View Poll Results: what light setup looks the best?
#1 current LED setup, Hella Rallye 4000 Compact Xenon pencil 8 29.63%
#2 current LED setup, Hella Rallye 4000 Xenon Euro Beam 1 3.70%
#3 BD Squadron wide cornering, Hella Rallye 4000 Xenon Euro 1 3.70%
#4 BD Squadron w.-crn., Hella Rallye 4000 Comp. Xenon driving, Hella Rallye 4000 Comp. Xenon pencil 2 7.41%
#5 BD Squadron wide cornering, Hella Rallye 4000 Xenon euro, Hella Rallye 4000 Comp. Xenon pencil 2 7.41%
#6 BD Squadron wide cornering, Hella Rallye 4000 Xenon euro, Hella Rallye 4000 Xenon pencil 0 0%
#7 HIDDEN BD Squadron wide crn, Hella Rallye 4000 Xenon euro, Hella Rallye 4000 Comp. Xenon pencil 1 3.70%
#8 HIDDEN BD Squadron wide cornering, Hella Rallye 4000 Xenon euro, Hella Rallye 4000 Xenon pencil 2 7.41%
#9 BD Squadron wide crn, Hella Rallye 4000 Comp. Xenon driving, Hella Rallye 4000 Comp. Xenon pencil 9 33.33%
current LED setup 2 7.41%
Multiple Choice Poll. Voters: 27. You may not vote on this poll
Old 07-23-2014, 10:49 AM   #126
Ol'_Blue78
Ol'_Blue78's Avatar
Re: 78 K20 custom delux "modern meets vintage" build thread
It is a fixed yoke on the t case but has a slip yoke on the driveshaft. The only thing making it hard to find is the spline count. Its a 16 spline and I found a few the right size in 27 & 32 spline counts.
1978 Sierra 1/2 ton lifted, 388/SM465/NP205, 35x12.50 on deep dish aluminum slot wheels.
Ol'_Blue78 is offline   Reply With Quote
Old 07-23-2014, 03:12 PM   #127
K20chevy
K20chevy's Avatar
Do you have a carrier bearing and a two piece drive shaft? I still have my old rear drive shaft laying around. And the truck originally had the 4 speed and 205 combo with the fixed yoke on the t-case and the slip joke at the carrier bearing. It is a 78 also. The shaft might only be shorter because mine had the 14 bolt rear end, yours being a half ton must have the 10 or 12 bolt, right? Or did you swap axles?
If youŽre interested in the shaft, pm me...
78 Chevy K20 Custom Deluxe, build: http://67-72chevytrucks.com/vboard/s...d.php?t=612104
68 Chevy K20 Panel truck, build: http://67-72chevytrucks.com/vboard/s...41#post7263441
K20chevy is offline   Reply With Quote
Old 07-23-2014, 04:01 PM   #128
K20chevy
K20chevy's Avatar
bumper starting to take shape.... all 3/16" steel plate...
Old 07-28-2014, 04:03 PM   #129
K20chevy
K20chevy's Avatar
this ist what the bumper looks like on the truck, just tacked in....
it still needs lights, trailer plug, etc, but the basic shape looks pretty good and old school, I think.
Old 07-28-2014, 10:07 PM   #130
TheBlueBomber
TheBlueBomber's Avatar
I think it looks great! You did a great job on it. I'd love for my metal skills to be at that level one day.
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
TheBlueBomber is offline   Reply With Quote
Old 07-28-2014, 11:38 PM   #131
85k30
85k30's Avatar
Did you use the master cylinder for the zf, or one from a 80's chevy truck? I can't seem to get enough throw for the slave to work.
85k30 is offline   Reply With Quote
Old 07-29-2014, 01:14 AM   #132
K20chevy
K20chevy's Avatar
I used the slave and master from the ZF. I had a custom adapter turned by a local mashine shop to accept the master cylonder plastic "swivel head" that clisp into the original clutch pedal. Sionce that was too long I had to go that way. However in order to get enough throw, you have to relocate the ZF master way up on the fiore wall and weld a bracket to the clotch pedal pretty far up. I still only have about half the trow on the pedal than with the old set up, but that is ok cause it shifts faster that way. But it take some time to get used to. Also you have to be careful with the clutch,pressureplate and flywheel you use. If you donŽt combine them correctly, the clutch will already be under pressure, not fully engaging. this will also make the clutch slip at full throttle. (donŽt ask me how I know )
IŽll see if I can find some pictures of the clutch set up and the custom stuff on the clutch pedal.
