Closed Thread
Old 11-10-2014, 02:59 PM   #126
DLW
Re: What did you do to your truck today part III
Originally Posted by earl84 View Post
DLW, that thing looks amazing. PB stuff sure is nice. Are you making your own panhard bar? I did that, and one thing I did that I thought was pretty neat (if I do say so myself) was get a hex nut that fit the bar and welded it in the middle of the bar to help make any adjustments easier. Turns out it spun like butter with the new joints, but it still looks kinda cool, haha.
Originally Posted by Micmac View Post
DLW that is off the chain! All I can say is, "WOW" I wished I possessed 1/8th of the talent you guys demonstrate.
Thanks guys.
For the panhard bar, I'm using the PorterBuilt bar, it just came minus some heim joints, misalignment spacers and hardware . That's a good idea on the hex nut in the middle though, I usually use the hex head tube adapters then I have one on each side.
DLW is offline
Old 11-10-2014, 04:33 PM   #127
Grizz1963
Grizz1963's Avatar
Not quite a truck build update.......
Had to come home early today from London to edit my 2015 business plan which I am presenting on Thursday....... deep joy.
Found myself the recipient of a parcel from Searcy, Arkansas, from Ta2Don. Postage alone $26.00 ..... eeeek !!!
Anyway, contents included a couple of Don's shop T-shirts for mate Martin and Amanda and another one for Ian who is living with us.
THEN...... Thanks to Don and Clemdaddy from Fayetteville, Arkansas a T-Shirt that blew my mind the first time I saw it as it had a C10 on it, as well as the Sinclair Oil Corporation, and a custom made number plate for car shows that Don had designed and got airbrushed for me.
Well, that was my day.
Have I mentioned I love my truck ??
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline
Old 11-11-2014, 09:02 PM   #128
rickywideglide
rickywideglide's Avatar
spent some time cleaning and polishing cabsails i picked up the other dayName:  001.jpg
rickywideglide is offline
Old 11-12-2014, 04:45 PM   #129
Grizz1963
Grizz1963's Avatar
Tonight the truck was loaded to work again.
Mate Martin will be starting his sandblasting soon, after doing some welding.
So we loaded the compressor and a crate tonight.......
Nothing like a ramp to make life a bit easier.
Ian supervising the tie down.
Can you say LOWER...?
Ready to Rock n Roll.
Old 11-12-2014, 05:37 PM   #130
CRGRS 66
CRGRS 66's Avatar
I never noticed all of the snap fasteners on your bed before, mine has the same, when I bought it there was a white tonneau cover on it. Do you have a tonneau cover for yours?
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline
Old 11-12-2014, 05:59 PM   #131
Grizz1963
Grizz1963's Avatar
Hi Craig, check out page one or two of my truck thread, it mostly wears the cover.
However, I am looking for a way to remove the fasteners but keep a cover.
Old 11-12-2014, 06:50 PM   #132
jb9281
jb9281's Avatar
What did you use to clean and polish the sail panels?
jb9281 is offline
Old 11-12-2014, 06:50 PM   #133
scuderia
scuderia's Avatar
I'd really like one of these but made of waterproof military canvas....
https://www.youtube.com/watch?v=r6zl0FGYF8g
'66 C10 SWB
'64 C2 roadster
'38 Indian Scout Flattracker
'70 Triumph T120R
'81 Laverda Jota
scuderia is offline
Old 11-13-2014, 04:06 PM   #134
earl84
Got a hydroboost from an '04 Silverado 2500 installed today, along with shortening the brake pushrod. Used Captainfab's hydroboost mounting plate and booster adapter bracket. I cannot give a strong enough recommendation for all his stuff. I have used the power steering gearbox adapter, the 14 bolt axle saddles, and now these two items. Top notch stuff and delivered incredibly fast, and his input on these forums is priceless.
