11-17-2022, 01:35 PM | #1476 |
Post Whore
Re: My Dusty 71 GMCe Electruck
meanwhile on this Two Steps Forward One Step Back update, we afixed the new used Honda CR-V master cylinder to the BOSCH iBooster and attempted to bench bleed it on the truck
11-17-2022, 02:01 PM | #1477 |
BlahBlahBlah
11-17-2022, 02:09 PM | #1478 |
Post Whore
11-17-2022, 02:13 PM | #1479 |
Post Whore
so here's the general idea and you is supposed to do this in a vice, with American style master cylinders, anyway that's where that clear line red fitting kit is from
11-17-2022, 02:23 PM | #1480 |
Post Whore
so learned that it's best to reroute the front brake lines to the front of the crossmember when you pull of a disc brake conversion so spent a few evening fandangling with that
nothing like cutting up brand new parts straight away |
11-17-2022, 02:25 PM | #1481 |
Post Whore
and the other side
I did add rubber gromets in them through frame holes |
11-18-2022, 06:43 AM | #1482 |
Stopping power!
71 C10 72 K20 72 K10 Super Kirk |
11-18-2022, 09:22 AM | #1483 |
Who Changed This?
That's a mighty tight bend in that hose. Is the spindle at the end of turn travel?
11-19-2022, 01:06 PM | #1484 |
Post Whore
11-19-2022, 01:15 PM | #1485 |
Post Whore
so I had to scroll up in my own thread way up to post #72 to see what radiator I had and as it turns out it is a generic aftermarket Spectra Premium part #CU369 one that fits the truck but is not specifically for this truck, so it doesn't quite fit on the bottom, it is too thick if you will, being 2 core and all
so I done did some research and learned that a Squarebody aka 1973 and up single core will fit perfectly and the reason I tell you this is that it can be had for half the price of an exact specific 67-72 one Murray Radiator part # 433161 $200 bones and you can get one like it for $120 on Rock Auto I just didn't have the patience to wait on it to arrive so I went to Oh' Really s Last edited by Gregski; 11-19-2022 at 01:56 PM. |
11-19-2022, 01:48 PM | #1486 |
Good info TY
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
11-19-2022, 01:53 PM | #1487 |
Post Whore
so now we have reached the plumbing, heater hose size, coupler, adapter, reducer hell portion of the build, you see we in America like to design our radiators with the largest inlets and outlets known to men and women, and the electrical components (inverters, dc-dc converters, chargers, water pumpulators, and transmissionisters) all like to use small ones, more on this later
essentially what we face is that we can no longer plumb with radiator hoses ( yes 1-3/4" or 1-1/2 or my personal favorite 1-5/16" that's a nice and even 33 millimeter for you non Standardizer type) but instead must plumb with heater core hoses ( 3/4" and or 5/8" ) |
11-19-2022, 01:57 PM | #1488 |
Post Whore
Tezla electric water pump (yes with a "z") uses a 3/4" standard American heater hose
11-19-2022, 01:58 PM | #1489 |
Post Whore
it needs to attach to the radiator outlet which is lets just say way bigger ( 1-9/16ths for those of you keeping track at home)
11-19-2022, 03:38 PM | #1490 |
Post Whore
now the fun continues as the 3/4" hose from the Tezla water pump has to now mate with the 5/8" Lexus inverter inlet, joy
the inverter is arguably the most important metal box in the entire jigsaw puzzle as it convert DC direct current stored in the BMW batteries into AC alternating current which the Lexus motors consume inside of that unicorn of a transmission |
11-21-2022, 12:01 PM | #1491 |
Post Whore
so back to fighting with that Honda CRV electric brake iBooster, the darn thing pulsates when the pedal is fully down, I just don't get it, I know it was designed to work with only disc brakes so maybe there aint enough flow
but I tried capping off the rear brake line at the master cylinder and pressing the pedal to only engage the front disc brakes, and the pedal still wiggles when fully down to the floor I even tried by capping off both outlet ports on the master cylinder, still no dice, is it air? |
11-21-2022, 12:50 PM | #1492 |
Did I miss how you plan on heat defrost etc and cooling transmission just interested on how your planning that if it’s in a post pardon me please
11-26-2022, 11:39 AM | #1493 | |
Post Whore
no heat / defrost in Phase I of the implementation, I live in California (pronounced: Spring, Summer, Fall, repeat) however if I do decide to add heat it will be via an electric heater such as the one from the Chevy Volt as far as cooling the transmission I am going for the belt and suspenders solution, first like any traditional automatic transmission it is plumbed to the radiator's transmission inner cooler that is integrated into the regular dime a dozen Chevy type radiator, then in addition to cooling the transmission fluid this transmission has water cooling built in, so those hoses also run to the regular car radiator (same one) but to the regular water inlets and outlets all this gets recirculated via a Tesla Model S electric water pump hope that hels |
11-26-2022, 11:42 AM | #1494 |
Post Whore
and this is what a $150 bones worth of hose reducers, couplers, and thing majigs look like
Sourced from: Pegasus Auto Racing |
11-26-2022, 11:43 AM | #1495 |
Post Whore
some trial fitment going on here, I do plan on cutting the 90° elbow shorter to bring the hose closer to the Inverter allowing me to use a hose clamp off of it to secure it so it's not all up in space like this (by the way that's a Tesla Model S water pompulator)
the Inverter is a metal box that changes DC Direct Current stored in the BMW batteries to AC Alternating Current consumed by the Lexus motors inside the transmission |
11-26-2022, 11:46 AM | #1496 |
Post Whore
same on this radiator inlet hose, this is coming from the passenger side of the transmission and I hate that it has to run across the engine bay under the battery pack, wish my inlets and outlets on the radiator were on opposite sides (how could Genereal Motors not envision this back in 1967?)
this 90° downward elbow will also be shortened and brong over closer to nearly hug the radiator, this again is just some expensive brain storming this hose will eventually not come out of the battery pack but run in front of it closer to the radiator |
11-26-2022, 11:46 AM | #1497 |
Post Whore
yup, so I tried to cheap out on one adapter and it bit me, here I was trying to connect a 5/8 water pump hose to a 7/8-1 1/2" radiator reducer and no dice, so what you have to do is go 5/8 - 1" reducer to a 1"-1 1/2" reducer to the radiator, oh well this gives me a chance to order a 45° reducer instead of the straight one so there's that
11-26-2022, 06:34 PM | #1498 |
I see a future in the plumbing industry for you
11-27-2022, 07:03 PM | #1499 |
Post Whore
ha, ha yup, that reminds me the proper radiator lower metal support brackets and rubbulators showed up
12-12-2022, 01:37 PM | #1500 |
bump for you! any updates?
Brian XNGH ECV Chapter 58 1972 Jimmy / Blazer Project 2wd 1974 Chevy Crew Cab Shorty |
