12-29-2017, 11:24 AM | #126 |
Re: Yet another 72 going under the torch, factory 3 speed on the tree!
12-29-2017, 12:02 PM | #127 |
Here you go, does have some issues 28 shipped let me know if interested.
12-30-2017, 07:27 AM | #128 |
I'll take those. I'm also looking for the section of the door that has the hole for
the ferrule if you have any. Drivers side. Thanks. |
12-30-2017, 10:07 AM | #129 |
12-31-2017, 12:31 AM | #130 |
If you think it'll work I'll give it a try. How much for everything?
12-31-2017, 10:01 AM | #131 |
01-01-2018, 04:22 PM | #132 |
Payment sent. Thank you.
01-02-2018, 12:17 AM | #133 |
01-02-2018, 02:04 AM | #134 |
Does it have the original gas tank? I'm looking for an original filler tube on the tank itself to put on a new aftermarket tank.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
01-02-2018, 08:14 AM | #135 |
Yes it did I cut the filler neck off and had it blasted it will need about an inch at the very end repaired. I will get some pictures later today.
01-02-2018, 10:26 AM | #136 |
Did anyone ever buy those seat brackets? I need both sides. 33511
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
01-02-2018, 11:37 AM | #137 |
01-02-2018, 12:56 PM | #138 |
It will need a 2 inch pieces added its a shame because the rest of the tube is pretty solid. I think a straight piece of tube the same OD will work but your call 20 plus shipping. If interested send me your zip and I will get you a quote.
01-02-2018, 12:58 PM | #139 |
Just realized the pictures don't show the worst damage I can get better if you like but most is closer to the end. The hole at the 2 inch mark is back farther then the rest of the damage.
01-02-2018, 04:30 PM | #140 |
1rippen6, Do you have a good pair of these rear seat front mount hold down plate/bolts? Circled in the picture.
01-02-2018, 04:39 PM | #141 |
I could make that work, but do you think the other Blazer you have coming in would have a better one?
I also need some hatch latches if you have them too. My zip is 70578
01-02-2018, 07:21 PM | #142 |
01-02-2018, 07:22 PM | #143 | |
01-02-2018, 07:25 PM | #144 |
I can wait to see if the other one is better, I'm not in a big rush.
01-03-2018, 02:18 AM | #145 |
01-06-2018, 01:40 PM | #146 |
I will take that gas tank filler tube and make it work, since the other Blazer doesn't have a tank. We can wait until we figure out the hatch latches on the other Blazer so that we can combine the shipping.
01-06-2018, 01:45 PM | #147 |
01-08-2018, 01:10 PM | #148 |
Vintage Evil
Is the floor in this any good? I mainly need the outside front seat riser from each side... the PO chopped up the seat mounting plates under the floor to put in a different seat... once i removed the new seat mount pretty much everything is swiss cheese on both sides...
Current Rides: Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread EvilK5 - 71 K5 Blazer Evil Twin - 2006 Suzuki M109R EvilDmax- 2018 GMC 2500 Denali Duramax |
01-08-2018, 02:11 PM | #149 |
How are the 4wd locking hubs?
Joe 1968 K20 1970 K20 Semper Fi |
01-08-2018, 06:20 PM | #150 |
