Old 12-23-2019, 02:11 PM   #126
Camaroguy
Camaroguy's Avatar
Re: Son's 68 c10 Short Bed
Didn't take any pictures but got the power steering all buttoned up on Saturday. The boy is working this week on removing the old cross braces from underneath the original bed floor so we can install them under the new floor.
Had to order another fan relay and some other small parts (Transmission cooler lines, and Temp Sending unit) so we can get this thing ready to fire. Also, I figured out the radiator I bought didn't have an bung for the fan relay so I ordered one we will have to Heliarc it in.
Former Build (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=724379 (SOLD)
Current Built (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=787712
Camaroguy is offline   Reply With Quote
Old 12-31-2019, 02:00 PM   #127
Camaroguy
Camaroguy's Avatar
We got some stuff done over the Christmas break.
First picture is of the tranny cooler lines. I had a local shop sweat some fittings on them and I will run rubber hose to the radiator.
Second picture is of the steering wheel my son got for Christmas.
Third picture is of the engine with the harness all strung out. I still need to clean up the wiring but it is basically done. I bumped it over on Saturday which was exciting. Need to do a couple more small things like plumb the radiator and fill it with fluids. Also need to wire the fan relays and mount the computers but we should be making smoke by the weekend.
Old 01-02-2020, 11:22 AM   #128
Camaroguy
Camaroguy's Avatar
I was able to spend part of New Year's Day working on the truck. Finished the fan relays, and the transmission cooler lines. Today, they need to find some radiator hoses and add antifreeze and fuel and it should start.
Old 01-02-2020, 11:24 AM   #129
Camaroguy
Camaroguy's Avatar
I don't know why the pictures are uploading sideways. Anyone know how to fix it?
Old 01-02-2020, 11:35 AM   #130
MDPotter
MDPotter's Avatar
Are you using the 3-relay setup?
If you're using an iphone, you have to take the picture holding the phone sideways with the home button on the right.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 01-02-2020, 11:52 AM   #131
TA_C10
TA_C10's Avatar
Looking good!
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 01-02-2020, 12:14 PM   #132
Camaroguy
Camaroguy's Avatar
3 relays for the fan or the harness? The fan was 2 and the harness has 3.
Old 01-02-2020, 12:15 PM   #133
Camaroguy
Camaroguy's Avatar
Originally Posted by TA_C10 View Post
Looking good!
Thank you
Old 01-02-2020, 12:30 PM   #134
MDPotter
MDPotter's Avatar
For the fans. It's a GM schematic that allows both fans to run half speed at the low temp setting and then both run full speed at the high temp setting. This setup gets its triggers from the PCM. I like it because it pulls air across the whole radiator all the time and is quieter.
Old 01-02-2020, 02:54 PM   #135
Camaroguy
Camaroguy's Avatar
Well, this just happened.....
https://youtu.be/-L6-lUMfA7o
https://youtu.be/4-5tb7Yw1HA
https://youtu.be/tVoyquxHMdg
Old 01-02-2020, 03:02 PM   #136
TA_C10
TA_C10's Avatar
BadAZZ!!
qq, do your tailpipes clear the rear axle when fully suspended in c-notch? I had to bend mine up after the cross-member or they would hit when fully suspended up to bump-stops in c-notch. Just curious.
The exhaust sounds really good. I will go back through your thread, but if you didn't say, what are the exhaust details? mufflers? H or X pipe?
"It's only money".
Old 01-02-2020, 03:28 PM   #137
Camaroguy
Camaroguy's Avatar
BadAZZ!!
Tailpipes should clear without issue. Exhaust was built in house with use of mandrals, no x or y. Mufflers are Flowmasters. The quiet ones. I can't remember what they call them.
Old 01-02-2020, 06:24 PM   #138
Camaroguy
Camaroguy's Avatar
Yeah that's probably the way to do it. I just did a fan relay kit and wired them separately.
Your truck looks good and is coming along nicely.
Old 01-03-2020, 10:20 AM   #139
MDPotter
MDPotter's Avatar
Thanks.
I'm jealous of you guys with coil spring rear ends for the ride quality, traction characteristics, and clearance for mufflers to be hung up high.
Old 01-06-2020, 11:15 AM   #140
Camaroguy
Camaroguy's Avatar
Thanks.
The last one of these we built (link in signature) was a leaf spring truck. Each has it's own set of advantages and challenges that's for sure.
Old 01-06-2020, 11:50 AM   #141
Camaroguy
Camaroguy's Avatar
On Saturday, I was able to get most of gauges working. Still need to run a line for the oil pressure gauge and order a speedo converter.
I also installed the check engine light. It's currently lit because I haven't gotten my air intake in and installed so the MAF is plugged in but just sitting on top of the intake.
Old 01-13-2020, 12:33 PM   #142
Camaroguy
Camaroguy's Avatar
Small little update from the weekend. I am cleaning up the wiring still and got the Neutral Safety Switch all finished up as well. I also installed a radiator overflow. Picked it up from LMC and mounted it using the factor windshield wiper fluid bracket welded to the bracket that came with the catch can.
Old 01-13-2020, 01:55 PM   #143
SCOTI
SCOTI's Avatar
Nicely done. The integration keeps the OE look.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-15-2020, 11:21 AM   #144
Camaroguy
Camaroguy's Avatar
Thanks, that was the idea.
Old 01-17-2020, 10:58 AM   #145
cornerstone
cornerstone's Avatar
Nice progress! Where are you guys with the bed? Hows that coming along? I'm looking forward to see the fuel door mods and set up.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 01-20-2020, 11:25 AM   #146
Camaroguy
Camaroguy's Avatar
Honestly, we haven't touched it since the last pictures. Once school is out, the boy will jump back on it and hopefully knock it out relatively quickly. The front clip is stripped but nothing done on it either. Hopefully, next step is to get the doors painted and hung so I can wrap up the interior.
Old 02-03-2020, 05:23 PM   #147
Camaroguy
Camaroguy's Avatar
Spent a few hours on the truck last weekend and was able to get the air cleaner/filter assembly installed. I bought a cheap kit off amazon and had to cut it down and built a support arm off the battery box. Came out pretty nice though.
Old 02-03-2020, 05:25 PM   #148
Camaroguy
Camaroguy's Avatar
I also finally took the time to build a bracket to mount the DBW gas pedal. This was something I have been dreading but I think it came out nice.
Old 02-05-2020, 05:36 PM   #149
MDPotter
MDPotter's Avatar
Looks good to me! That seems to be what most guys do.
Old 02-10-2020, 10:43 AM   #150
Camaroguy
Camaroguy's Avatar
This past weekend we finished the sound deadening, and installed the carpet and seat. The boy got to putt the truck around the facility a few times which was fun.
