Old 04-14-2015, 09:16 PM   #1501
Chaplain
Chaplain's Avatar
Re: Restoring Rusty
Originally Posted by greg64 View Post
Wait a minute on the steering box. It's far easier to release the tapered joint at the other end of the pitman arm with a pickle fork. Unless, of course, you're looking to replace the pitman arm.
The way to get the pitman arm off is with a puller. You apply a fair bit of tension with the puller, and the tap the pitman arm from the side with a hammer. The puller alone won't do it, at least in my experience.
True dat... I removed mine last Sunday.
Chaplain is offline   Reply With Quote
Old 04-14-2015, 09:21 PM   #1502
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Hey man who's side are you on? LOL us rookies must stick together, don't let pros tell ya what to do! jk
Gregski is offline   Reply With Quote
Old 04-14-2015, 09:23 PM   #1503
Chaplain
Chaplain's Avatar
Re: Restoring Rusty
Originally Posted by Titomars View Post
Yeah I hear ya. I hate those "rag" joints. Cut from old tire carcasses. LOL
Steering dampener?
Old 04-14-2015, 09:24 PM   #1504
greg64
greg64's Avatar
Re: Restoring Rusty
Originally Posted by Gregski View Post
Says the man who hasn't faced the wroth of the stupid nut that you have to git off first!!! Man not only was it one size bigger than the largest wrench I own, but not even tapping the tool with a sledge could loosen it up... stubborn little fella!
Okay, I may have an unfair advantage there. I have impact sockets big enough for all these nuts, and the air impact wrench to drive them.
I did once get the pitman arm nut off with a pipe wrench with a length of pipe over the handle. I think the tighten torque is something like 160 ft-lbs, so you know it'll be tougher still to get it off.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 04-14-2015, 09:25 PM   #1505
68Timber
I know the pieces fit
68Timber's Avatar
Re: Restoring Rusty
I'm guessing you've seen this, but just in case you haven't Tx Firefighter did a great how-to on fixing a leaky steering box here: LINK.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 04-14-2015, 09:26 PM   #1506
greg64
greg64's Avatar
Re: Restoring Rusty
Steering dampener?
Ya, those rag joints cut down on vibration. And they aren't the "final word" because there are two steel pins in slots so that if the rag joint ever rotted out and was too weak, you wouldn't lose your steering.
Greg
Old 04-14-2015, 09:49 PM   #1507
enaberif
Re: Restoring Rusty
Just be glad you don't have to remove the actual steering arm. Those tapered cone washers are hell!
enaberif is offline   Reply With Quote
Old 04-14-2015, 09:50 PM   #1508
Chaplain
Chaplain's Avatar
Re: Restoring Rusty
I worried about how to get my new gear box lined up with the pitman arm and the steering wheel/column.
Old 04-15-2015, 12:58 AM   #1509
Titomars
Titomars's Avatar
Re: Restoring Rusty
Yeah I still hate the things. I have replaced way too many of them. So I just don't trust them. I plan to replace my intermediate shaft with u-joints as both ends. eventually.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 04-15-2015, 08:40 AM   #1510
greg64
greg64's Avatar
Re: Restoring Rusty
I agree that the rag joint seems pretty bush-league. With proper u joints in there, how much have you noticed the vibration goes up?
Greg
Old 04-15-2015, 09:52 AM   #1511
Titomars
Titomars's Avatar
Re: Restoring Rusty
I went to a double u joint shaft in my CJ7 (GM steering system). The pros out weigh the cons to me. The only con (for some) is you will get more "road feel". By going to u joint shaft you take out that insulator of a rag joint. but
I don't notice any vibrations just a very positive steering system where I can feel somewhat where the tires are and going through.
