Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 04-10-2015, 05:14 PM   #126
DWilbur
Re: Project 68 k10 LWB..aka "The Hulk"
you steering brace fit much better than on my truck if all you had to do is shim it.
DWilbur is offline   Reply With Quote
Old 04-10-2015, 05:49 PM   #127
First c10
First c10's Avatar
I will try and take pictures of the shims and the thicknesses. I did have to run a 1/2" drill bit through the tubing on both brace pieces.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 04-11-2015, 02:38 PM   #128
First c10
First c10's Avatar
I got the steering brace installed and was in a hurry and forgot to take pictures. I will get some.
The steering box bolt hole shims where as follows:
1-Top column bolt no shim
2-Bottom column end 2-3/16" thick 7/16 washers( fits inside the dimpled bolt area of the frame) a 1/4" think shim.
3-Top radiator side bolt no shim
4-Bottom radiator side bolt 3-3/16"thick 7/16 washers plus 1- 1/4" thick shim (this is to align the small steering brace to the crossmember hole
5-the big brace to crossmember I drilled a 1/2" hole for a 1/2"X1-1/4" bolt. Used 2-1/4" shims.
I will get a few pictures so hopefully this will make sense.
GO GO!!!
Old 04-12-2015, 12:37 AM   #129
First c10
First c10's Avatar
This is a pictures of the steering box brace that mounts to the center of the front crossmember and its shims
GO GO!!!
Old 04-12-2015, 12:41 AM   #130
First c10
First c10's Avatar
This is the steering box side of the big brace
GO GO!!!
Old 04-12-2015, 12:42 AM   #131
First c10
First c10's Avatar
This is the small front brace. I did have to clearance the side of the tubing where it was to class to the front crossmember bolt.
Oh and I had to use 4-7/16 washers and the 1/4" shim. Earlier I said 3 washers.
GO GO!!!
Old 04-13-2015, 01:57 AM   #132
First c10
First c10's Avatar
So think I am going to build a truck without tearing the green truck apart. I have a clean title that is a k20 so I am going to the DMV to find out what needs to be done.
I got some new parts for the rearend. Rear discs, axles, posi,gears etc. so I will try to get them installed this week. Pictures to come.
GO GO!!!
Old 04-13-2015, 11:05 AM   #133
7dee2
7dee2's Avatar
Is that going to result in a reconstructed title? I don't have an issue with those type of titles but it sure makes them hard to insure and dings resale big time.
Brett
67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594
72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.)
72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 04-13-2015, 11:10 AM   #134
First c10
First c10's Avatar
I am not sure as I need to find out. I have the cab with the vin and frame that match.
GO GO!!!
Old 04-13-2015, 11:21 AM   #135
7dee2
7dee2's Avatar
I would think as long as those match it's a restoration isn't it? Really nice work on this new frame btw!
Brett
Old 04-13-2015, 11:53 AM   #136
First c10
First c10's Avatar
I meant I have the VIN plate from the the cab that was on the frame.... just wanted to clarify.
I have a bill of sale so that will be the issue to registration in California. I have a friend that works at DMV so I am hoping she can help.
Thanks for the compliment. I am currently working on the sway bar mounts as they don't look right to me. I think there will be a problem with it binding after the weight is on the suspension. So I think I am going to get a sway bar shackle link kit. I built a drop block for the sway bar where it mounts to the frame and was not happy with the look. This kit should also help with the ride...or at least that is what the comments I have read say.
GO GO!!!
Old 04-13-2015, 04:38 PM   #137
7dee2
7dee2's Avatar
Good luck with the DMV I keep putting my trip off. Need to retitle all 3 of our projects including the K30 build.
Shoot I was hoping the sway bar was going to work out the way you had it mounted on the frame rails. Watching closely as I'm sure you'll come up with something really clean looking.
Brett
Old 04-13-2015, 04:53 PM   #138
First c10
First c10's Avatar
The above bracket will help with the angle and give a little flex in the front suspension. These brackets work good if you have a lift. I had an 85 back in the day that had blocks to lower the sway arm off the frame to give a better angle and assist with binding but it was rough riding so I made a set of these brackets and the rod was so much better. So since I think it swap will have the same problem I just went and ordered the shackle kit for the sway arm. I will post pictures when installed. The frame mounts of the sway arm should look the same.
GO GO!!!
Old 04-16-2015, 12:11 AM   #139
First c10
First c10's Avatar
Well finally got a present from the boys in a brown truck. Auburn carrier with new Richmond gears and Timkin install kit.
GO GO!!!
Old 04-16-2015, 12:12 AM   #140
First c10
First c10's Avatar
I couldn't wait to dive in so I forgot to take pictures. This is after I started assembling.
GO GO!!!
Old 04-16-2015, 12:14 AM   #141
First c10
First c10's Avatar
Working on the pinion depth first. But ran out of time tonight.
GO GO!!!
Old 04-17-2015, 01:44 PM   #142
First c10
First c10's Avatar
Getting closer. Just keep running out of time. I will have it completed by. Weekend.
GO GO!!!
Old 04-18-2015, 12:04 AM   #143
First c10
First c10's Avatar
Got the ring and pinion all set and mocked up the rear disc brake set up. Just had to weld up the caliper brake line tabs and we are good to go. I got the rearend in primer.
My sons have prom and 2 trap shooting events this weekend so we will be out of town. So no work on the truck.
GO GO!!!
Old 04-20-2015, 11:56 PM   #144
First c10
First c10's Avatar
Got the rearend painted and installed. I need to get the brake lines installed and reroute a little to fit the rear disc.
GO GO!!!
Old 04-21-2015, 12:04 AM   #145
First c10
First c10's Avatar
Hey guys I need a little help. I need a few pictures of how the brake lines are run on a 72 k10? For some reason the SS kit from inline tune came with no instructions and since the frame is stripped I am not sure how it installs.
Please help??
Thanks guys.
GO GO!!!
Old 04-21-2015, 01:46 PM   #146
DWilbur
Typically both calipers are hard line to the center of the axle and 1`flex hose up to the frame with a bracket to support the brake line on the frame.
Old 04-21-2015, 02:20 PM   #147
First c10
First c10's Avatar
Sorry I meant the front crossmember to the master cylinder That area.
GO GO!!!
Old 04-21-2015, 05:30 PM   #148
DWilbur
Mine ran down to the left frame rail crossed over fallowing the front cross member to the right side. I don't have pictures you are ahead of me installing the break lines.
Old 04-21-2015, 05:40 PM   #149
First c10
First c10's Avatar
Left as the driver side? my frame has the rear hard line bracket on the passenger side. I think I am going to remove and install the bracket that came on the 91 burb frame I bought. the line I have looks to stop about where the original engine crossmember was. I thought the lines ran across the very forward crossmember (where the steering brace attaches).
As far as installing the brake lines I figured since I was doing the rearend I might as well get the line to the front of the frame.
The rear caliper hose ends have 3/8"-24 female inverted size and the brake line kit has 7/16-24.So I had to pick up the correct fittings, but since I have to cut them down and re-flare its no big deal.
GO GO!!!
Old 04-21-2015, 05:47 PM   #150
DWilbur
I have a CD at home that should show the break lines I will look for it and post if I find the info.
