Old 02-08-2019, 09:58 AM   #126
RADustin
Re: 1976 CCSB Duramax Project #trucknamedsue
Originally Posted by 83GMCK2500 View Post
Any idea what the year range is on early doors? If there's an early crew/suburban in a yard near me I'd cut out the tops of the inner door skin for you.
early doors are 73-76. But I don't think the piece I need is specific to just the early doors.
1949 Chevy 3100 P/U
http://67-72chevytrucks.com/vboard/s...d.php?t=302780
1976 GMC Sierra Classic C35 CCSB
http://67-72chevytrucks.com/vboard/s...25#post8188825
RADustin is offline   Reply With Quote
Old 02-08-2019, 11:55 PM   #127
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I have a 80 C20 I'm cutting up. Send me a pic of what you need and I'll cut them off these doors for ya.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 02-09-2019, 02:27 AM   #128
AJC
I have a set of 76 doors that have lower rust problems that your welcome to have patches form also.
AJC
AJC is offline   Reply With Quote
Old 02-09-2019, 11:41 AM   #129
RADustin
Oh man! This would be awesome. This is the hole I’m trying to fill.
1949 Chevy 3100 P/U
Old 02-09-2019, 11:42 AM   #130
RADustin
Thanks! If this offer from AJC doesn’t work I’ll hit you up.
1949 Chevy 3100 P/U
Old 02-09-2019, 07:19 PM   #131
AJC
Wow they did a number on that. How big of a patch do you want? I give you both doors if you know how to ship them. They need some rust repair at the bottom. I will get some pictures after I dig out my shed. Got to love snow.
AJC
Old 02-10-2019, 11:00 PM   #132
RADustin
just the patch would be fine. I'll lay some marks on my door tomorrow, and maybe you can match them up and hack it out???
1949 Chevy 3100 P/U
Old 02-11-2019, 12:11 AM   #133
ericjon262
uhhh.... wow! now that's a build!
'06 2500 HD 4x4. manual transfer case, crank windows.
'88 V10 Suburban 4x4,"The Pig Rig" L05, 700r4, NP208, 4x4 beater camper fun truck project.
My trucks don't leak oil, they mark their territory.
ericjon262 is offline   Reply With Quote
Old 02-12-2019, 01:10 AM   #134
AJC
That works.
AJC
Old 02-26-2019, 10:16 AM   #135
RADustin
That works.
sorry it took so long. Got side tracked.
need a piece that goes ~4" below the window opening, and ~11" long. the width would be offset from the door crank hole by ~2" or so.
see attached pics. LMK if you can cut it out, and how much you want. I can send over some money.
Thanks!
1949 Chevy 3100 P/U
Old 02-28-2019, 01:09 PM   #136
AJC
I will get on cutting those out.
AJC
Old 02-28-2019, 01:19 PM   #137
RADustin
thanks!
1949 Chevy 3100 P/U
Old 03-15-2019, 03:11 PM   #138
AJC
Finally got some time to cut them out. PM me where you want them sent.
AJC
Old 03-15-2019, 06:03 PM   #139
RADustin
sweeet!
1949 Chevy 3100 P/U
Old 03-15-2019, 09:07 PM   #140
rennat_2006
rennat_2006's Avatar
Awesome build, definetely following.
FYI a 2" body lift and a heavily modified core support will fit a stock lbz cooling "stack". Dropped the bottom of the core support down 2" which gave me most of the clearance needed. No body lift pucks will be used under the core support mounts since it got its "lift" from dropping the bottom down 2".
1972 C10 cheyenne super -350/th350 Wifes truck
1971 Nova- 6.0l with some goodies and a t56, 98-02 camaro brakes all around, tubular control arms, etc
2000 zr2 blazer- rock crawler offroad toy, one ton axles and lockers front and rear.
2006 2500hd- 500hp duramax/built allison trans,traction bars, and some other goodies.
rennat_2006 is offline   Reply With Quote
Old 03-18-2019, 01:37 PM   #141
RADustin
man that's sweet.
is that an 81+ core support?
