Old 03-20-2014, 06:07 PM   #126
aotte1
Re: 1986 Chevy C10 SWB Step Side
Actual bolt picture/ description.
aotte1 is offline   Reply With Quote
Old 03-20-2014, 06:10 PM   #127
aotte1
If need more info let me know.
Old 03-20-2014, 06:12 PM   #128
aotte1
Pictures of power coating items got back today.
Old 03-20-2014, 06:16 PM   #129
aotte1
Front inner fenders.
Old 03-20-2014, 06:17 PM   #130
aotte1
Other parts
Old 03-20-2014, 06:19 PM   #131
aotte1
Close-up of parts
Old 03-20-2014, 06:20 PM   #132
aotte1
Fan part number
Old 03-20-2014, 06:22 PM   #133
aotte1
Last picture
Old 03-20-2014, 07:19 PM   #134
aotte1
Continuing to work on process for R/R of the bolts. So far plan is:
1). first cleaning in tumbler ( done);
2). next final clean in cabinet with aluminum oxide of specific grit ( will post size later);
3). Immediately apply ceramic coating after final clean with touch up gun .08 at 18 to 20 PSI, the coating should be enough to cover item and no more, once covered do not applied second coat ( more on coating process after used , so can report results); and
4). Lastly dry coating.
Probably be a week before getting to do first run.
Les
Old 03-20-2014, 09:52 PM   #135
jetfast
Thanks, that's prefect. Those parts look great.
jetfast is offline   Reply With Quote
Old 03-20-2014, 10:41 PM   #136
aotte1
Touch-up gun nozzle is 0.8MM (correction for above post).
Old 03-21-2014, 08:44 PM   #137
aotte1
Below is picture of touch-up gun with 0.8 MM nozzle.
Old 03-21-2014, 08:45 PM   #138
aotte1
Another picture
Old 03-21-2014, 08:46 PM   #139
aotte1
Picture of touch-up spray gun.
Old 03-24-2014, 10:42 PM   #140
aotte1
Put media blast cabinet together tonight, will use it on this project and grandsons 1964, chevy K10. Bolts for putting the bed back together will be first item cleaned with aluminum oxide, grit 120. Will do report on how well it works, quality, assembly.
Old 03-25-2014, 04:02 PM   #141
jpnh
jpnh's Avatar
looks good.
jpnh is offline   Reply With Quote
Old 03-25-2014, 09:07 PM   #142
aotte1
Thanks Jeff for the support and help with restoring a step side bed.
I used the media cabinet today for first time to clean the bolts from taking the bed apart. The cabinet worked really well cleaning the parts. I really liked how the aluminum oxide cleaned!! I used 120 grit.
The pictures are of the bolts after they are cleaned.
Old 03-25-2014, 09:11 PM   #143
aotte1
I made a cleaning and coating holder for the bolts out of a sheet of aluminum, then drilled holes that would be taped to fit the bolts. For the nuts used a piece of wire to hold them.
Another picture
Old 03-25-2014, 09:44 PM   #144
aotte1
Right after cleaning/etching the bolts ( this was done as one step) I sprayed them with the ceramic material. The spray gun mentioned above worked really well. The bolts were sprayed at room temperature (70 degrees), about 18 PSI, coverage was one pretty light coat, just enough to cover. I we'll report back on how resistant to abrasion the coating is. So far preliminary tests look good.
Picture is right after spraying, before drying.
Old 03-25-2014, 09:47 PM   #145
aotte1
This the bolts after drying.
Old 03-25-2014, 09:49 PM   #146
aotte1
They have a satin appearance .
Old 03-26-2014, 09:50 PM   #147
aotte1
Step side bed body restoration panels
Today returned the left side step panel to vender, because of poor fit, it was just made wrong where it aligns with fender. It had a big gap. The restoration fenders I am using are no where close to originals either. It has been said here before many time, originals are the only way to go. I purchased restoration fenders, which are supposed to be better, but still not very good.
Another voice saying get original step side bed fenders if all possible.
Old 03-26-2014, 10:02 PM   #148
98Murray
98Murray's Avatar
Looking good!
98Murray is offline   Reply With Quote
Old 03-28-2014, 09:25 PM   #149
aotte1
Thanks,
Old 04-01-2014, 08:50 PM   #150
aotte1
The body shop is making progress, the bed is apart and pretty much ready for sealer and primer this week. I just need to confirm that a few of the new bed SS bolts are correct. Those that are going to be painted body color were very lightly etched with 120 grit aluminum oxide for good paint adhesion.
The cab and front fenders are moving along too. The fenders are also almost ready for sealer and primer. The windshield is out and the frame looks really good except for drivers side corner with a little rust but solid. The cab corners are being repaired too. They have been welded in and fiberglassed over for strength of seam. The following are a few pictures.