Hooked up the brake lines, but gave in to the cold, it's only 36 degrees and windy here in the Dallas area. I'll have to hook up the pressure and return lines to the power steering pump another day.
earl84 is offline
Old 11-14-2014, 06:27 AM   #135
schpeen
schpeen's Avatar
Got the radiator and fans in and wired the motor
schpeen is offline
Old 11-14-2014, 09:12 PM   #136
LVPhotos
LVPhotos's Avatar
Chop, cut, rebuild. Isn't that a show? Cut bumper brackets, weld, cut, weld, fit. Two down two to go. Putting a 67-72 rear bumper is more pain for the gain. Got temp tires for front 225/70/15 to replace the 13+ year old 235/60/15. Now at 27.4 tall it filled the fender and closer to the 245/45/18 waiting for crossmember install. Picked up Flaming River manual 15:1 rack.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline
Old 11-14-2014, 10:39 PM   #137
cooperhw
cooperhw's Avatar
went up to my cabin property and stripped my 66 Chevy car. Going to probably haul it down the phoenix next spring and sell it. Got lots of great parts off it but have decided the 63 GMC is the one for me to build. Gonna pull the trailing arms off the bent frame later and put them in so I can eventually put some bigger tires in.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline
Old 11-15-2014, 02:59 PM   #138
LVPhotos
LVPhotos's Avatar
Getting close on final install. Got to make sure it's center and/or slot holes.
LVPhotos is offline
Old 11-15-2014, 03:45 PM   #139
Grizz1963
Grizz1963's Avatar
RADICAL TRANSFORMATION !!
That is the only way I can describe how the new lowered shocks and springs on the trucks suspension performs compared to the waddling duck it had been before.
After fitting everything new, including the brake hoses, I never got a chance to go test drive the truck, but of course the compressor had to be taken over to Martin's place 15 miles away today, after which I came home and then Nicola and I took a very large wooden chest down to her work and drove around some more before coming home, so I did around 50 plus miles today.
After dropping the compressor off, I came back home driving rather briskly...... through every roundabout and other bendy bits, the truck felt a whole lot like a modern car, sure footed and going where I pointed it.
I am amazed at the transformation.
This is a modification I would highly recommend to anyone with one of these trucks. Of course there is a lot more radical stuff you can do to the truck including C-Notching, airbags, dropped spindles etc. The sky is the limit, or the size of your bank balance.
I think that with imported parts, it came to about £100.00 or $160.00 per corner to fit these Brothers Trucks parts.
After all the driving and hooning, the suspension must have settled for now, so here are a pair of pics, unfortunately, I had not straightened the steering wheel up front for the photos.
After we came back from the shops, Martin came over and we went to go look at a 1990 Chevy Dayvan.
I was interested in the steering column, as I want a replacement column shift steering for my truck, and Martin is looking for a decent 350/350 or 700R4 combo for his truck. He will be selling the 307 and gearbox he bought running out of a truck earlier this year. The rest of the Dayvan would be sold off as spares if we bought it for the asking price of £800.00
When we got there and looked it all over, the steering was locked and the ignition mullered, Martin also decided for once to be sensible and walk away as the peripheral costs of making this engine run, could end up being more than than he wanted to spend.
HOWEVER, we ended up spending a great afternoon with Wayne the seller and some of his mates at his industrial unit.
I did have to use the bathroom, and the whole bathroom was done just perfectly, and I could not resist taking this pic of the toilet seat cover....... Just perfect for an Avatar.
We eventually left there and came home via Screwfix.
Old 11-15-2014, 07:28 PM   #140
Grizz1963
Grizz1963's Avatar
Got the following text an hour ago......
Hi Rian, I'm leaving my current job in three weeks, do you want me to pop round one evening to pull the dents out on your truck door with the pin puller ??
Message from a really nice guy I met months ago when he bought something for his son off Ebay from me.
So I guess the bodywork is about to start on the truck.
The world and life sure is filled with good stuff.
