12-09-2017, 10:57 PM | #126 |
Re: Crew Cab build preview...
At this point it doesn’t matter but the engine compartment looks factory, I like how it all fit together.
12-11-2017, 01:37 AM | #127 |
I drove the crew out of the garage today and brought in the diesel, engine will be out tomorrow...
12-11-2017, 01:38 AM | #128 |
Damn dodges are weird for me, unusual metric sized bolts like 16 and 18mm....
12-11-2017, 04:01 PM | #129 |
6>8 Plugless........
Get used to it, that entire engine is metric. 12mm, 17mm, but 10, 13, 15, 18, and 19 are pretty common in and on them. Haha
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
12-11-2017, 04:17 PM | #130 | |
What I'm not cool with is 16 and 18mm usage, that's uncommon except gm power steering and engine mount bolts I think....and when a fastener could be 12 or 13, and another could be 14 or 15....have it be consistent like a Japanese or German car I had every wrench and every socket out and guessed wrong half the time... |
12-20-2017, 07:32 PM | #131 |
This Cummins is a beast...
12-20-2017, 08:12 PM | #132 |
Where's my beer?
Man, you don't play around! looks like you're well on your way to completing the Cummins swap.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
12-20-2017, 08:30 PM | #133 |
Wow Good thing there is plenty of room under the hood
12-20-2017, 08:45 PM | #134 |
Well I hope to get a cross member built for the Cummins mounts over the next few days then it should go pretty quick. I'm waiting on a couple transmission parts right now.
12-27-2017, 12:55 PM | #135 |
Randy
Your truck is looking Great. I have a question on the 3rd and 4th door. I noticed early in your build you tried the front door hinges on the back door and the door did not open enough and you chose to use suburban hinges. Do you have Dimensions for these door hinges so I can make them or know where they can be bought? Thanks Dwayne |
12-27-2017, 01:01 PM | #136 | |
12-27-2017, 01:08 PM | #137 |
I am trying to round all my parts before I make the first cut. I don't have a Suburban but I think I can do it without one. It will just be a lot more work. I have plenty of doors and a Extra cab. Last edited by Getter-Done; 03-12-2018 at 11:42 PM. |
12-27-2017, 01:14 PM | #138 |
Make it easy and at least buy 2 "B" pillars. I bought one off the forum and used it on the drivers side by cutting it in sections and flipping each over and re-welding them, I don't think I documented that in my build.
12-27-2017, 01:24 PM | #139 |
That sounds like a plan. Thanks.
I have been doing a lot of research. I have looked at the builds on this forum. Also looked at lots of Pictures on the Web. The B Pillars seem to be the Big deal. Also the choice of a high or low roof line and joining the roof together. |
01-07-2018, 12:05 AM | #140 |
The Cummins with 5spd and NP205 is mounted and new exhaust installed.
Of note in this picture is that the turbo is about 5/8” from the AC box and I had to build a bracket for the power brake booster to mount it directly to the firewall. The master cylinder would not clear the intake elbow so I fanned up a bracket similar to the one captainfab sells. |
01-07-2018, 12:11 AM | #141 |
I mounted the engine as far forward as possible and even used the 1st gen Cummins fan hub which is 5/8” shorter, I had to mount the engine forward to get turbo clearance on the AC box, I even offset the motor to the drivers side as much as I could which wasn’t much due to my use of 2nd gen engine mounts which stick out a long way from the block.
The fan is very close to the radiator at the top, I will re-mount the radiator closer to the core support at the top to gain some clearance. The radiator in stock location is tilted back at the top, so it will be easy to make it more upright. |
01-07-2018, 12:15 AM | #142 |
The 2nd gen exhaust angled right into the passenger floorboard so I ordered a full 1st gen 4” exhaust system, a little cutting and it fit right up nicely.
01-07-2018, 12:17 AM | #143 |
New exhaust has a real 4” downpipe off the turbo...
01-07-2018, 12:21 AM | #144 |
SWB 4x4 Collector
Looking good Randy! You are flying.
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
01-07-2018, 12:23 AM | #145 |
I boxed the front frame for the engine crossmember from the rear shackles past the engine crossmember, I will finish boxing the front frame to the front crossmember.
I will also be boxing the frame from the rear of the front shackles to the rear spring mounts. I had some 3/16” plate sheared to size so boxing that will be a quick job. Pic of the crossmember... |
01-07-2018, 12:26 AM | #146 |
Crappy lighting but here is a pic of the exhaust.
01-07-2018, 12:29 AM | #147 |
2nd gen mounts
01-07-2018, 01:27 AM | #148 |
01-08-2018, 04:06 PM | #149 |
Nice work Randy!
01-08-2018, 08:05 PM | #150 |
Making good progress!
