Old 11-12-2021, 12:38 AM   #126
jarrodblake
jarrodblake's Avatar
Re: 1970 C30 Car hauler Buildish thread.
I moved the driver side shock mount behind the axle to match the dodge bracket.
20211027_210329 by jarrod vanwinkle, on Flickr
20211027_210340 by jarrod vanwinkle, on Flickr
20211027_210919 by jarrod vanwinkle, on Flickr
I cam across some assist shocks for cheap. I don't know if they actually do anything it says it gives any extra 500lbs of load on each shock and supposed to give a little lift idk but they sit at the same height as the old ones. that said i'm running helper bags any ways to help keep the load level. and its way cheaper then replacing the old leaf springs.
20211027_145259 by jarrod vanwinkle, on Flickr
20211027_212021 by jarrod vanwinkle, on Flickr
20211027_213118 by jarrod vanwinkle, on Flickr
Pulled my step fathers boat out of the water on november 1st it was 71 out here it was a warm fall.
20211026_175543 by jarrod vanwinkle, on Flickr
20211026_180542 by jarrod vanwinkle, on Flickr
started on the wide body extensions.
20211104_153546 by jarrod vanwinkle, on Flickr
20211104_161715 by jarrod vanwinkle, on Flickr
20211104_192849 by jarrod vanwinkle, on Flickr
the steel wheels have a slightly deeper offset so I needed to make sure they fit. I have about an inch of room
20211104_202457 by jarrod vanwinkle, on Flickr
20211104_202519 by jarrod vanwinkle, on Flickr
20211105_142617 by jarrod vanwinkle, on Flickr
I ended up going with dodge style u bolts so I had to redo the helper bag mounts.
20211101_194706 by jarrod vanwinkle, on Flickr
20211105_200749 by jarrod vanwinkle, on Flickr
20211106_141838 by jarrod vanwinkle, on Flickr
Had another 71 degree day yesterday november 10th.
20211108_174112 by jarrod vanwinkle, on Flickr
Got one more use out of the grill.
20211110_172043 by jarrod vanwinkle, on Flickr
20211110_172557 by jarrod vanwinkle, on Flickr
20211108_194312 by jarrod vanwinkle, on Flickr
20211108_193520 by jarrod vanwinkle, on Flickr
20211109_163550 by jarrod vanwinkle, on Flickr
Had a new drive shaft made for the rear. and had them balance it and replace the carrier bearings and they replaced the u joints as well. I about had a hart attack when I got the bill.
20211110_191747 by jarrod vanwinkle, on Flickr
20211111_195122 by jarrod vanwinkle, on Flickr
I wired up two 7 pin trailer plugs one for the gooseneck and one for the normal hitch.
20211111_215045 by jarrod vanwinkle, on Flickr
20211111_210344 by jarrod vanwinkle, on Flickr
jarrodblake is offline   Reply With Quote
Old 11-13-2021, 11:59 AM   #127
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work on it. I like your junction box for your trailer connectors. Nice work on the bag mods and bed widening. If has been a warm fall. Next week around here is going to be warm too. Sounds great to me!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-17-2021, 10:13 PM   #128
dnd1978
dnd1978's Avatar
Great work on the boxes and doors
________________________________
1972 SWB stepside pro tour build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=452840
dnd1978 is offline   Reply With Quote
Old 12-30-2021, 11:56 PM   #129
jarrodblake
Thanks, I'm happy with the junction box, I also run my tellights off it and it makes it easy to add lights. It looks like its going to be cooling down next week here. It was 72 on christmas day here, apparently it was the warmest christmas in the last 30 some years here.
Thanks, I can't wait to get the other side skinned.
I hope you all have a wonderful new year!
Photo dump.
20211111_221907 by jarrod vanwinkle, on Flickr
20211112_153643 by jarrod vanwinkle, on Flickr
20211112_155808 by jarrod vanwinkle, on Flickr
20211113_200358 by jarrod vanwinkle, on Flickr
20211113_201401 by jarrod vanwinkle, on Flickr
20211113_201915 by jarrod vanwinkle, on Flickr
20211113_201857 by jarrod vanwinkle, on Flickr
20211113_204712 by jarrod vanwinkle, on Flickr
20211114_155826 by jarrod vanwinkle, on Flickr
20211114_200548 by jarrod vanwinkle, on Flickr
20211116_195214 by jarrod vanwinkle, on Flickr
20211114_200556 by jarrod vanwinkle, on Flickr
20211120_163340 by jarrod vanwinkle, on Flickr
20211120_163344 by jarrod vanwinkle, on Flickr
20211120_163415 by jarrod vanwinkle, on Flickr
20211120_170609 by jarrod vanwinkle, on Flickr
20211121_192454 by jarrod vanwinkle, on Flickr
20211121_192712 by jarrod vanwinkle, on Flickr
20211124_194438 by jarrod vanwinkle, on Flickr
Finally got around to making a stool out of a crark that came out of a jeep my brother through a rod in.