Old 07-29-2014, 01:15 AM   #133
K20chevy
K20chevy's Avatar
Thank you! Practice makes perfect.... Just dare to try it and youŽll see it is not that hard to do!
Old 08-04-2014, 05:19 PM   #134
K20chevy
K20chevy's Avatar
Here is the new (temporary) fuel filler inside the bed. IŽll add a fuel door to the back end of the bed sometime in the future.
This is what she looks like now...
Old 08-19-2014, 12:15 PM   #135
K20chevy
K20chevy's Avatar
Did some more work on the bumper.
Finnished the lisence plate area:
And the end caps on both sides:
recovery points welded in:
just some more shots on the truck:
with the cut outs for the BD SII flush mount flood lights:
I think itŽll look pretty good when smoothed out and powdercoated:
Old 08-19-2014, 12:23 PM   #136
K20chevy
K20chevy's Avatar
Also finally got the Dodge e-brake cables to work. But I donŽt like how low they hang. ItŽll do for now but I have to think about sth else!
And the front shaft finally clears the reworked exhaust on the passenger side!
Old 08-19-2014, 01:27 PM   #137
85k30
85k30's Avatar
Looking good! Cant wait to see that bumper powder coated!
Old 08-22-2014, 10:25 AM   #138
K20chevy
K20chevy's Avatar
Thank you! Next is the frenching in o some LED tail lights into the bumper, then getting it coated semi gloss black, like the front.
Still need to mount the hitch, get a tank skid plate made and remount the rear sensor for the adaptive headlights.
Oh and mount the NOS grille I got for it.
Then I might actually drive it for a while before tearing into the suspension front and rear and swapping the entire body to an arizona body.
Then it should be as good as done... but itŽll be a while before that ias all done!
Old 08-22-2014, 10:34 AM   #139
K20chevy
K20chevy's Avatar
did some fender trimming on the aftermarket fenders to clear the 37" MTRŽs for now, til I get the OEM fenders modified.
DoesnŽt look as bad as I thought it would. I still canŽt wait to modify the OEM ones for a factory look!
Old 09-06-2014, 02:19 PM   #140
85k30
85k30's Avatar
I finally got my truck on the road! I absolutely love the zf trans! Granted I only need 3 of the 6 gears most of the time. You going to build another trans tunnel for the Arizona cab?
Old 09-25-2014, 06:36 PM   #141
K20chevy
K20chevy's Avatar
I got to drive mine again and I love it too. I just have the clutch slipp when I really get on it. CouldnŽt find a stronger clutch for this setup though, only for the duramax but not the 8.1, where I have my pressureplate from.. and yes, they are different!!
Yes, but this time the tunnel will look better and more OEM. I will use a 2WD hump under the seat area and a modified 4WD hump up front, so the new hump is all OEM steel as well!
Old 09-27-2014, 11:21 PM   #142
85k30
85k30's Avatar
I managed to get mine to look almost factory. I used a trans tunnel from a automatic 4x4 to raise it up and clear, about an inch or so. Had to move the t case hole over and back for the 205 shifter.
Old 09-28-2014, 03:58 PM   #143
K20chevy
K20chevy's Avatar
WOW, that looks really good!
Old 09-30-2014, 01:11 PM   #144
K20chevy
K20chevy's Avatar
Ok, so here are some more shots of the rear bumper. I just added the work/backup lights for now and spray painted it... itŽll get the LED tail lights, the trailer plug, etc later and when all done the powder coating:
just had to throw this one in!
Old 09-30-2014, 10:23 PM   #145
TheBlueBomber
Oh yeah man that looks killer! I might have to get you to build me one! Haha. Looks really good man
Austin
Old 10-01-2014, 12:15 PM   #146
K20chevy
K20chevy's Avatar
Thanks, I appreciate that!
Well for the right price, I might build another one or two of these!
Old 10-12-2014, 05:23 AM   #147
K20chevy
K20chevy's Avatar
So more photos.....
here is a shot of the drive shaft angle with the high pinion D60 and about 4.5"-5" of lift. Worked out perfect...
here is a close up on the LED lights on the bumper (off)
and here (on) during the day
Warn VR10000-s winch... love the light weight synthetic rope!
Old 10-12-2014, 05:31 AM   #148
K20chevy
K20chevy's Avatar
And now some beauty shots on the beach....
here are the massive F550 brakes
Hella Bi-Xenon headlights
and just some more beauty shots
I really like this one....
Old 10-12-2014, 11:23 AM   #149
whitels1
whitels1's Avatar
Truck is looking real nice!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 10-12-2014, 11:47 AM   #150
tip
Nice work! Love the bumpers, clean and simple.
tip is offline   Reply With Quote
