Old 04-14-2015, 01:37 PM   #1476
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
but wait it gest worse, you know me and stickers right, so I go to peal off the REMANUFACTURED sticker off the back of this thing, and I pull a foot of paint off with it
heck this paint job makes mine look like Michelangelos'
Gregski is offline   Reply With Quote
Old 04-14-2015, 01:41 PM   #1477
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
ok, third and final straw that broke the camel's back as I was still trying to make it work, by mounting on all the brackets, was this stupid key that would not fit in the groove to put the pulley back on
now, come on Greg just grind it flat a bit and it will slide right in, don't tell me I didn't consider that till I slid it in my pulley and it fit snug there, so if I were to grind it down it would wiggle in the pulley while fitting in the shaft, not gonna do it
Old 04-14-2015, 01:42 PM   #1478
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
The Greg is off to NAPA for a new power steering pump... be right back
Old 04-14-2015, 02:19 PM   #1479
enaberif
Re: Restoring Rusty
uh oh... Reman was crap.
enaberif is offline   Reply With Quote
Old 04-14-2015, 02:21 PM   #1480
enaberif
Re: Restoring Rusty
**double post**
Old 04-14-2015, 03:27 PM   #1481
greg64
greg64's Avatar
Re: Restoring Rusty
That's sad. What good is a reman no one can really use? Good luck, Gregski.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 04-14-2015, 05:08 PM   #1482
rusty76
rusty76's Avatar
Re: Restoring Rusty
Always fun.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 04-14-2015, 05:42 PM   #1483
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
decided to take the steering gear box off, but cant get the pitman arm off the knuckle, can I use a pickle fork on it?
Old 04-14-2015, 07:19 PM   #1484
Titomars
Titomars's Avatar
Re: Restoring Rusty
That is just one of the many reasons I do NOT buy hard parts from O'Reilly's.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 04-14-2015, 07:23 PM   #1485
Titomars
Titomars's Avatar
Re: Restoring Rusty
I personally don't use pickle forks they tend to do more damage than help.
I remove my Pittman arms with a good 2 or 3 lb sledge hammer. A couple of good strikes will release it once the nut is off. Like tie rods ends the Pittman arm to shaft is a taper fit.
Old 04-14-2015, 08:22 PM   #1486
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
ok, well lets get us up to speed on the damage that The Greg has done today, since NAPA had the same crudy pump as Oh Reallys, (they said it's made by BBB Enterprises, that don't sound shady at all) I ordered one from CarQuest (pronounced expensive)
so as I waited for the new(er) pump to arrive I decided to stay busy
what to do, what to do?
I know off with the inner fender
Old 04-14-2015, 08:24 PM   #1487
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
those of you who have been with me and Rusty since day uno, know that The Greg likes his inner fenders not black but the color of the vehicle, so this one is going to get treated to a coat of green on it's back and some undercoating on it's belly, but first he'll need a bath, stay tuned
oh by the way, stripped/broken bolt count = 0
Old 04-14-2015, 08:28 PM   #1488
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
now where were we, oh yes, trying to remove the steering gear box, so since The Greg is a one clown circus he has to improvise so he used his boy scout knot tying skills and fabed this Russian crane hoist
you twist the smaller 2x4 on top and it lifts the part you are trying to lift, genius I tell you
Old 04-14-2015, 08:32 PM   #1489
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
with the steering box literally hanging in the balance I still could not get that darn pitman arm off, yes I tried using gentle persuasion aka my 3 lbs sledge, no go, tried PB Blaster, wedged and broke a large screw driver in there too
I felt as if it was me vs 40 years of stick-to-it-a-vness
Old 04-14-2015, 08:34 PM   #1490
greg64
greg64's Avatar
Re: Restoring Rusty
Wow, you got all those bolts out without breaking any? I'm impressed.
Now, I have something else for you to do. In the picture that shows the master cylinder well, I can see some wires that have blue butt-splices. Those things suck for long term connection quality, but they are quick to put on. I'd take advantage of the great access you have to those wires right now to fix those.
In my experience, with automotive wiring, there's no substitute for soldered connections with heat shrink tubing over the joint. They last forever. Nothing is more frustrating than unreliable wiring.
Greg
Old 04-14-2015, 08:34 PM   #1491
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so off to AZ, to pick up some "specialty" tools
got a fork and a pitman arm puller, the actual pitman arm proved to be useless, LOL
the fork on the other hand got her done!
Old 04-14-2015, 08:36 PM   #1492
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by greg64 View Post
...In the picture that shows the master cylinder well, I can see some wires that have blue butt-splices... I'd take advantage of the great access you have to those wires right now to fix those.
You are making it very difficult to procrastinate on those! LOL
Old 04-14-2015, 08:38 PM   #1493
greg64
greg64's Avatar
Re: Restoring Rusty
Wait a minute on the steering box. It's far easier to release the tapered joint at the other end of the pitman arm with a pickle fork. Unless, of course, you're looking to replace the pitman arm.
The way to get the pitman arm off is with a puller. You apply a fair bit of tension with the puller, and the tap the pitman arm from the side with a hammer. The puller alone won't do it, at least in my experience.
Greg
Old 04-14-2015, 08:38 PM   #1494
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
ok, so let's see that hunk of junk out in the open
FYI the only thing heavier than this steering box on the truck so far be the Muncie gear box, hee hee
Old 04-14-2015, 08:40 PM   #1495
greg64
greg64's Avatar
Re: Restoring Rusty
That's my job!
Greg
Old 04-14-2015, 08:42 PM   #1496
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
then I spent the next two hours transferring the dirt, grime, grease, and rust off of the steering box and onto myself
she aint perfect, but definitely more better...
I would clean her some more [big lie] but I have to go pick up the new(er) pump from CarQuest
Old 04-14-2015, 08:45 PM   #1497
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Says the man who hasn't faced the wroth of the stupid nut that you have to git off first!!! Man not only was it one size bigger than the largest wrench I own, but not even tapping the tool with a sledge could loosen it up... stubborn little fella!
Old 04-14-2015, 08:53 PM   #1498
Titomars
Titomars's Avatar
Re: Restoring Rusty
the 3 lb sledge method only works if the box is still mounted to the frame. I highly doubt the arm will give it up on the floor. Just an observation but it looks like the nut is still on and tight. the nut has to be off or damn near off. The fun begins trying to hold that heavy box up and start a bolt or two.
Old 04-14-2015, 09:02 PM   #1499
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
what gets me is how this massive 3 ton steering box connects to the steering shaft, via a rubber disc the size of your grandmas coffee table coasters, exactly three of them stacked together???
Old 04-14-2015, 09:13 PM   #1500
Titomars
Titomars's Avatar
Re: Restoring Rusty
Yeah I hear ya. I hate those "rag" joints. Cut from old tire carcasses. LOL
