03-19-2020, 08:10 PM | #126 |
Re: Got it one piece at a time... 51 chev
Can you post a pic of your box? Just curious how you built yours. Yes, groving the pipe worked out great
03-19-2020, 11:34 PM | #127 |
Today's project, I got the box pieces in place and all tacked together. I went with a new, stock tailgate, just trying to figure out how i will hinge and latch the tailgate now
03-20-2020, 09:56 AM | #128 |
Here’s a couple of pictures. I welded a stud in place for my lower gate hinge. I’m going with the hidden latches from classic auto industries as well. Hope this helps
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build |
03-21-2020, 10:30 AM | #129 |
Your box is looking good! I'm curious how your tailgate hinges look. I really like how you curved your pipe to meet top of the tailgate!
03-21-2020, 10:37 AM | #130 |
Got some work done at both ends of the truck today. My friend came over and installed my new intake manifold and my new Holley Sniper fuel injection system. The engine i'm using had TBI but it was old and I dont know much about wiring it up so this Sniper kit seemed like a good way to go. Seems like a simple install, it comes with all the wiring, fuel pump, filters and fuel lines,etc.I hear good things about these systems, hope it will work well!
03-21-2020, 10:41 AM | #131 |
At the back end of the truck I made myself some hinges for the tailgate. I wanted to keep it simple and clean looking, I think it worked out good.
03-21-2020, 10:48 AM | #132 |
I also played around with some ideas for the stake pockets. I always think the stock ones look a bit unfinished the way they just end with a straight cut at the bottom. I'm trying different ideas, Not sure yet if this is the final version, but I'll do something similar. Im making a few different patterns out of wood to see which I like best
03-21-2020, 01:16 PM | #133 |
i like it!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
03-22-2020, 12:23 AM | #134 |
Nice work! If you click on the link on the bottom of this post you will go to my build. That way you can see all the pictures of what I’ve done.
03-22-2020, 11:57 AM | #135 |
I spent the day yesterday building my stake pockets. I tried a few different designs and came up with one I like. I started off with bending up an"L" shaped piece for the sides of the stake pocket
03-22-2020, 12:00 PM | #136 |
Next I used my wooden pattern to cut out a left and right side piece with my plasma cutter
03-22-2020, 12:03 PM | #137 |
Wow! That is nice.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
03-22-2020, 12:03 PM | #138 |
Then I welded a strap to join the two pieces
03-22-2020, 12:05 PM | #139 |
Here is the finished stake pocket, all welded and smoothed off
03-22-2020, 12:31 PM | #140 |
doing killer work.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
03-22-2020, 01:44 PM | #141 |
So I bought some teardrop shaped tailights at least 6 years ago because I liked the shape of them. I wasn't sure where or how i would mount them on this truck, but after trying a bunch of different things, I think I have figured out a look I like! What do you think, Good or bad idea?
03-22-2020, 01:53 PM | #142 |
Definitely a good look!
03-22-2020, 03:07 PM | #143 |
What's wrong with that.....Nothing! I think it looks great! Thanks for sharing.
03-22-2020, 04:40 PM | #144 |
I like it!
03-22-2020, 04:42 PM | #145 |
Curious what size is the lens on that torpedo tail light. Is it a sealed beam style?
03-22-2020, 05:22 PM | #146 |
03-22-2020, 05:33 PM | #147 |
Ok. Thanks. I assume the light is a sealed beam replacement style. Wondering if there is a dimension for the actual sealed beam.
03-23-2020, 10:28 AM | #148 |
very nice work, well done
03-23-2020, 01:52 PM | #149 | |
Dsraven, this is what the light itself looks like, about 3 1/2 inches diameter |
03-24-2020, 12:03 PM | #150 | |