20211128_161848 by jarrod vanwinkle, on Flickr
20211128_184304 by jarrod vanwinkle, on Flickr
20211129_184745 by jarrod vanwinkle, on Flickr
20211130_213927 by jarrod vanwinkle, on Flickr
20211202_143323 by jarrod vanwinkle, on Flickr
Also made a pair of lamps.
20211202_205254 by jarrod vanwinkle, on Flickr
20211216_152143 by jarrod vanwinkle, on Flickr
20211216_152205 by jarrod vanwinkle, on Flickr
20211216_152224 by jarrod vanwinkle, on Flickr
20211211_130042 by jarrod vanwinkle, on Flickr
Then I decided to make a some ornaments to give everyone for christmas
This was way to heavy to hang on a tree
20211211_203900 by jarrod vanwinkle, on Flickr
So I ended up making trees
20211220_220220 by jarrod vanwinkle, on Flickr
20211220_195116 by jarrod vanwinkle, on Flickr
20211220_215958 by jarrod vanwinkle, on Flickr
decided on a side exit for the exhaust.
20211206_161808 by jarrod vanwinkle, on Flickr
20211206_200358 by jarrod vanwinkle, on Flickr
20211206_201203 by jarrod vanwinkle, on Flickr
20211213_203615 by jarrod vanwinkle, on Flickr
20211229_151045 by jarrod vanwinkle, on Flickr
20211229_155246 by jarrod vanwinkle, on Flickr
20211214_193915 by jarrod vanwinkle, on Flickr
20211214_202011 by jarrod vanwinkle, on Flickr
20211214_202014 by jarrod vanwinkle, on Flickr
20211215_193855 by jarrod vanwinkle, on Flickr
20211222_214849 by jarrod vanwinkle, on Flickr
20211222_163542 by jarrod vanwinkle, on Flickr
20211230_192012 by jarrod vanwinkle, on Flickr
20211230_193643 by jarrod vanwinkle, on Flickr
20211230_200740 by jarrod vanwinkle, on Flickr
20211230_200745 by jarrod vanwinkle, on Flickr
20211230_200752 by jarrod vanwinkle, on Flickr
20211230_204543 by jarrod vanwinkle, on Flickr
20211230_204548 by jarrod vanwinkle, on Flickr
20211230_210045 by jarrod vanwinkle, on Flickr
Old 01-03-2022, 11:57 AM   #130
daddyjeep
daddyjeep's Avatar
You spent a lot of time with the plasma cutter on those trees. Nice little gift though. I like the exhaust exit. Looks good
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 08-15-2022, 12:51 AM   #131
jarrodblake
Unfortunately I spent more time cleaning the slag off then It took me to cut them. The where a big hit with the family! I'm happy with how the exhaust turned out.
I've been neglecting this thread. I finally started back at work so I haven't posted any updates. But I have made a lot of progress.
I have a few months worth of a photo dump.
20220101_194804 by jarrod vanwinkle, on Flickr
20220103_200943 by jarrod vanwinkle, on Flickr
20220122_195545 by jarrod vanwinkle, on Flickr
20220122_195537 by jarrod vanwinkle, on Flickr
20220122_202309 by jarrod vanwinkle, on Flickr
20220123_155502 by jarrod vanwinkle, on Flickr
20220123_160532 by jarrod vanwinkle, on Flickr
20220207_202548 by jarrod vanwinkle, on Flickr
20220207_202606 by jarrod vanwinkle, on Flickr
I've been wanting to upgrade my welding cart with a welding table on top for a few years know and I had a bit of left over angle iron from the bed boxes brackets so I made a new welding cart.
