Old 08-28-2021, 05:10 PM   #126
65Custom
Re: Power Window Project DIY 64-66 TRUCK
So I'm just wondering on this topic, I see that this seems to work really well and can be done and saves money, but Has anyone ever looked at using the 80's square body power window regulators for these trucks? Just curious since they are similar sure there are some differences but wondering if they would be a fit and replacement for these trucks?
If anyone knows let me know.
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=366677
I must be
65Custom is offline   Reply With Quote
Old 03-29-2022, 01:23 PM   #127
Steve Van Gent
Steve Van Gent's Avatar
In my option, not even close. The mount is a 4 bolt system and at wrong points.
The concept here was to use the actual regulators for the correct truck, simply add a motor to them.
Steve Van Gent is offline   Reply With Quote
Old 03-29-2022, 01:55 PM   #128
Steve Van Gent
Originally Posted by Sick5 View Post
ok who has the parts list?? lol
Had a few minutes today, here is list so far;
MOTOR with correct tooth pitch (GMC Safari model):
https://www.carparts.com/details/Che...B&gclsrc=aw.ds
Spacer that must be used for mounting motor above. The motor that comes with spacer will NOT WORK, wrong pitch teeth. WE ONLY WANT THE SPACER THAT COMES WITH THIS MOTOR. Give motor to your square body friends…
https://www.amazon.com/Dorman-742-15...Motors+742-150
Manual Regulator that will be used. NOTE: YOU will need both Right and Left side versions, which are different:
https://www.classicparts.com/1964-66...tinfo/18-730/#
https://www.classicparts.com/1964-66...ctinfo/18-729/
Motor Pigtail wiring:
https://www.repairconnector.com/prod...r-1979-up.html
Power window RETRO handle control- this one takes some effort to install and is very generic, not 64-66 friendly, but will work. QUITE EXPENSIVE!!! (ANYONE THAT FINDS A BETTER RETRO SWITCH OPTION, PLEASE POST!)
https://www.summitracing.com/parts/a...UaAktvEALw_wcB
Old 03-16-2024, 06:44 PM   #129
E.TexasTwister
Anyone find a better handle control yet?
E.TexasTwister is offline   Reply With Quote
