quote
Old 11-14-2013, 01:52 PM   #135
swamp rat
swamp rat's Avatar
Re: Rat repair.
Thanks for the comps Skid99!
I have been sidetracked getting my seat frame ready to take to the Upholstery place this Saturday, its a good day to head that way (up north a ways) because the guy is a 67-72 truck nut and he's having a truck show this Saturday.
I bought this frame about 2 years ago at a swap meet, its for the deep foam seat, the frame has developed some rust so i have been sanding it down and primer and paint, i have the bottom sanded and primed, have to get the top sanded and primed today, and if i have time the first top coat of paint on the lower.
Test fitting the American Cushion Industry's foam, Bought the seat cover here on the forum from the vendor Truckseats.
I could use another seat bracket adjust lock if someone has an extra one.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-14-2013, 02:37 PM   #136
faribran
Re: Rat repair.
are you happy with that foam cushion ?... i need to do the same thing.
faribran is offline   Reply With Quote
Old 11-14-2013, 08:36 PM   #137
swamp rat
swamp rat's Avatar
Re: Rat repair.
It from my understanding is the highest quality foam on the market, its made in America and not the import stuff. EDIT, but i should add i have not sat on the new foam yet, i have sat on truck seats with the stock 6" foam and they are a lot plusher than the spring/2" foam seat.
You also need to know if you have a spring seat or a full foam seat frame, the replacement cushions are made for the full foam seat only. How you tell is to look at the bottom of your seat, if the springs run straight across the bottom from front to back its a fill foam seat, if the springs arch upward then its a spring seat. A full foam seat has a good 6" of foam, the spring sear has only 2" of foam.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-15-2013, 05:25 PM   #138
swamp rat
swamp rat's Avatar
Re: Rat repair.
Earlier in my build i was using Phosphorus acid to coat my axles and U bolt plates ect, It works ok, it covers the rust and turns it to a black iron oxide (i think that was the name)
2 days ago i was reading another build thread and they prepped the rusty parts with Muratic acid, the parts, cast rotors and hubs were unbelievably void of rust, so today i bought some to work on my seat tracks.
When i first opened the jug the fumes started rolling out of the jug, i knew this was some real toxic stuff and in for a nasty job ahead. I first tried to pour it in a new spray bottle, it sprayed fine but the bottle was leaking allover and i didn't buy rubber gloves, big mistake! so i washed up cause this stuff burns, then i filled an old coffee cup and used a brush, the fumes on this stuff are super strong and also toxic, the breeze was on and off so i had to hold my breath then step over to the parts then coat and back away and catch my breath.
It took about an hour to get the worst of the rust, but a lot of the surface rust melted off in about 10 minutes, not very good pictures and forgot to get before shots but these brackets were solid rust when i started. Another benifit was that it cleaned out the track so they slide super smooth now..
I have washed my hands with Dawn dish washing liquid 4 times now and the stuff is still on my fingertips, it slaked in, plus my fingers smell like rust too. Don't mess around with this stuff without being outside with lots of ventilation and heavy rubber gloves!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-15-2013, 05:29 PM   #139
Skid99
Re: Rat repair.
Dam that's impressive. Looks like new metal. I wonder how this would do on a frame? Did you jist wash it off with water afterwards
Old 11-15-2013, 05:37 PM   #140
swamp rat
swamp rat's Avatar
Re: Rat repair.
Yes just used the garden hose, i put it on full strength.
I think for a frame there would be way too much vapors and I'd recommend sand or media blasting.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-15-2013, 10:01 PM   #141
jaros44sr
jaros44sr's Avatar
Re: Rat repair.
Amazing stuff, and i thought my vinegar was good stuff....gotta try muriatic acid OUTSIDE
Nice work on your build
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-15-2013, 10:28 PM   #142
swamp rat
swamp rat's Avatar
Re: Rat repair.
No smoking dude..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-15-2013, 10:28 PM   #143
Tx Firefighter
Re: Rat repair.
You guys are figuring out my secrets and tricks. I buy Muriatic acid by the case at the pool supply store. Its 11 dollars for 6 gallons that way.
Look closely in the background. I use a ton of the stuff....
Its hell on rusty gas tanks too. Cleans them right up, inside and out.
Old 11-15-2013, 10:31 PM   #144
swamp rat
swamp rat's Avatar
Re: Rat repair.
Before i left for work i put some rusty bolts in that coffee cup and poured some Muriatic acid on them to cover, the cup was blowing fumes almost immediately so i took it outside of the garage..
I think if you poured this down the drain you would probably have to call a plumber!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-15-2013, 10:34 PM   #145
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Re: Rat repair.
Any luck with the pulling to the side under braking?
Originally Posted by Skid99 View Post
looks killer man.
Wouldn't discs be better for towing also?
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 11-15-2013, 10:36 PM   #146
swamp rat
swamp rat's Avatar
Re: Rat repair.
Yea that was a little cheaper than the $7-8 i payed for my gallon jug.. What do they use it for regarding swilling pools?? EDIT: I didn't have a magnifying glass to read the small print..
Ya know i tried a gas tank liner in a motorcycle tank called Kreem on time, its a 3 stage treatment, i said i'd never use the stuff ever again, it discolored and started to flake away at the filler.. Wish i had known about this stuff then, but the trick would have been keeping it off the paint.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-15-2013, 10:47 PM   #147
swamp rat
swamp rat's Avatar
Re: Rat repair.
I had to put a hold on the brake issue this week to get my seat frame prepped and painted, tomorrow i have to head off to a truck show and drop off the seat, new foam and cover to an upholstery place, i'm almost done, will be going home here in a few to put the final black paint on the sliders, they are primed already.
I have a plan of attack on the calipers, just got to make the time to get it done, i'm hoping Sunday i can find the time.
Would Disks be better for towing? I don't know if it will matter much ether way, I have the proper Proportioning valve, plus the calipers are the same as the fronts, and normally the front brakes supply about 80% of the braking power, now the Drums have more surface area, but is the slave cylinder any stronger or weaker? I don't know.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-15-2013, 10:48 PM   #148
Tx Firefighter
Re: Rat repair.
I'm no pool guy, but my in laws own a company. You use chlorine and Muriatic acid to keep the water proper. Its way common to see a pool owner pour a gallon of Muriatic acid into the pool to adjust something or the other.
Internet research shows......"Muriatic acid, or hydrochloric acid, is used in swimming pools to lower the pH and total alkalinity of the pool water."
Old 11-15-2013, 11:18 PM   #149
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
Re: Rat repair.
This is good info here I might have to do something with my seat.
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 11-15-2013, 11:25 PM   #150
Mr Chevorlet
Rusty Nuts
Re: Rat repair.
Swamp rat it looks like you went through hell on your suspension but it looks great. And your truck looks nice with the lift. Like the tires and wheels also. Great job nice truck.
Larry
Mr Chevrolet