Old 11-16-2014, 03:26 AM   #141
Kenfuzed
Kenfuzed's Avatar
  1. Drove out and picked up a set of fan shroud side mounts from a member (thanks Danny!)
  2. Installed the alternator using a side mount bracket made by Bill's Hotrod Company.
  3. Ordered a new P/S pump that I'll pick up tomorrow.
  4. Picked up a fan clutch for the large fan I picked up at the last swap meet.
  5. Finished some wiring.
Slowly chipping away at all the little stuff to get back on the road again. Hopefully tomorrow I will get some time to install the relay and wiring for the fuel pump.
1988 Sportster, 2008 Street Glide
Ken's 1966 C10 build "Red Ale"
Follow on Instgram: @cv_performance
https://instagram.com/cv_performance
Harley Performance Parts: CV Performance (Harley related)
Enjoying the ride!
Kenfuzed is offline
Old 11-16-2014, 10:25 AM   #142
JWheeler331
JWheeler331's Avatar
Got the bed back on the truck finally. Still need to order the headlight hardware kit and put the headlights back in the grille.
Our 1965 Build
http://67-72chevytrucks.com/vboard/s...79#post6204879
JWheeler331 is offline
Old 11-16-2014, 03:03 PM   #143
Grizz1963
Grizz1963's Avatar
Drove it out the garage...... smiled
Reversed it back into the garage..... smiled.
Spoke to Bob the dent guy for about 45 minutes this morning, I sense a kindred spirit.
He will be here next week Sunday morning for the door crease and a couple of other small dents that can do with pulling.
I took a couple of fresh photos today while doing some other bits down at the garage, preparing it for when I start the bodywork.
Does not look bad, but still worth pulling, rather than just filling or bashing from behind.
New chrome rectangular mirrors are waiting, I will clean and repaint the stalks, either black or probably gunmetal/silver.
After seeing Markeb01's garage again this morning, I was shamed into pulling finger and starting the clear up and tidy up of my own space, before I start the actual tear down of my truck over Christmas.
I started with the outside, pulling weeds, clearing "stuff" away, followed by a few hours on the pressure cleaner, inside and outside that garage as well as both sides of the door.
The other day I realised when I posted this pic, the inside and outside needed some serious tidying.
At some point it looked like this.....
Current view, the ply sheets will form walls for a "spray/bodywork booth"
So I cleaned up the interior and drive......
Done.
Next job will be to clear out and sort out the interior.
Then figure out the new walls.
Old 11-16-2014, 04:56 PM   #144
awbrown
Did the same thing !!
And
awbrown is offline
Old 11-16-2014, 06:23 PM   #145
hotrod66
hotrod66's Avatar
looking good bub!
Between saying and doing many a pair of shoes are worn out
hotrod66 is offline
Old 11-16-2014, 09:26 PM   #146
xRAY76
drove mine in the snow for the 1st time...that was fun
xRAY76 is offline
Old 11-17-2014, 07:05 PM   #147
JWheeler331
Thank you.
Originally Posted by hotrod66 View Post
looking good bub!
Our 1965 Build
Old 11-17-2014, 08:01 PM   #148
markeb01
Senior Enthusiast
markeb01's Avatar
Nice to see things moving forward. Just a thought before you construct a plywood booth inside your garage - the last time I painted my truck I lined the garage with cheap disposable plastic drop cloths. I did one set for the body work, and replaced them again before painting:
These allow maximum use of space, keep dust and overspray off your stuff, and take about 5 minutes to pull and toss in the garbage can when you're finished.
[quote=Grizz1963;6920203]Drove it out the garage...... smiled
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 11-17-2014, 10:45 PM   #149
LVPhotos
LVPhotos's Avatar
Change oil pan from leeky chrome to zinc Moroso. Played gasser.
LVPhotos is offline
Old 11-18-2014, 12:12 AM   #150
Chevy Fleetside
Chevy Fleetside's Avatar
I pulled my fuel gauge sender to see if maybe that was the problem with my fuel gauge not working, and sure enough it was. So I fixed it. I tried soldering it first but it would not stick so I just stuck and brass screw through and tighted it down and it worked like a charm.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Closed Thread