Old
20220209_203431 by jarrod vanwinkle, on Flickr
New
20220210_205252 by jarrod vanwinkle, on Flickr
20220211_191947 by jarrod vanwinkle, on Flickr
20220214_164308 by jarrod vanwinkle, on Flickr
20220214_165257 by jarrod vanwinkle, on Flickr
20220217_201803 by jarrod vanwinkle, on Flickr
20220217_173125 by jarrod vanwinkle, on Flickr
20220217_203930 by jarrod vanwinkle, on Flickr
20220217_203945 by jarrod vanwinkle, on Flickr
20220217_204721 by jarrod vanwinkle, on Flickr
started adding stake pockets
20220221_203219 by jarrod vanwinkle, on Flickr
20220302_145334 by jarrod vanwinkle, on Flickr
20220302_150239 by jarrod vanwinkle, on Flickr
20220302_185607 by jarrod vanwinkle, on Flickr
20220304_161030 by jarrod vanwinkle, on Flickr
20220304_204813 by jarrod vanwinkle, on Flickr
20220305_150757 by jarrod vanwinkle, on Flickr
20220305_202657 by jarrod vanwinkle, on Flickr
20220305_202702 by jarrod vanwinkle, on Flickr
20220306_153357 by jarrod vanwinkle, on Flickr
20220306_165313 by jarrod vanwinkle, on Flickr
20220306_200759 by jarrod vanwinkle, on Flickr
20220307_155609 by jarrod vanwinkle, on Flickr
20220309_204146 by jarrod vanwinkle, on Flickr
20220310_153750 by jarrod vanwinkle, on Flickr
20220310_153801 by jarrod vanwinkle, on Flickr
20220310_163049 by jarrod vanwinkle, on Flickr
Cut the holes for the goose neck
20220405_202642 by jarrod vanwinkle, on Flickr
20220405_210854 by jarrod vanwinkle, on Flickr
20220405_210924 by jarrod vanwinkle, on Flickr
bed lined under the dimandplate
20220418_200251 by jarrod vanwinkle, on Flickr
20220418_200254 by jarrod vanwinkle, on Flickr
Painted my buddys mud truck
20220424_153949 by jarrod vanwinkle, on Flickr
20220510_155050 by jarrod vanwinkle, on Flickr
20220516_171500 by jarrod vanwinkle, on Flickr
made the mounts for the removable dove tail.
20220426_153653 by jarrod vanwinkle, on Flickr
20220426_155742 by jarrod vanwinkle, on Flickr
20220426_164404 by jarrod vanwinkle, on Flickr
20220427_164619 by jarrod vanwinkle, on Flickr
20220427_170107 by jarrod vanwinkle, on Flickr
20220427_170117 by jarrod vanwinkle, on Flickr
20220427_174858 by jarrod vanwinkle, on Flickr
20220427_175644 by jarrod vanwinkle, on Flickr
20220427_181233 by jarrod vanwinkle, on Flickr
The whole point of the mirrors is so I can do this!
20220427_201356 by jarrod vanwinkle, on Flickr
20220510_152710 by jarrod vanwinkle, on Flickr
20220515_195034 by jarrod vanwinkle, on Flickr
20220515_195041 by jarrod vanwinkle, on Flickr
mounted a different power steering cooler
20220525_164640 by jarrod vanwinkle, on Flickr
20220608_120534 by jarrod vanwinkle, on Flickr
20220608_120547 by jarrod vanwinkle, on Flickr
20220608_143139 by jarrod vanwinkle, on Flickr
20220608_152649 by jarrod vanwinkle, on Flickr
20220608_162956 by jarrod vanwinkle, on Flickr
20220608_201706 by jarrod vanwinkle, on Flickr
20220608_201721 by jarrod vanwinkle, on Flickr
20220608_151908 by jarrod vanwinkle, on Flickr
20220615_145845 by jarrod vanwinkle, on Flickr
20220615_145852 by jarrod vanwinkle, on Flickr
20220615_150109 by jarrod vanwinkle, on Flickr
Mounted the boxes and installed the battery and air compressors
20220621_175626 by jarrod vanwinkle, on Flickr
20220622_201436 by jarrod vanwinkle, on Flickr
20220622_201442 by jarrod vanwinkle, on Flickr
20220626_204553 by jarrod vanwinkle, on Flickr
20220628_213144 by jarrod vanwinkle, on Flickr
20220630_223401 by jarrod vanwinkle, on Flickr
20220630_232654 by jarrod vanwinkle, on Flickr
20220630_233803 by jarrod vanwinkle, on Flickr
Took it on its maiden voyage 4Th of July parade our church float!
on the river that evening.