Old 04-15-2015, 10:43 AM   #1512
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so picked up my $40 dollar power steering pump for $80 bucks from Carquest, LOL maybe the extra $40 bucks is for the pink blanket it comes with, hee hee
for $80 bucks you think they could afford to put a picture of the actual contents on the box instead of some generic pump photo
I'm pretty sure this is no better than what I got from OReilly's but we'll see, I think some of these parts come from the same source, that's why the resellers rebrand them as their own, Autozone, O'Reillys, NAPA, Carquest, PepBoys
I would prefer to see the manufacturers logo on the box, but then we could compare apples to apples price wise, and the resellers don't want that
[end of rant]
Old 04-16-2015, 01:13 AM   #1513
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so started wire wheelin the frame rail and a bit under the cab in preparation for POR15, not fun, ended up removing the front bumper, again for better access
tomorrow I should paint it black with POR15 to match the other side
Old 04-16-2015, 02:13 AM   #1514
JacobSchni
JacobSchni's Avatar
Re: Restoring Rusty
by the way por 15 doesnt stick as well to bare metal compared to to rusted. from what ive seen, just a quick one over to remove loose rust will work best.
JacobSchni is offline   Reply With Quote
Old 04-16-2015, 08:43 AM   #1515
greg64
greg64's Avatar
Re: Restoring Rusty
I'd agree with this. I've had por-15 peel off when used on shiny steel. That's when I started using the Metal Ready spray (has some new name now) first, and that cured the problem.
Greg
Old 04-16-2015, 08:59 AM   #1516
enaberif
Re: Restoring Rusty
That is because POR15 like a lot of other products are a "rust encapsulator". If you take your frame down to bare metal then use tremclad paint instead.
Old 04-16-2015, 10:18 AM   #1517
cnorth
cnorth's Avatar
Re: Restoring Rusty
My compliments on your progress as usual and your meticulous approach is a inspiration to all of us, and i wish i had the knowledge to help you with some of your problems but all i have is a tip for you.
I have a Portable Abrasive Blaster Kit it's old and from sears but has saved me a ton of time when cleaning up parts I've seen them at harbor freight for $40 the trick is to capture the media as you use it and just reuse it.
cnorth is offline   Reply With Quote
Old 04-16-2015, 10:54 AM   #1518
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
I think you are right, I am learning that too, needless to say I am a bit of a slow learner, lol, that and I have a hard time accepting that I am painting over rust, but I think I am getting over it as removing it is difficult
Old 04-16-2015, 10:56 AM   #1519
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
The Greg is a proud owner of Metal Ready (pronounce expensive made up of a tiny bit of Phosphoric acid diluted with a lot of water and a blue urinal biscuit thrown in for color, hee hee) but hey if that's what it takes, The Greg will git er done
Old 04-16-2015, 01:33 PM   #1520
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by cnorth View Post
My compliments on your progress as usual and your meticulous approach is a inspiration to all of us...
Thank you very much I appreciate that
Old 04-16-2015, 09:24 PM   #1521
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
welcome to another Charge of the Light [truck] Brigade
another day, another wire wheel, I swear one can easily spend as much on these wire wheels (almost $20 a pop) as the purchase of some of our "project" trucks, if I keep visiting Depot Home (as my mum says) like this I may as well suggest they open up a drive through
needless (pun) to say one must replace these every 3 months or 3,000 miles, LOL
(one of these on the LEFT is the used one, can you guess which one that is?)
Old 04-16-2015, 09:29 PM   #1522
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so we managed to get some POR15 black paint on the frame rail
UPDATE: Five years later, the POR15 paint is pealing off in huge chunks the size of 3x5 cards, do not recommend this product at all!
Old 04-16-2015, 09:33 PM   #1523
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so while the frame rail was drying we decided to check on our inner fender which had been marinating in a light muriatic acid / water bath
you can see where the liquid could reach, as there is a distinct line, I could not fit the entire fender into my container so I would rotate it upside down, and down side up, etc
Old 04-16-2015, 09:36 PM   #1524
greg64
greg64's Avatar
Re: Restoring Rusty
I hear ya, Gregski. I've gone through a million wire brush wheels in my grinder too.
Greg
Old 04-16-2015, 09:36 PM   #1525
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Could someone explain to me please, why when one single tiny drop of brake fluid drips from my master brake cylinder onto my brake booster it takes off half the paint off of it, yet when I shmear / lather the entire inner fender with DOT 3 brake fluid it won't remove a single spec ???