I actually brought the bottom of my support lower than factory, taking up some of the stock gap between the support and frame. It's weird to think about, but the stock support bushing is basically frenched or counterbored up in the bottom just a hair.
1949 Chevy 3100 P/U
Old 03-18-2019, 01:40 PM   #142
rennat_2006
Yes its an 1984
Old 03-18-2019, 01:44 PM   #143
RADustin
for some reason, those seems like they are way more easily 'swappable' than the earlier ones. I haven't messed with one personally, but I have one friend with a cummins swapped '76 and another friend with a '84 and the 84' has way more space up front for the intercooler and what not.
it looks 'flatter' if you know what I mean.
I dig the crap out of you using the mechanical fan. I haven't seen anyone else doing that. Did you offset the motor from center line or the cooling stack?
1949 Chevy 3100 P/U
Old 03-18-2019, 02:56 PM   #144
rennat_2006
Cant get pics to upload right now. Motor is centered and cooling stack is centered in the core support also. I will post some pics tonight and probably make a new thread so i dont hijack this one.
Truck is being built to work so sticking with the lbz complete cooling setup was a priority to make sure everything was gonna work and stay cool, should be overkill in this truck honestly. Also easy to source replacement parts out on the road.
Old 03-18-2019, 03:21 PM   #145
RADustin
and you used truck parts? my lb7 shrouds makes the fan offset from center on the cooling stack. about 1/2" IIRC.
In a stock GM truck, the engine is offset to the passenger side, and the cooling stack is centered. So when I centered my engine, I had to offset the cooling stack.
I'm wondering if the LBZ rad is offset from center, along with the engine- making all the components centered up. I'll have to measure some LBZ parts I have.
very interesting.
I hear you on using stock d-max parts. I plan to tow with mine as well, hence the gooseneck. Everyone I've talked to said the LB7 parts should be fine with a proper cold air intake as that was the pitfall of the LLYs.
With LBZ cooling stack and no EGR(assuming you'll delete), you should have more than enough cooling. I'd only look at using the LML trans cooler.
1949 Chevy 3100 P/U
Old 03-19-2019, 01:17 AM   #146
rennat_2006
Yes im using stock truck parts, all lbz including shroud and fan. I am not running the inner shroud/cage deal around the fan.
Egr is deleted, bigger downpipe(lbz truck aftermarket replacement)is installed and 4" will be ran out the back. Stock charger for now and running the stock lbz air intake and powercore or whatever it is called filter setup. Should put down 500hp to the tires with the tuning i have.
We went with a aftermarket trans cooler, i will get the part # and post it. I built the trans to hold 750hp so it needs plenty of cooler.
Old 03-21-2019, 11:30 AM   #147
Devilman
The 94-02 dodge diesel cooling stack fits perfect in the core support, almost like they're meant to. I was origionally gonna use the cooling stack from my LBZ donor truck but decided to stick with using dodge parts due to ease of fit and scoring a mishimoto radiator and an on3 performance intercooler for dirt cheap.
Devilman is offline   Reply With Quote
Old 03-21-2019, 01:39 PM   #148
RADustin
what cooling fan arrangement do you have?
the 2nd gen cummins cooling parts essentially bolt in the 80+ core supports. It doesn't go in as cleanly in the 73-80 supports IIRC.
1949 Chevy 3100 P/U
Old 03-21-2019, 01:45 PM   #149
rennat_2006
I thought about using the dodge stuff but wasnt sure if it would be enough under heavy towing. I decided to go through the work to fit the oem lbz stuff because i know it works from first hand experence from my truck in my signature and being super easy to find anywhere you may be in the US be it from local parts store or a wrecking yard.
Old 03-21-2019, 01:46 PM   #150
RADustin
did you total the 2006 and using it as a donor?
1949 Chevy 3100 P/U