20220704_185309 by jarrod vanwinkle, on Flickr
mounted the mud flaps
20220705_115732 by jarrod vanwinkle, on Flickr
spare tire mount
20220706_220549 by jarrod vanwinkle, on Flickr
20220706_220600 by jarrod vanwinkle, on Flickr
20220711_145851 by jarrod vanwinkle, on Flickr
20220711_152013 by jarrod vanwinkle, on Flickr
Old 08-15-2022, 01:08 AM   #132
jarrodblake
My buddy that I painted his truck gave me an old warn winch that he got on trade. He though it was told it was an 8k but it is a 6k. but after I did a bit of research on them it has the same gear ratio as the 9k winch. so I'm going to upgrade the motor and motor plate and make it a 9k winch.
20220719_201348 by jarrod vanwinkle, on Flickr
20220719_213423 by jarrod vanwinkle, on Flickr
20220719_213439 by jarrod vanwinkle, on Flickr
20220719_213711 by jarrod vanwinkle, on Flickr
20220720_213529 by jarrod vanwinkle, on Flickr
20220724_172049 by jarrod vanwinkle, on Flickr
20220724_165146 by jarrod vanwinkle, on Flickr
I really love the look of the old warn 8274 I I made a fake 8274 gear case to give my winch a period correct look of something you would see on a old ramp truck from the 70s/80s
20220727_201851 by jarrod vanwinkle, on Flickr
20220727_201847 by jarrod vanwinkle, on Flickr
20220727_201854 by jarrod vanwinkle, on Flickr
20220727_210311 by jarrod vanwinkle, on Flickr
20220727_210317 by jarrod vanwinkle, on Flickr
20220731_155029 by jarrod vanwinkle, on Flickr
20220731_155034 by jarrod vanwinkle, on Flickr
20220731_155038 by jarrod vanwinkle, on Flickr
20220731_155043 by jarrod vanwinkle, on Flickr
20220802_172650 by jarrod vanwinkle, on Flickr
20220802_172610 by jarrod vanwinkle, on Flickr
20220802_172638 by jarrod vanwinkle, on Flickr
20220803_090524 by jarrod vanwinkle, on Flickr
20220808_153207 by jarrod vanwinkle, on Flickr
Old 03-07-2023, 11:04 PM   #133
jarrodblake
Its been a while since I have posted. I have not stopped on the truck. I have just gotten lazy with my up loads.
Back last year after I finished the winch I installed a York compressor I have had sitting since 2012 I always planed on using it for onboard air on something but just have not.
Its a york 206
https://www.tmcom.com/~tsm1/scout/faq/york.html
20220804_002321 by jarrod vanwinkle, on Flickr
20220801_015400 by jarrod vanwinkle, on Flickr
20220801_015435 by jarrod vanwinkle, on Flickr
20220804_002334 by jarrod vanwinkle, on Flickr
20220804_232407 by jarrod vanwinkle, on Flickr
20220807_161254 by jarrod vanwinkle, on Flickr
I rebuilt it and made some mounting brackets for it. I attached it to the alternator.
20220808_224532 by jarrod vanwinkle, on Flickr
20220808_224524 by jarrod vanwinkle, on Flickr
20220815_153505 by jarrod vanwinkle, on Flickr
20220815_153459 by jarrod vanwinkle, on Flickr
20220815_153451 by jarrod vanwinkle, on Flickr
20220815_153456 by jarrod vanwinkle, on Flickr
20220815_154321 by jarrod vanwinkle, on Flickr
the pully is from https://www.cuoffroad.com/product-li...om-components/
20220815_153230 by jarrod vanwinkle, on Flickr
V1
20220815_161049 by jarrod vanwinkle, on Flickr
20220815_161056 by jarrod vanwinkle, on Flickr
20220821_205202 by jarrod vanwinkle, on Flickr
V2 I built a breather oil catch can. as oil was coming out of the breather.
20220831_200150 by jarrod vanwinkle, on Flickr
20220831_200154 by jarrod vanwinkle, on Flickr
I drilled and tapped the intake so I could add a better air filter.
20220911_192717 by jarrod vanwinkle, on Flickr
20220911_193916 by jarrod vanwinkle, on Flickr
I added a in cab air pressure gauge.
