Old 01-10-2014, 08:40 PM   #1476
SeTx67
SeTx67's Avatar
Re: 1968
Been in a while since I checked in on your build George. It's looking great. Keep up the good work
SeTx67 is offline   Reply With Quote
Old 01-10-2014, 10:02 PM   #1477
afmedic01
afmedic01's Avatar
Re: 1968
Nice build, keep up the good work.
My build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=611258
69 C10 SWB Fleet(under construction)
350/TH350
Porterbuilt Front/Rear Mild Dropmembers
Accuair e-level kit
Coys C5 22x9, Nitto 555 255/30r22
afmedic01 is offline   Reply With Quote
Old 01-10-2014, 11:27 PM   #1478
Bomp
Bomp's Avatar
Re: 1968
Box came out Sweet!
Bomp is offline   Reply With Quote
Old 01-11-2014, 12:59 AM   #1479
sduckworth13
sduckworth13's Avatar
Re: 1968
Truck is looking great George, I really like the Kubota Orange color. The bed looks super straight and shiny.
Scott
sduckworth13 is offline   Reply With Quote
Old 01-11-2014, 07:57 PM   #1480
gdavis
gdavis's Avatar
Re: 1968
Originally Posted by Bomp View Post
Box came out Sweet!
hey bomp where have you been haven't heard from you in a while.
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 01-11-2014, 07:58 PM   #1481
gdavis
gdavis's Avatar
Re: 1968
I had the kubota orange gave to me. and after I used it on a project I liked it so the rest of the story is history
Check out Patches
Old 01-11-2014, 07:59 PM   #1482
gdavis
gdavis's Avatar
Re: 1968
thanks man and same to you keep it coming.
Check out Patches
Old 01-11-2014, 08:00 PM   #1483
gdavis
gdavis's Avatar
Re: 1968
check back every once in a while. I do try and do something even if it is wrong.
Check out Patches
Old 01-12-2014, 05:40 PM   #1484
gdavis
gdavis's Avatar
Re: 1968
Well, I got the front panel cartiage bolts installed. The bolts were too long. I had to cut the bolts off so they did not get in the way if I wanted to wash between the bed and cab in the future.
I had some bad rotor studs and installed new ones.
Check out Patches
Old 01-13-2014, 01:12 AM   #1485
cubber
Re: 1968
Boy, that orange looks good!
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 01-13-2014, 07:40 AM   #1486
rich67
rich67's Avatar
Re: 1968
nice detailed build thread george. what kind of primer and paint did you use on your frame and all of its parts?
rich67 is offline   Reply With Quote
Old 01-13-2014, 10:20 AM   #1487
gdavis
gdavis's Avatar
Re: 1968
thanks guy
Check out Patches
Old 01-13-2014, 10:21 AM   #1488
gdavis
gdavis's Avatar
Re: 1968
rustolelm on frame and 2K primer on the sheet metal
Check out Patches
Old 01-13-2014, 06:45 PM   #1489
dfwright
dfwright's Avatar
Re: 1968
Looking very nice, George! It's looking really good now, with the parts all coming together. You're an inspiration to do a little bit each day, eventually it all gets done.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 01-13-2014, 07:10 PM   #1490
gdavis
gdavis's Avatar
Re: 1968
Thanks. I am waiting on weather to paint the cab. It has been raining a lot down here in Fl.
Check out Patches
Old 01-13-2014, 07:17 PM   #1491
gdavis
gdavis's Avatar
Re: 1968
Today I recieved some more parts. Two brake lines that run from the master cly to the port valve. I tried to use advance auto brake lines. But they did not bend like the oem. so now I will replace the ones I bent.
(2) door seals. How I need a seal for the rear glass. (large) If any of you guys have one that you didn't use plz contact me.
Check out Patches
Old 01-14-2014, 10:30 AM   #1492
gdavis
gdavis's Avatar
Re: 1968
another rainey day in Florida.
Check out Patches
Old 01-14-2014, 11:22 AM   #1493
Low Elco
Re: 1968
Keep after 'er, George! Lookin' great so far!
Low Elco is offline   Reply With Quote
Old 01-14-2014, 11:42 AM   #1494
~Whitey~
~Whitey~'s Avatar
Re: 1968
Trucks looking great George, You've come along way since I last looked!
Jimmy
.69SWB Build.
~Whitey~ is offline   Reply With Quote
Old 01-14-2014, 08:51 PM   #1495
gdavis
gdavis's Avatar
Re: 1968
thanks alot there man.
Check out Patches
Old 01-14-2014, 08:53 PM   #1496
gdavis
gdavis's Avatar
Re: 1968
yea I try to do something every once in a while. weather is slowing me down Rain
Check out Patches
Old 01-16-2014, 11:28 AM   #1497
gdavis
gdavis's Avatar
Re: 1968
Thanks a lot there guys. I wll be installing a rebuilt steering column soon.
Check out Patches
Old 01-18-2014, 11:03 AM   #1498
gdavis
gdavis's Avatar
Re: 1968
it's going to get down to 28 in the morning to cold to work on the old gal. So Nothing to post today.
I did pull my steering column off the truck. I got it ready for shipment to a guy that said he could make it work right.
also ordered a rear window seal. Now I have all my glass seals, so when I get her painted I can install the glass. any tips on this?????????/
Check out Patches
Old 01-18-2014, 09:03 PM   #1499
gdavis
gdavis's Avatar
Re: 1968
Does anyone know a easy way to put the glass seals and glass in the truck??????
Check out Patches
Old 01-18-2014, 10:09 PM   #1500
WIDESIDE72
WIDESIDE72's Avatar
Re: 1968
Originally Posted by gdavis View Post
Today, I sanded the cab and front clip and shoot some 2K primer on. Now I can let it set untill I need to shoot the color.
I removed the doors so I could sand and prime the doors easier. I can also shoot some color on the doors in my shop. I will be ahead of the game this way.
Here is the picture of the cab with doors removed.
The project looks great! BTW It looks like you haave a 72 driver side door (screw hole by vent window). I have had to do the opposite in the past and cut and welded a patch with the screw when using 68-71 doors on a 72
WIDESIDE72 is offline   Reply With Quote
