Old 11-15-2017, 01:15 AM   #126
Jason7121
Jason7121's Avatar
Re: 1972 Chevy Pickup Project.
I sent my ecm to a guy on eBay and was around $75 . He was super helpful and can tune for gear ratio cold air intake electric fans etc. Here's a picture of his eBay info.
Jason7121 is offline   Reply With Quote
Old 11-15-2017, 08:40 AM   #127
thetucks
thanks. I wonder if there is anyone here locally.
thetucks is offline   Reply With Quote
Old 11-15-2017, 10:50 AM   #128
rsgt
rsgt's Avatar
Here is a place that is an hour and a half from you. http://www.lsx-harness.com/contact.html
rsgt is offline   Reply With Quote
Old 11-15-2017, 09:39 PM   #129
thetucks
thanks rsgt. Ill give them a call.
Old 11-16-2017, 05:31 PM   #130
thetucks
Thanks for finding those guys for me rsgt. I just got off the phone with them and they are going to get me all fixed up.
Old 11-16-2017, 05:54 PM   #131
Jason7121
Jason7121's Avatar
Glad you were able to find a local place now you can run true dual exhaust with no cats.
Old 11-16-2017, 07:16 PM   #132
rsgt
rsgt's Avatar
I am glad it worked out.
Old 11-19-2017, 11:32 PM   #133
thetucks
Got a lot done today. I refilled all the fluids and found an immediate problem. I know I should have put on a new water pump when I did the motor tear down but I check everything and it looked really good. As it turns out the seal behind the pulley is bad because water started running out. Went to the local parts store and picked up a new one. Im going to finnish up the new fuel filler neck tomorrow and then ill try to start it up for the first time since the teardown.
Old 11-19-2017, 11:38 PM   #134
Jason7121
Jason7121's Avatar
The ecm would have to be reflashed first to delete anti theft passlock system for it to start unless you are using all the stuff from the donor like the body control module steering column etc. Just a thought you may have that all worked out already.
Old 11-19-2017, 11:45 PM   #135
thetucks
yes sir I am using using all of it from the tahoe. Im going to make sure it all works before I get the ecm reflashed.
Old 11-20-2017, 12:18 AM   #136
Jason7121
Jason7121's Avatar
That's awesome!
Old 11-24-2017, 01:04 AM   #137
thetucks
happy thanks giving everyone.... Got a lot of work done on the truck today. Got the new grille, insert, headlights, etc. installed. Got the new rear bumper brackets made and installed and got the fuel filler installed. I also go the trailer hitch installed. And oh yeah I got her started today......She sounds sweet.
Old 11-24-2017, 01:07 AM   #138
Jason7121
Jason7121's Avatar
Wow looks good. Bet it was nice hearing it run for the first time.
Old 11-24-2017, 01:11 AM   #139
thetucks
Yes it was. now I cant wait to drive it.
Old 11-27-2017, 11:42 PM   #140
COS399
COS399's Avatar
Very Nice Work!
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 11-28-2017, 09:43 AM   #141
thetucks
Originally Posted by COS399 View Post
Very Nice Work!
thanks cos399
1972 chevy pickup/ 2004 chevy tahoe merge...
My build -http://67-72chevytrucks.com/vboard/s...d.php?t=731246
Old 11-28-2017, 09:46 AM   #142
thetucks
So Ive got an appointment to have the ecu reflashed and that will fix my tire size change, my o2 sensor delete, any engine related changes, etc. But where do I have the computer reprogramed for the inside components? I want to turn off the extra air bags, reprogram for the new factory stereo, etc. Any ideas?
Old 11-28-2017, 11:01 AM   #143
Jason7121
Jason7121's Avatar
You could take the bulb out of the cluster for the air bag light and for the factory stereo if it came out of the same vehicle everything else did it should work without being locked.
Old 11-28-2017, 01:00 PM   #144
thetucks
The radio that was in the tahoe was damaged. I purchased a replacement like new to put in.
Old 12-03-2017, 12:44 AM   #145
thetucks
The front bumper and inner fenders are installed. The airbox and overflow are mounted.
Old 12-03-2017, 12:59 AM   #146
Jason7121
Jason7121's Avatar
If radio is locked dealer can program it. I do it at work for people who replace the radio themselves. Truck looks great with grille and bumper on.
Old 12-03-2017, 11:01 AM   #147
thetucks
I wonder what they are going to say when I pull up in a 72 chevy and say reprogram my radio please?
Old 12-03-2017, 12:04 PM   #148
Jason7121
Jason7121's Avatar
They will appreciate the work you are doing if they don't your in the wrong place!
Old 12-03-2017, 01:41 PM   #149
mjensen
mjensen's Avatar
Such a cool project! And here I am struggling with a slightly modified '69
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 12-03-2017, 10:08 PM   #150
thetucks
That is True.
Yes it has been fun. I am so ready to drive it everywhere.