20220922_131612 by jarrod vanwinkle, on Flickr
20220926_160843 by jarrod vanwinkle, on Flickr
I added a water/ oil separator
20220810_210024 by jarrod vanwinkle, on Flickr
20220810_210014 by jarrod vanwinkle, on Flickr
Old 03-07-2023, 11:28 PM   #134
jarrodblake
I built a new shifter! It started out as a old Hurst 4 speed shifter that I found in our barn when we bought the house. back in 05 I think?
I cant find some of the pics. The chrome was coming off it was super rusty and pitted. In this pic it looks like i just finished sanding all the chrome a pits off of it getting ready to cut it.
20220816_205308 by jarrod vanwinkle, on Flickr
I made some brackets to be able to bolt it on and make it height adjustable.
20220816_214714 by jarrod vanwinkle, on Flickr
here is the bracket welded in place and the shifter polished. before I copper and nickel plated them.
20220817_144102 by jarrod vanwinkle, on Flickr
20220817_220502 by jarrod vanwinkle, on Flickr
20220817_221246 by jarrod vanwinkle, on Flickr
20220817_221449 by jarrod vanwinkle, on Flickr
20220817_221826 by jarrod vanwinkle, on Flickr
20220821_202427 by jarrod vanwinkle, on Flickr
here it is after nickel plating
20220822_221831 by jarrod vanwinkle, on Flickr
I made a shift knob out of a old curtain rod end
20220823_124300 by jarrod vanwinkle, on Flickr
Old 03-08-2023, 12:05 AM   #135
jarrodblake
added a second row taillights
20220908_134649 by jarrod vanwinkle, on Flickr
installed wench cable
20220918_194706 by jarrod vanwinkle, on Flickr
tuched up the rockers
20221004_154010 by jarrod vanwinkle, on Flickr
went to a swap meet.
20221007_134359 by jarrod vanwinkle, on Flickr
Picked up a hose real at the swap meet
20221009_145010 by jarrod vanwinkle, on Flickr
20230307_223834 by jarrod vanwinkle, on Flickr
20230307_223819 by jarrod vanwinkle, on Flickr
installed a new radio its ok no cutting to the dash!
20221006_003318 by jarrod vanwinkle, on Flickr
Fall pics in the front yard
20221018_135117 by jarrod vanwinkle, on Flickr
20221018_135134 by jarrod vanwinkle, on Flickr
20221018_135153 by jarrod vanwinkle, on Flickr
20221018_135204 by jarrod vanwinkle, on Flickr
installed a steering wheel cover the color matches better in person but not more sticky steering wheel!
20221023_212020 by jarrod vanwinkle, on Flickr
20221023_212103 by jarrod vanwinkle, on Flickr
20221023_212048 by jarrod vanwinkle, on Flickr
I made a really bad decision I used a wipon clear coat it look great from 15 feet but it has a lot of runs
20221025_193003 by jarrod vanwinkle, on Flickr
20221103_132601 by jarrod vanwinkle, on Flickr
20221116_173428 by jarrod vanwinkle, on Flickr
I reinforced the dove tail and added d rings
20221102_192006 by jarrod vanwinkle, on Flickr
20221102_194241 by jarrod vanwinkle, on Flickr
20221102_194235 by jarrod vanwinkle, on Flickr
20221102_210128 by jarrod vanwinkle, on Flickr
20221102_210113 by jarrod vanwinkle, on Flickr
Took it for its first haul
20221109_152506 by jarrod vanwinkle, on Flickr
20221109_152456 by jarrod vanwinkle, on Flickr
20221109_172350 by jarrod vanwinkle, on Flickr
then a month later the DD broke down lol
20221127_164244 by jarrod vanwinkle, on Flickr
20221223_170252 by jarrod vanwinkle, on Flickr
20221223_170306 by jarrod vanwinkle, on Flickr
led head lights
20230216_132145 by jarrod vanwinkle, on Flickr
20230216_132202 by jarrod vanwinkle, on Flickr
installed a work light for the bed it came of the YJ I had.
20230222_210225 by jarrod vanwinkle, on Flickr
20230222_210236 by jarrod vanwinkle, on Flickr
20230222_210527 by jarrod vanwinkle, on Flickr
20230222_210553 by jarrod vanwinkle, on Flickr
20230222_210602 by jarrod vanwinkle, on Flickr
air ride, c30, cummins, nv4500, ramp truck
