#1501 |
Re: 1976 Square "Simple Green"
So you have no notch? Are you riding axle on frame?
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
#1502 | |
#1503 |
I put button bump stops on so I can get my thumb in between frame and button bump stops. Monotube on rear also but I still will hit depending on the bump or hole. I need the PB c notch.
WC flip kit WC drop hangers WC drop shackle. I am at 8" drop in rear and will go that other 1" when I notch it. Last edited by RodsGreen10; 05-23-2016 at 11:12 AM. |
#1504 |
#1505 |
Also get the PB front shock relocators you will need them also.
Get your shocks from KYB outlet or RockAuto. |
#1506 | |
These are the part numbers you would need. These are verified cause I am running them and been running them for 6 months. KYB-KG5474 KYB KG5401 Last edited by RodsGreen10; 05-23-2016 at 04:05 PM. |
#1507 |
So. I have another teaser of my interior. This is my new dash pad trim piece!!!
#1508 |
A closer look.
#1509 |
Would you recommend the KYB Gas-A-Just for stock application right now?
#1510 |
I would. I like how these ride. When I first got them put on I could tell the difference right way. Truck was stiffer tighter in turns I felt more planted on the ground a sporty ride. Now if you don't like that kind of feel you won't like them or any mono shock. I have ran a few different shocks on my truck. And out of them all I honestly like these the best. So yes I would.
#1511 |
Great! Ordered a set today.
#1512 |
#1513 |
And another look of interior trim. The dash bezel. Guys it just keeps getting better and better. I am really excited about this new interior!!!
#1514 |
Also would like to add. Truck sitting this low has never handled so good and tight. Really sporty feeling. Steering is nice and sensitive. I was running up the interstate today just moving along. And could see the wind down force on top of hood lol.
#1515 |
Are you running front and rear sway bars?
#1516 |
Funny you mention Swaybar. The answer is no on the rear. But I have a PB/Addco Swaybar here at the house that won't fit. Due to the angle of the lower tabs on the LCA. Because I am so low. So spoke with Nate which is a top notch guy he said they are about to release the official PB Swaybar one they make in house. So he had me take some angle measurements so he could verify it would work. So I am waiting on that Swaybar. If it won't work then I will be sending this Addco crap back and getting a c notch.
#1517 |
I have a front and rear Belltech kit. Wonder if it'll work. I doubt I'll ever be as low as yours but at least another couple inches in the front.
#1518 |
The rear will work. But not the front. If you get the PB control arms you have to buy PB swaybar. Or you don't run one at all. We all want just a couple more inches right lmao!!
#1519 |
Hey UKNOWME. Did you ever get your grille figured out? If not I might have a option for you.
#1520 |
And I will be grippin tha grain haha... The middle section is support for the process just in case you don't know. Cause I sent this pic to a couple of buddies and they started freaking out.
#1521 |
I ordered a 74 grille and bracket kit but what did you have in mind?
#1522 |
#1523 |
Now the dash bezel dash trim and steering wheel all will be getting cleared and polished can't wait to have it installed!!
#1524 |
Well don't leave me in suspense at least tell me what you were going to say
#1525 |
