Old 09-18-2021, 07:52 PM   #126
Grumpy old man
Grumpy old man's Avatar
Re: 1968 C10 Stepside Restoration Project
You may want to consider welding the upper seams also and use some short hair glass filler to smooth it all out and not have to worry about seam sealer around the windshield .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 09-19-2021, 09:46 AM   #127
68 C10 Driver
Hey Grumpy, I am there with you on eliminating those seams (see pic below). I had previously welded that area up above the windshield in an effort to remove any potential entry points for water and rust formation. I plan on spraying all of that, as well as the interior with epoxy primer as further protection.
Once I finish the interior welding, I will epoxy prime it and spray the Lizard Skin.
68 C10 Driver is offline   Reply With Quote
Old 10-12-2021, 08:36 AM   #128
Two Stall
Very cool truck. I love seeing that you have young help. Good for future love of hot rodding. I built a very similar dolly for my cab as well. Good luck, Two Stall
Two Stall is offline   Reply With Quote
Old 10-12-2021, 10:48 AM   #129
geunther
geunther's Avatar
Amazing job and nice methodical work.
geunther is offline   Reply With Quote
Old 10-15-2021, 09:50 AM   #130
68 C10 Driver
Thanks Guenther, I appreciate the compliment. The encouragement I get here really helps, so many folks here with so much expertise...it's amazing!
Old 10-15-2021, 06:46 PM   #131
68 C10 Driver
I wanted to show the progression of the rusted out under dash repair I did...
Old 10-15-2021, 06:49 PM   #132
68 C10 Driver
Now I am prepping to paint the cab interior with epoxy primer, then on to the Lizard Skin.
Old 10-16-2021, 06:51 PM   #133
68 C10 Driver
So I took advantage of thr beautiful weather and sprayed on the epoxy primer this afternoon.
Old 10-16-2021, 11:57 PM   #134
Kronald_70GMC
Kronald_70GMC's Avatar
Looks good! Great job
Kyle
1970 GMC "Project Splice"
2017 Silverado LTZ (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 10-17-2021, 09:14 AM   #135
68 C10 Driver
I built the dolly based upon the one Paulkc10 built in his YouTube videos. Paulkc10 and Gibson63 were great resources for understanding how to properly repair the cab.
Old 10-17-2021, 05:17 PM   #136
68 C10 Driver
So another item is ticked-off of the list...seam sealer is on.
Old 10-17-2021, 05:18 PM   #137
68 C10 Driver
I am going to try to get the Lizard Skin sound barrier down Monday, at least the first coat..
Old 10-18-2021, 08:22 PM   #138
68 C10 Driver
Another beautiful day means another opportunity for working on the truck. The weather was great...no wind, not hot, not humid. Perfect day to apply the Lizard Skin. Being water-based, the low humidity is helping it cure really nice.
Old 10-18-2021, 08:32 PM   #139
Kronald_70GMC
Is it easy to work with the Lizard Skin? I still have to decide what to run on the inside of my cab.
Kyle
IG: kyle_ronald
Old 10-19-2021, 06:23 PM   #140
68 C10 Driver
It is easy-peasy! I would say near fool-proof. It will make a mess, so put a tarp down to ensure the over spray/spatter is contained.
I never used it before and it's easy to work with. It is water soluble so clean-up is a breeze.
Old 10-20-2021, 04:51 PM   #141
68 C10 Driver
Ok, the Lizard Skin thermal barrier is now on...glad to be done with that, it was a 4 day affair allowing a day to dry between coats.
I also coated the inside of the cowl intake with Raptor Liner...that should seal that up really well!
I think I will move on to the frame next for a little change of pace.
Old 10-20-2021, 07:22 PM   #142
May70
May70's Avatar
That turned out nicely
70 C20 Build link : Project Montezuma
http://67-72chevytrucks.com/vboard/s...d.php?t=794479
How to repair that rusted out 67-72 c10-c30! Please subscribe!
https://www.youtube.com/c/MaycoCustomRestorations
May70 is offline   Reply With Quote
Old 10-20-2021, 08:20 PM   #143
68 C10 Driver
Thanks!
Old 10-27-2021, 08:47 PM   #144
68 C10 Driver
So I know that I will be painting the interior of the cab, thus painting over the Lizard Skin. My thought is that I want the smooth looking kick panels, as the doors will also be smooth because they are not coated with the Lizard Skin. As you can see in the photo there is a pretty definite texture to the kick panel shown.
So I will sand the kick panels a bit (not removing all of the texture) and spraying with high build primer, sanding. and using a glazing putty to smooth it out.
Old 10-30-2021, 09:42 PM   #145
68 C10 Driver
So I sanded and used filler primer and some glazing putty to smooth out the driver's side kick panel, also removed the remaining seam sealer from the rain gutters to day and applied some Rust Mort. Once that dries I will prime and sand.
Old 10-30-2021, 09:54 PM   #146
68 C10 Driver
I also coated the outer part of the kick panel where the cowl drains (and part of the A pillar as well with Raptor Liner in an effort to stop any future rust from forming. I also coated the inside of that cowl area where it drains with Raptor Liner too. I sanded some of the texture down and primed that...it will get painted along with the rest of the cab.
Old 10-31-2021, 10:07 AM   #147
raggedjim
raggedjim's Avatar
Nice work, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 10-31-2021, 10:18 AM   #148
68 C10 Driver
Thanks, I appreciate it! I am just trying to build a tribute truck to my father-in-law that will survive me and give the kids something to remember me by after I am gone (their grandfather passed several years before they were born).
Old 11-02-2021, 07:33 AM   #149
A1971Blazer
A1971Blazer's Avatar
Shaun...very nice progress on the cab....what I thought was a solid cab on my '67 has turned out to be not so solid.....some slightly rusty (looking) places on the outside turned out to be some really bad (hidden) rust inside...
I'm knee deep in cab repair....have a new roof, new rear panel, front windshield header panel and nearly every other patch panel known to man....
the good news is that the panels available now days seem to be a better fiy than the ones in the past...I hope that holds true....
Keep up the good work...I'm following your build...
BTW I found that little bracket for the spare tire mount....I thought I had sent it...sorry...I'll put it in the mail
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 11-02-2021, 08:13 PM   #150
68 C10 Driver
Post Re: 1968 C10 Stepside Restoration Project
Attachment 2142903
Attachment 2142904
A1971Blazer, sorry to hear about the rust you have encountered. I bought a borescope like device that I snaked through all of the cab cavities and found only surface rust. I have sprayed Rust Mort where I could, but the WaxOyl should get to those areas I may have missed up in that roof cavity.
I am with you, most of my patch panels have been good quality (knocks on wood), I hope that trend continues. I am about to seam seal the drip rails, luckily I have only found minor surface rust under the old seam sealer that has been there since 1968. Not bad. Most of my rust has been in the lower 1/4 of the cab.
Great news on that bracket, thanks for looking, send it when you get time.
Cheers-
